Glad I have just found your log before you have got too far Valeriy, love this style of model.  Making all of the metal parts must be so time consuming and sadly I'm not familiar with the techniques so looking to be educate by you.  I can't even imagine the amount of work you have ahead of you...but it will be worth it.
Cheers,
Jason
In the shipyard:
Hey Jason. Thanks for the kind words. I will be happy to help you with my experience. :)
Deck on forecastle.
Valeriy,
wonderful brass metal work, and joining into the hull, it looks top !!
Nils
Current builds
-Lightship Elbe 1
Completed
2 hours ago, cotrecerf said:
Hello Valeriy,
wow, fantastic work! Varyag is of the same period and style as a future project I am planning to build: German Gun Boat Iltis II stationary  of Tsing Tau in 1900.
Looking forward to learning of the progress of your Cruiser.
Joachim
Hello Joachim!
I would be glad if you join. We will build models together and then there will be more metal ships on the forum.  Iltis II  interesting and original ship.
very nice progress!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Valeriy,
I was already wondering if you would bring metal plating on to the hull. Now the surprise with liquid putty and masking tape. The result is fantastic, well done, thanks for sharing your methode here....
Nils
Current builds
-Lightship Elbe 1
Completed
2 hours ago, mmdd said:
Valeriy V  There are very few metal ships on the forum. I will try to add a little
in my opinion  metal ships are something like
You are a little wrong. I wrote about metal SHIPS.   You wrote about the metal MODELS of ships. Perhaps the reason for this error is my bad English.  :)
59 minutes ago, Mirabell61 said:
Hi Valeriy,
Nils
Hi, Nils!
Thanks for the feedback. This method has long been used by ship modelers from the former Soviet Union.
Thanks for your feedback comment Valeriy,
is there perhaps a way of resembling rivet heads and vertical joints on the model, and in combination with that method, if the belt strakes were not welded ?  I trust in your case  scale 1:75 may allow visible (flattened) rivets, they would not be too dominant in that case.
Nils
Current builds
-Lightship Elbe 1
Completed
47 minutes ago, mmdd said:
Valeriy V You are a little wrong. I wrote about metal SHIPS
Two examples of metal SHIPS (iron-hulled)
James Craig launched 1874
Rickmer Rickmers launched 1896
Valeriy V  Perhaps the reason for this error is my bad English
маєте рацію - гарна допомога The Oxford Companion to Ships and the Sea (Peter Kemp, Oxford University Press).
Thank you, mmdd. I will use your help.
Nils
Good question, Nils! :)
Here is the table of the German Lloyd, the diameters of the rivets, depending on the thickness of the sheet. Probably, the data of English Lloyd are not very different. It turns out that the size of the heads of the rivets in the range of 15-45 mm.
In my opinion, showing the size of the heads of rivets on a scale of   1: 100    1:75 does not make sense. If the diameter of the rivet heads is shown correctly, they become almost invisible by 0.15-0.6 mm.
On Varyag all the heads of the rivets were not visible, option "C".
Nils
I cut the vertical joints on the hull of the boat with a sharp knife blade along the ruler.
Thanks for explaining Valeriy,
yes, it makes sence with Option "C" type used on Varyag and rivet-heads sunk and flush with plates and overpainted anyhow....
Nils
Current builds
-Lightship Elbe 1
Completed
Nils
Nils,  you can try to show the head of the rivet with a tube of the desired diameter with sharp edges. But an experiment is needed.
Thanks Valeriy.
 good idea with with a sharp edged tube....., I tried it once by using injection needles (due to the mini diameter) for this purpose, but the application worked out too messy...
Nils
Current builds
-Lightship Elbe 1
Completed
