6 minutes ago, cog said:
Quite an improvement OC. Hope your rattlecan turns up soon
I have it now mate, it turned up in the post today,  I just need to find a way of holding the sub that gives me an easy way of spraying it with the rattle can.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
1 hour ago, cog said:
bluetack, two small dots on the bottom with some thin wooden sticks in it
Yep  I have done similar - the top of the sail is open at the moment, so I managed to find one of my brushes where the handle fitted inside with a quite tight fit, I ran some gaitor pva down inside around the handle, with any luck it will hold the brush handle enough tomorrow  so I can hold it to spray with.
Then when dry I should be able to cut away the handle to allow the top of the sail to be fitted.
OC.
Edited by Old Collingwood
Current builds
Completed works.
20 minutes ago, cog said:
That's a better way OC
Time will tell tomorrow.
OC.
Current builds
Completed works.
the sail {as you call it} is called the conning tower.    the periscope,  communications,  and main hatch are located here.   on some subs,  some form of armament would be located there as well.   I'm sure there will be a deck gun somewhere fore or aft of the conning tower........I'm not sure if there are hatches on the deck,  but those you put on are likely missile tubes {not usually that close to the conning tower though}.   Piet knows more than I do........I'm sure he'll be along soon and can fill you in better.  Kevin could as well.   glad to see your on the move again :)
Edited by popeye the sailor
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
look outs on the bridge will carry SLR or possibly SMG to protect the ships company at times like hands to bathe, or when passing through close narrow strips of water like the suez canal
HMS Andrew was the last British sub to be fitted with a deck gun but only for the indonesia-malaysia troubles in 1964
Edited by Kevin
Evening everyone,   here are the pics as requested  -
The spraying went quite well  I think.
OC.
Current builds
Completed works.
8 minutes ago, CDW said:
Oh, that looks real good! I like it.
Thanks mate.
OC.
Current builds
Completed works.
9 minutes ago, cog said:
Now it really is a production line cigar tube ... You picked up spraying rather well OC .. a sterady hand, I like the result ... a lot
Thanks carl,    spraying it was so easy  and clean.
OC.
Current builds
Completed works.
Run silent, run deep seems fit what I see.   Great looking paint, OC.
Boy I go away for a couple of days into the wilderness where civilization has yet to touch and you start building a new sub! What happened to the British moss covered gray thing that was looking for batteries?:rolleyes:
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Thank you sincerely mark,   she does have a more stealthy look to her now.
OC.
Current builds
Completed works.
Hiya mate  hope you and yours are well, wondered where you had gone,   thought my singing had put you off:o
I decided to give her a complete makeover, she has had a refit and new lick of paint and shortly ready to go back into service.
OC.
Current builds
Completed works.
Unless you sing like my oldest son who could not carry a tune if his life depended on it. He ended up playing drums instead. Even did it professionally off and on and until he moved was playing a few times a year in a couple of clubs and contests with a few other doctors who made up a band in their spare time. Luckily being a doctor doesn't require having a singing voice.
Anything above that level of singing i can put up with for at least short times. If you go beyond that I will just turn down the volume on my keyboard!:huh::D
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
18 minutes ago, CDW said:
Haven't heard OC's singing voice yet, so couldn't say with any certainty I like or dislike it. But I do like his latest paint job.
Maybe you need to record a singing audition for us, OC, and post it here. I double-dog dare 'ya.
I wont scare anyone - so I will relent from singing,  I used to be in a band in the 80s  but thats another story.
OC.
Current builds
Completed works.
Right  - more work on the sub this afternoon,  I masked and re painted the top anti-slip black paintwork,   then I turned my attention to the sail/conning tower top section, this has multiple devices - periscope etc, theres were cut from the spue  and cleaned up before placing in thier respective positions, I also painted the inside white as this will be seen from the top.
Here are a couple of pics  (taken with my phone camera as I do not have a close up lens on my dslr)
OC.
Current builds
Completed works.
3 minutes ago, cog said:
Nice, although, I have the distinct impression that some of the trees in that wood are a lot thinner than provided in the kit ...?
I thought the same  - I might try an take a couple of them away, and thin the rest a bit with a sanding stick.
OC.
Current builds
Completed works.
2 hours ago, cog said:
My favorite instrument ...
I used to be a keyboard player and still record using VST  digital  equipment.
OC.
Current builds
Completed works.
