I go away for a couple of weeks and find out that you've had to make a major save, Toni. Isn't it amazing what we can sometimes miss? Glad it was fixable!
Danny, scary that we had the same issue.  After I discovered the problem I simply walked away and did nothing on her until the next day.  Of course, then you are second guessing yourself.  I remeasured both sides bow to stern and found no other issues other than a slight rise at the stem, which will be dealt with when I frame the forecastle deck.
Well, Druxey, I guess you simply can never go on holiday again!
Toni
Member IPMS
                           Utrecht-1742
Now that I was happy with the elevation of the quarter deck clamp, it was time to finish the quarter deck transom.  The middle and inner counter timbers fit into slots on the aft end of the transom.  The slot has to be cut at an angle fore and aft as well at side to side because of the shape and slope of the counter timber.
The upper face of the transom is shaped to the curve of the quarter deck beams.  A rabbet is cut into the fore end to accept the deck planking.  The extensions on the ends of the transom are for the waterways.  Everything was going well until I discovered that I had cut the top of the transom too thin.  Luckily, I cut the rabbet to the correct thickness and so added a thin layer of wood to build up the aft portion of the transom.  This line can be seen looking from the stern but will be covered up by the stern planking.  The last two pictures show everything glued up and brass bolts inserted into the feet of the counter timbers.  I will touch-up these bolts with black paint after final sanding.
Toni
Member IPMS
                           Utrecht-1742
Good going, Toni: but the starboard end of the transom seems higher than the port end. Compare it with the wing transom: or is it the angle of the photo?
Druxey, thank you for your astute observation.  When I saw the photo I went back and measured everything...again.  The angle of the photo is part of the problem; the difference is actually barely noticeable. The position of the quarter deck transom is correct.  The starboard end of the wing transom is lower than the port, giving the illusion that the quarter deck transom is uneven.
Toni
Member IPMS
                           Utrecht-1742
How many times over the years has Murphy's Law been around in this hobby.  As a result we always have to look over our shoulder and double check everything to make sure he is not around.  When my nephews were still in elementary school one of them brought me a kit of a Pt109.  Nice kit for the time and asked me to help him build it.  I spent the next few weeks of vacation helping him out.  Murphy showed up when I was not looking.  I was showing him how to detail with a brush and left the room.  I came back and he had switched from a bottle of testors enamel to their bottle of liquid glue.  Needless to say I am not sure whose face was more surprised his or mine.  When you are 7yrs old it is all a game. :o
David B
I have a scintilla of doubt, Toni: could it be that the model is leaning slightly to starboard on its baseboard? Sorry to be OCD about it! I'll shut up now.
Edited by druxey
Druxey, I think we are all at least a little OCD if we participate in this hobby.  I went back and remeasured everything again.  It appears the last time I corrected the elevation the pieces shifted when I clamped them.  So I unglued everything, remade the aft starboard deck clamps and rebuilt it yesterday.  To prevent the same problem from happening again I glued the quarter deck transom in place and then added the deck clamp after the transom was secured.  No pictures yet, but I am much happier with the results.  I appreciate you and everyone who alerts me to problems.  As you know, when one looks at something for a long time you stop seeing the problems until they are pointed out.
Toni
Member IPMS
                           Utrecht-1742
Next on the agenda is the helm port.  I worked on this while the stern was being rebuilt  so the corrections will not be evident until the next posting.
The helm port is a opening in the counter to allow the rudder to pass into the ship.  It needs to be large enough to accommodate the rotation of the rudder.  It is comprised of three pieces, two side pieces and a chock and in construction is very similar to the bowsprit chock.  (Loosely translated as a right royal pain in the stern.)  At first glance you would say "two straight pieces and a chock, what's so hard about that?"  The straight edges' lateral pieces are cut an an angle to match the taper of the sternpost and the cant of the inner counter timbers.  Once that is set, the chock was started. The chock not only has the same side angles as the lateral pieces, but must also lock into their top edge.  After I was happy with the fit, I traced the curvature of the inner counter timbers onto the over-sized pieces and sanded in the top and bottom curvature off the model with a Dremel.  The opening in the helm port is perpendicular to the water line.  The aft end of the chock was left rough at this point and will be finished when the knuckles of the counter are shaped.
Edited by tlevine
Toni
Member IPMS
                           Utrecht-1742
Toni? This might sound like a silly question but I have to know.  Are you working from a template that you drew up or are you freehanding?  If freehanding you have more courage than I.
David B
David, I made a template of the space between the inner counter timbers to give a general outline for the piece of wood to cut.  Next, I sized the piece to fill the entire space between the timbers, cutting the opening for the stern timber.   I made sure the wood was thick enough to accommodate the inner and outer curvatures.  The opening for the rudder was drawn on the piece as were the cuts for intersection with the chock.  After cutting away everything aft of this point I was able to make the hole for the rudder and install the side pieces. The chock was formed by careful fitting and refitting and refitting.
Toni
Member IPMS
                           Utrecht-1742
Indeed a tricky set of parts, but they came out really nice.
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
A belated thank you Remco.  And thank you everyone for the likes.
A little progress has been made.  In order to fit the counter planks the ship had to be "launched" from its building board. This marks the first time I have removed it from its home since fairing the exterior of the hull over a year ago.  No champagne was wasted in the launching but I did toast it with a little homebrewed IPA.  I have also done a little more fairing of the lower transoms and cut off the aft ends of the ribbands.
The lower counter was covered with five rows of planks.  These are cut to shape rather than attempting to edge-bend them. The planking started next to the stern post and progressed outwards.  The exact shape of the cut-out on the outermost plank will await fabrication of the rudder.
There are a few points in every build where decisions need to be made which will impact everything else going forward.  I am at one of those points.  I have decided to attack at least some of the hull planking next.  The decisions to make are: how much to plank, what materials to use and what finish to apply.  I will be leaving the starboard side with ribbands and hairpins.  The port side will be completely planked.  The main wales will be castillo that will be colored black.  I made test pieces using india ink, archival marker, ebony stain (oil and water based) and paint.  Ink is very messy but dyes the wood well.  I found the archival marker too time consuming but it does a good job of dying the wood.  Regular marker will bleed with oil based finishes.  The castillo is to dense to take up stain readily.  I have opted to paint the wale black with Poly S model railroad color Engine Black.  I used this same approach with Hannah.  I am still uncertain about the rest of the planking.  It boils down to aesthetics...  Two colors vs. several.  I am leaning towards only two colors but I'm a girl so I have the right to change my mind at any time. :rolleyes:
I measured the top and bottom of the wale from the plans and marked the points on the hull.  I then ran a row of pin striping tape above and below these points and faired them to a smooth run of planking.
Toni
Member IPMS
                           Utrecht-1742
It sounds promising, Toni.  I like the choices in wood although I'm partial to swiss pear on the planking.  :)
Mark, although I like the look of unsteamed pear, I find swiss pear too pink for my taste.  I am going to cut some planks of pear, holly and pau marfin (in addition to costello) and see what I like best.  David, I didn't say the paint was bought recently ;).  It is left over from my Victory build so it must be at least 10 years old.
Toni
Member IPMS
                           Utrecht-1742
Hi Toni, Amazing work , very impressive . she looks fantastic
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Thanks, Pete.  Mike and Ben, I will make my final selections in the next few weeks.  The first order of business will be to install the wales.
Toni
Member IPMS
                           Utrecht-1742
It has been a while since I have posted anything new...but I have an excuse.  I was performing nautical research in the Tetons and Yellowstone.  For you non-US folks, these are two national parks adjacent to each other in the Rocky Mountains.  First I had to research the types of water craft used on Jackson Lake.  This photo was taken from our campsite.
We had rain and so drove up to Yellowstone.  We had never seen Old Faithful and decided to act like tourists.
There is a lovely grand hotel called the Yellowstone Inn that overlooks the geyser.  It was built by the railroad in the '20's to promote travel in the West (which had to occur via rail since there were few passable roads).  Walking back to the car I looked up under the eaves and saw...compass timbers!
So much for the nautical research.  The rest of the time was spent hiking and enjoying a phenomenal wildflower display.
Toni
Member IPMS
                           Utrecht-1742
Looks like a wonderful "research" trip Toni.  Thanks for sharing the photos.
A breath of fresh air and a chance to unwind and enjoy god's beauty is a must for all.  I am glad you had a great time Toni.
David B
Thanks everyone.  The first strake of the main wale has been installed.  I hope to finish it over the weekend.  Pictures forthcoming.
Toni
Member IPMS
                           Utrecht-1742
Excellent research.  I have a mental image of you dickering with the desk clerk and manager about buying one of those compass timbers. :)
