Thank you all very much for the comments and the likes!
It took me until cannon 8 (7 long and 1 medium) to recall my methodology that I used for the cannons on the Prince de Neufchatel.
It works much better if I put the main contour on the barrel and THEN put the rings on instead on adding the contour of the barrel, ring by ring.
Number six has major issues.  I know this.  It will also not be particularly visible as it belongs on the upper gundeck and will be covered with the ship’s boats.
Edited by GrandpaPhil
Building:
I am glad that you like the carving.  I learned from this forum, with the learn to carve group project.
I finished the second medium 12 and carved the first two short 12’s.  The third is nearly done, but I broke it and now it needs to dry before I can put the last band on and bore it out.AD02935F-D1FB-497E-9DCF-34C84382738F.thumb.jpeg.d3dda623db36c93273103a2c9be875b4.jpegB183392E-CCA0-4F11-8366-188FF262738D.thumb.jpeg.7bf652ab7b25cd38b80e5bf638e16dfa.jpeg
Building:
What excellent work phil  cant wait  to see the carriages.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
I made my trunnions.  I made the pivot points that the carronades mount into.
I now have to make a decision about my cannons.  The eyebolts at scale would be too small to thread a breech rope through unless I use thread like I did on the gunport lids.
If I don’t want to use eyebolts then I can make dummy eyebolts and wrap the breech rope around the cascabel, French style (yes this is a British ship, hence the debate).
Building:
Should be second nature to you now Phil 🤪
Victory is looking fantastic
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Wowzer  look at all them  - superb work Phil   amazing work.
OC.
Current builds
Completed works.
I love how the canons/carriages have turned out  - excellent work phil.
OC.
Current builds
Completed works.
Thanks, OC!
I assembled the carriages for the short twelves.
While I wait for those to dry, I am going to start working on tracing out the sleds for the carronades.
After they dry, I’ll paint them and then drill holes for the eyebolts.
I’m using the Tichy HO scale eyebolts again due to the diameter of the thread I’ll need to stay in scale. They will be inside the hull, so I shouldn’t have problems with them breaking again.
Just for the record, this will probably be the last sailing ship that I build, for myself, at this small of scale.  The rest of mine will most likely be at 1/72, like the Prince de Neufchatel.
Building:
