HM Cutter Cheerful 1806 by Seventynet (Ian) - FINISHED - 1:48 scale
Greetings shipmates,
I have decided, somewhat retrospectively, to show an abbreviated build log of Chuck’s Cutter Cheerful, which has been paused for the last few months while I work on other things.  I hadn’t intended to document this build because there are already so many excellent logs here. My thinking was that I’m slightly beyond the “help me” stage but not yet at the “here’s how you should do it” stage for creating a build log - putting me in limbo land.
So perhaps I can go forward with a “here’s how you shouldn’t do it” log. This will allow me to go back and examine the areas I can improve for the next Cheerful build, not to mention the possible benefit to others. But I am sorry I did not take a lot of photos.
Instructions for this build. Chuck's instructions are the best I've encountered. Read them carefully, re-read them and you will be happy.
Stage 1: Gun Ports & Planking
1.    You simply cannot be too precise with the gun port frames. I was not. I will next time. When you are talking about a 1/64th inset from the planking it is important to get the line right. I used European boxwood for these, simply because I had a piece. Harder than Castello and pinker. Sorry,no pictures.
2.    One must take the time to fair the bulkheads to perfection. While Chuck abundantly warns of this, and I had thought I’d done a decent job of it, there was one or two bulkheads near the stem on the port side that were slightly “high”. This resulted in me merrily sanding right through several planks. I replaced 4 or 5 of them (but could have done a better job of even that).
3.    The planking is thin. Of course, it is adequate if you fair the bulkheads perfectly, otherwise…
4.    The shape of the rabbet at the stem is important. If you want the planks to fit like a lock and key, take the time to shape it perfectly, it will pay off. It doesn’t take much figuring to know how to do that, just patience with a good file.
5.    Bending Castello boxwood is a truly liberating experience. Easy peasy. The first time I’ve ever used it. Absolutely beautiful wood.
6.    Learn how to read the plans properly. Forgetting that the plans represent a 3-dimensional model projected as 2-D will run you into trouble. Witness my first two planks below the wales at the stern on both sides. Too narrow. I had planked most of the hull before I woke up. So I left the whole thing as it was and somehow the rest of the planks forgave me and allowed me to end up approximately where I needed to be as I planked down the stern post. I can’t remember if I slipped an extra-wide plank in there to compensate. I think I did.
Edited by Seventynet
None
Link to comment
Share on other sites
wales and stuff
1.    Take your time with the “fancy” pieces that run from the bottom of the wales to the top of the transom. That’s really all I can say, just take your time. I didn’t and had to improvise. Pretty much concealable in the end.
2.    My approach for building the counter worked well. Sorry no construction pictures. I laminated several 1/8th inch thick pieces of boxwood edge to edge. Overlaid this prepared structure (there is one for each side) with the pencil-traced outline of the frame using Scotch’s (3M™) matte tape, cut it out, carefully manicured it and glued it into the frame. This worked better IMHO than fitting each plank into the frame.
Too many pictures that I can't figure out how to get rid of...
Link to comment
False Deck
1.       I used an 1/8th inch piece of basswood cut longitudinally. Worked well.
Link to comment
Deck Structures
I bought and assembled all of Chuck’s kits. They are well worth it. Even the windlass which I built but can only conclude was eaten by my shop vac and dumped in the garbage after my semi-annual filter clean. Sigh, I guess I’ll have to order another one from Chuck.
Link to comment
Decking
1.       I used Alaskan yellow cedar for the deck. I’d also used it for the deck on my Brazzera. It is perfect for this application.
2.      Decking layout. I would do it slightly different next time. I would let some of the bow planks close to the center plank taper so that I could end up with all of the planks except the center plank being the same width at the bow. I could have been more careful to achieve the same objective at the stern as well.
This is where I am at today. It may be a few weeks before I have any updates. I hope these are of some interest and value to those starting out.
Best Regards,
Ian
Link to comment
There is nothing wrong with your build. If it were mine I would be happy, happy. Great job.
I love the look of the Yellow Cedar decking. I use it myself for my decking.
Edited by Jim Rogers
Regards,
Jim Rogers
Damn the Torpedoes , Full speed ahead.   Adm David Farragut.
Link to comment
Hi Ian.
That one nice looking build you have going on there.
Very clean workmanship.
Planking is first class and no exceptions. Repair work looks ... I cannot see the repair..
Well done.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Link to comment
Beautiful build Ian,
the planking looks superb....
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Thanks so much for the (overly) kind words and for hitting the like button.
Jim: Thanks for the encouragement. I am intrigued by the picture of your yellow cedar deck. Where can I find your beautiful model?
Antony: Thank you. I have come up with a pretty reliable approach to removing planks by first treating the area with rubbing alcohol and then heating up the area with a heat gun (after the fumes have cleared!). The planks come off with ease. And clean up is easier too.
Much appreciated Joe. I found your Atlantis restoration project the other day. Wow is all I can say!
Thanks so much for following Niles. Love your work!
Regards,
Ian
Link to comment
You must be especially proud of how you pulled off those fixs. I sure would be! I wish I tried your alcohol heat gun trick. Mine’s planked to just below the wales. so far. I did two rip offs and always took off more than I probably needed to because the edges of some of the best planking would chip, removing the bad ones. C’est La Guerre.
Kurt
PS.  I really like how the yellow cedar looks.
Edited by Kurt Johnson
post script
Link to comment
Link to comment
Thanks for the encouragement Kurt and Don. I really would like to see more of your build Kurt. Don I wonder what you’ve been cooking up in that shipyard of yours? Any undocumented projects you’ve been holding back?:)
I cleared the Cheerful deck for action this morning :pirate41:. It feels good to be back at it.
Best Regards,
Ian
Link to comment
Ian, your workmanship is beautiful. I have this kit but don't want to start it until I can do it justice like you have. She has such great lines.
The heart is happiest when the head and the hands work together.
Al
Current Builds:
HMS Halifax 1/48 POF Lumberyard Kit
Model Shipways Glad Tidings
Acoustic Guitar Build FINISHED
Link to comment
Thanks B.E., honestly your build is absolutely beautiful and there has been more than one occasion where I had wished I was behind you so that I could have followed your lead. I have said to myself many times that I have to build another Cheerful so that I can do a better job next time.
Al thanks for the compliment. I know your work and you will do a splendid job on it. You will also enjoy it as much as I do. Chuck has put together a beauty.
Ian
Link to comment
Thanks a lot Jim. I used a flat black acrylic. I think, but not positive it is what Chuck originally recommended. However I painted over it with satin wipe on poly which makes it shine a bit more than I like.
Regards,
Ian
Link to comment
  • 2 months later...
Greetings shipmates, thanks for looking in.
I'm getting closer!
Lots of fiddly bits: transom boom holders, chainplates, posts, channels and boarding ladders, only some of which have been installed.
1328392460_channelspostsboardingladderschainplatesboomholders.thumb.JPG.254cfc611bdfcfcf6edb14ad4abe1d6f.JPG
Unassembled catheads1639389812_catheadsandposts.thumb.JPG.e67c3dd71d38fe17e757d8adf2a9f69a.JPG
Jib outhaul block:
Carronade carriage assembly line:
Carronade factory:
Trunion cap jig:
1189130239_carronadefactory1.thumb.JPG.f19f12e49844dce8128eed2b8dd12d98.JPG1042821465_carronadefactory2.thumb.JPG.c8f5c23c7dec98596fea769db4397724.JPG1330505253_barrelinsignia.thumb.JPG.1351fd546f51d43e967428753e8ab398.JPG
Eye-bolt jig:
Uninstalled carronade:
Rudder works:
2073012400_preblankenedbottomrudderhinge.thumb.JPG.4f6d6c934bb4f98421d42936139342ef.JPG
1401613343_blackenedpintelsandgudgeons.thumb.JPG.66eaac46093741df1871e0fe037510d3.JPG
Bowsprit assembly:
Current state of progress:
Link to comment
What a beautiful build Ian, did you make those carriages? I see they are in your mill vice and was wondering if that baby is getting utilized
Link to comment
Thanks Jim. I really appreciate your comment about the rim bolts. It's been bothering me since I installed them. Unfortunately I CA'd them in place so I'm not sure they will come out without too much damage. I will continue to think about them but for the time being I will leave them.
Ian
Link to comment
Hey Don, thanks for looking in. These are Chuck's mini kits. The real challenge is getting all the char off such small pieces. The rest is about building jigs to position and glue the pieces together. The mill with the DRO is a true luxury. It allowed me to reproducibly position the drill holes for each carriage piece, amongst a million other beneficial uses.
Ian
Link to comment
Hey Chuck, what's really exceptional is this model, your kits and instructions! A real pleasure to build.
Thanks but no B.E., this one is promised to my brother. Anyway remember all those treenails...I took the easy way out.😏
Ian
Link to comment
Ian the make a product called Uncure for removing CA attached parts. It works well. Just put on a few drops and let it set for about 30 seconds and the part should pull right out.
Your Build is coming along greatly.
Regards,
Jim Rogers
Link to comment
Thanks Jim. Looks like I can get it locally. I would expect it’s mostly acetone which I’ve used on occasion. But since I use CA a lot in making pens and using it almost exclusively as a finish it’s definitly worth a try.
Ian
Link to comment
Greetings,
So here is where I'm at now. Pretty much everything is done in preparation for making and installing the mast, spars and rigging.
First I want to give you the results of my pseudo-scientific experiment on which glues to apply to bind already painted (poly) wood surfaces. This has always been a question in my mind. Do I need to scrape/sand surfaces to bare wood before I apply PVA with all the attendant problems associated with that operation, or can I just apply PVA or some other glue and hope for the best?
So I tested epoxy, PVA and CA on boxwood carriage trucks glued to yellow cedar to simulate gluing the carriages to the deck.  Both received poly treatment and were allowed to dry for several days. I then applied the glues and let them set for 24 hours. I hung weights to the wheels using a bent steel rod attached to magnets and various pieces of steel for deadweight. The PVA let go before I reached 2 lbs, which is not insignificant to me anyway. I proceeded to load up the other two to 5 lbs and they still held on! So eschewing the harder to prepare epoxy I went with CA to anchor the carriages to the deck.
Rudder assembly cleaned up a bit:
Winch and handles completed:
Bow assemblies:
Carronade close-up:
Wide view of deck:
Thanks for looking in.
Ian
Link to comment
Ian, very well executed. The ship is really looking nice.
Able bodied seaman, subject to the requirements of the service.
"I may very well sink, but I'm damned if I'll Strike!" JPJ
My Pacific Northwest Discovery Series:
On the slipways in the lumberyard
Union, 1792 - 1:48 scale - POF Scratch build
18th Century Longboat - circa 1790 as used in the PNW fur trade - FINISHED
Future Builds (Wish List)
Columbia Redidiva, 1787
HM Armed Tender Chatham, 1788
HMS Discovery, 1789 Captain Vancouver
Santiago, 1775 - Spanish Frigate of Explorer Bruno de Hezeta
Lady Washington, 1787 - Original Sloop Rig
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
