49 minutes ago, RGL said:
The build is on here
I spent a little while looking but couldn't find it. I'll possibly try again tomorrow when I have a little more time.
51 minutes ago, RGL said:
I just don’t want to spend a decade on one.
I know what you mean there as well. It was just a question on which you got more ultimate satisfaction from in the finished project.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Those are the metal stanchions from Tamiya? You really pick a nice sizable object for that kind of work ... to keep your fingers in shape and pretty much flexible? ... she does look good, even without those pesky posts ... but "a man's gotta do, what a man's gotta do" ... I think I'll stay in the whimp corner ... I am better suited for that ... messed up the hull of the big one the day before Yesterday ... since humidity has risen and temperatures dropped, paint dries slowly ... I had some lovely runners ... back to stage one ... sanding/priming/sanding/priming/..., so I am of by miles when it comes to stanchions ...
Carl
I find that working on fine details has to be done in short bursts. Try building Z scale (1/220) structures or N scale (1/160) double hung windows. <Remind me not to do those ever again!>  Do one operation at a time (glaze a window, say) and do 2-4 operations. Then walk away; maybe work on something you can see without using your optical enhancers. You won't get done in a hurry, but what's the fun in that? :D Like Greg said, sometimes you feel you're plodding along.  I've been rolling brass HO scale piping clamps for a grain hopper. The detail set gave me more than enough and happily none have been launched into Never-never Land. Having good pliers of the correct size helps there, too. 👍
Ken
Started: MS Bounty Longboat,
Quote
Thanks Greg.
I guess I saw it after all, just didn't know your full name. You now know what I will be doing for at least part of today.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
catching up on your endeavors Greg........she is one fantastic model :)   there is so much detail,  and your paint skill is off the charts!  very nice that you were able to do the color layering on the gun barrels.....how did you mask them without getting the paint lines?  nice work on the camo as well  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
So I tried a new technique today. First, get a mouthful of black coffee. Second sneeze. Third, direct sneeze over the ship. Drench it in coffee.
FFS! 20 minutes with a paintbrush and water to clean it up. The deck does not like it but I think I’m on to something here when it comes to dulling down the wooden decks! Who knew!
Anyways, the back end of the ship’s railing is now done. I added a little bit of unpainted PE for comparison and I like it better the way I’m doing it. I just don’t think I can go back to PE railing again for this type of ship’s rails.
Greg
I couldn't do it - not even close,  I have poor enough eyesight as it is need glasses for almost everything and deffo stronger ones for bookwork.laptop  building etc,  then I have my magnifier under a powerful light just to do my build.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Dull down the wooden deck ... more like coffee it up!
I wouldn't be spraying coffee all over it, but get some different shades of pastels from light wood to dark and work that in with a hard bristled brush with a straight end instead of pointed, and work it in gradually. I bought an "artists" set of pastels (12 colours), and used those on the G class destroyer's decks. On a wooden deck I would have to get a few additional colours, as sets are quite limited with respect to a modeller's needs.
those tri-coloured barrels look marvelous on that dark blue turret
Edited by cog
Carl
I've seen most chalks and pastels disappear when spraying a fixative over them.  Started using something called Pan Pastels, which can be applied with a variety of tools (brushes, sponges, etc.) No fixative required. Here's a link: http://www.modelingcolors.com/index.html
They do list some European outlets. Nothing for Oz or Japan.
Ken
Pastels and pigments work fine on paint, just not the cellulose deck materials as the definition disappears. It is what it is BUT! The coffee sneeze leads me to believe I’m onto something that I’m going to have to work on.
I really dont don’t want to weather this deck, asehen you look at the KGV photos from the Med in 1943 it is spotless as would be expected of the Kings ship.
Greg
Well that’s the worst part of the build done. The stanchions are white as I gave them a base primer coat from the Tamiya rattle can before putting them on, as another coat would plug up the holes. When I do the touch up phase I will make sure they are all strait and paint them.
The Anchors are resin ones from North Star Models as the kit ones are utter rubbish. There are only two as no reference I can see has her with three after 1940.
Edited by RGL
Greg
superb bit of progress there Greg........the stanchions look super :)    they look much better than PE....more life like.   I've done that before.......given my projects coffee baths.......not only that,  I'm sneeze prone  :D  {try explaining that one  ;) } .    some do stain their decks......light stains,  coffee's a new one on me.   looks like you did a decent job of cleaning her up.   she looks great :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Just about finished, flags, screws and davits done. Unfortunately the Walrus was located on the floor of my study today destroyed. I have plenty of them but no PE for them. I’ll have to order some.
Just some hull weathering to do.
Greg
I like the camouflage giving the ship strange angles when you look at those frontal pictures, a busy deck and lots of things to see. So much more pleasant to look at than those boaring modern ships ...
Vendetta is already relatively small compared to the G/Tribal class desroyer I built, so this doesn't surprise me, next to the Yamato class she would be even more like a ship's boat ... but so much more agile one shouldn't forget ...
P.s. what's that French title about ...?
Carl
4 hours ago, RGL said:
Just look at the photos really, if I lived to be 500 I’d never be that good.
No, but you can aspire to ... On the other hand ... when I look at what you establish with some plastic, brass, glue and paint ... a lot would think the same about you ...
Carl
I agree with Carl and Ken.
Your work is every bit in par with any museum ship I have ever seen. Possibly I only go to low quality museums but I don't think that is the case.
You have to remember that the pictures in the books are all taken with perfect light and professional photographers and like the pictures in Playboy are probably touched up as well.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
