Thank you for answering Vladimir. will google it. im quite stunned by speed and constant unshakable precision in evety segment wow. thanks for having you here its quite an inspiration. top threshold indeed.  looking forward & enjoying enormously.
V.
Thank you all for the very positive responses, they are embarrassing me a bit.:rolleyes:
To dvm27: It is not an exact copy of real splice. The ends of the rope are cut to a length of approx. 2 - 5 mm (depending on the size of the ceiling), the number of threads is then reduced by half on each side. Subsequently, the ends of the ropes are connected to each other and with the help of PVA and fingers, a connection is made. Finally, wrapping is done on the joint thus formed. So even if it's fake, the result doesn't look bad.
The first photo of strings weighted with nuts I thought what is that, then I saw how it became a woven mouse that would be the envy of a full size ship. The simple but perfect jig for aligning deadeyes that never occurred to me. The precision of the seizings and splices, the quality of the blocks. Wow, the creative mind and master skill displayed with this model. Incredible. Which museum gets the completed work?
Edited by glbarlow
Regards,
Glenn
Current Build: HM Flirt
