Germania Nova 1911 by KeithAug - FINISHED - Scale 1:36 - replica of schooner Germania 1908
Im getting annoyed with myself that i am not finishing off this build, but thanks to everyone for sticking with me. I suppose that I was having and aversion to fixing mistakes but this weekend I managed to overcome my prevarication and fixed the problem.
As I previously said the upper fore mast back stay had been rigged as a fixed stay. During a discussion on the complexity of tacking the fisherman it became obvious that I should have fitted a pair of running back stays with only the windward stay taking the load. Although I hadn't fitted a fisherman the change was made necessary by the nagging voice in my head. The change necessitated the production of 5 more twin blocks (one of which I managed to misplace).
I found the 5th after a half hour hunt!!!!!!!!!!
The fixed stay was removed and replaced by a pair of back stays wrapped around the upper fore mast,
The pair were led to the twin block mounted high on the main mast.
I had to remove a couple of deck hard points to mount the blocks - luckily they were glued in with CA and came free neatly with the application of a soldering iron. See hole next to the uppermost hand wheel. I managed to knock the hand wheel off (its smaller than it looks) and spent a good hour getting it back on - idiot!!!
IMG_0370.thumb.jpeg.5aa0fd73113797db803ec202248ea2bf.jpegIMG_0355.thumb.jpeg.1981ac1047377f4316eab4c1084b17e4.jpeg
Rigging the blocks was the easy bit - but just twice ad difficult as it would have been had it got it right in the first place.
It now feels fixed but most people won't notice.
I also made some progress on the flags but dinner is ready so that will have to wait until next time.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Share on other sites
Nicely fixed, Keith. It's annoying enough having to re-do things inside a maze of obstacles, but misplacing a block as well.... Anyway, well done.
Link to comment
Nice job on the alterations. Glad to see that you were able to locate your missing block assembly. Nothing more frustrating than having to re-do work.
How right you are, finishing up a build is a lot harder than it seems. I still look back at my previous ones and think, I need add a little bit of this and that, or a tweak here and an adjustment there.
-Brian
Current Builds:        Completed Builds:
Mississippi River Towboat Caroline N.                                                    HMB Endeavor: Artesania Latina
        USS Constitution - Cross Section: Mamoli
Non-Ship Builds:        HMS Victory - Cross Section: Corel
New Shipyard        King of the Mississippi - Steamboat: Artesania Latina
        Battle Station Section: Panart (Gallery)
In Dry-dock        Chaperon - 1884 Steamer: Model Shipways
USS Constellation: Aretesania Latina                                                       USS Cairo - 1862 Ironclad: Scratch Build
Flying Fish: Model Shipways
Link to comment
Kieth,
Your work is beautiful!
But I don't understand why you ran the two backstays through the double block on the main mast. That seems to me to defeat the purpose of the two backstays. The geometry is all wrong.
As you have it rigged it having two stays is no different than one. Both create the same triangle aligned along the centerline with the main mast. There is no support for the transverse forces acting on the mast, and that is the purpose of the stays.
The idea behind running backstays is that the two stays lead to opposite sides of the vessel, creating a triangle on each side to support the mast and take the strain of the sail. The downwind stay is slacked to avoid interference with the gaff sail, and the upwind stay is tightened to take the strain on the mast.
Shouldn't each stay end in a luff tackle belayed to a point on deck close to the bulwark, port and starboard?
Link to comment
Phil,
I probably didn't explain it well enough.
When rigged the fishermans sail is hoisted between the two stays and the downwind stay is loosened to allow the sail to take the correct shape. With the fisherman set only one back stay is bracing the fore top mast at any one time. Because I have not installed the fisherman I have tightened both back stays. When tightened the load path is from the top of the fore top mast to the top of the main mast. The majority of the load is then transmitted to the deck via the main mast back stays. The blocks tightening the twin fore top mast back stays are split on to port and starboard beams.
Thank you Druxey and Brian for commenting.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Kieth,
Thanks for the explanation. This arrangement is new to me (as are a lot of things about schooner rigging).
I understand why the leeward stay was slacked to allow the sail to catch the wind. And I see how your stays function as a backstay to transfer forces to the mainmast top. Marquardt (The Global Schooner, Naval Institute Press, Annapolis, Maryland, U.S.A., 2003, page 179) describes your fore and aft running stay that leads from the fore topmast down to the main masthead and then to the deck as a "schooner stay." However he seems to be talking about a stay the runs from the fore mast top to the main mast top, and not from a point near the top of the fore topmast.
I was thinking of the running backstays used on some schooners where the stays were secured to points behind the mast and outboard at the bulwark. In this way the stay took not only the strain from the forward forces on the mast, but also some of the lateral forces.
The stays usually had a tackle (luff tackle or gun tackle) at the bottom end. The windward stay was belayed to a point outboard and aft of the mast, and the tackle drawn tight to take the strain. The leeward stay tackle was slackened and the tackle moved forward to a point outboard the mast. This allowed the gaff sail boom to swing wide outboard on the downwind side to catch the wind.
Link to comment
Hi Keith,
I like your design of the stand, very nice idea.....
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Once again thank you all for your continued interest.
I finally finished the outstanding bits but as yet haven't taken a comprehensive set of completion photos. Here are the final bits of the build and a few photos.
The burgee carries the owners flag. This contains of the boats name stars and a swallow. I made this up at A4 scale using powerpoint. The swallow was drawn freehand, pricked out on a piece of card out out and glued on. As the burgee was being reduced down to about 1/4 x 3/8 inch I wasn't too worried about the pin holes.IMG_0350.thumb.jpeg.a60ff082fc1823301d40a9b98e55699d.jpeg
The pig stick was made out of brass wire.
It was then hoisted on the fore top sail.
The ensign was then made from paper. This was printed in two operations with the paper flipped over and aligned to get the two images perfectly symmetrical. I may make it again with thinner paper but for the moment it will suffice. The paper was bent round a pencil to get it to hang as if their was a very gently breeze. as you can see from the ensign the boat is registered in a "port of convenience".
I then tried a few shots of the deck but was dissatisfied with the general builders dust over the deck surfaces. This curtaiedl my photography efforts but i did take one shot peeking through the open door of the deckhouse. I will clean the model and then take more shots before posing them over the next few weeks.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Its only when close up shots appear that you begin to appreciate the level of detail and complexity of this tremendous model. have you kept a log of the hours invested so far? Looking forward to the gallery shots!
Andy
'You're gonna need a bigger boat!'
Completed Build: Orca from the film 'Jaws'.
Current Build: Sailing Trawler Vigilance BM76
Link to comment
Your Germania comes as close to perfect as any model i've had the pleasure to view. Keith, thank you for allowing us to journey with you on your build. I've enjoyed every post and have been inspired by all. Congratulations!
Link to comment
Absolutely amazing details Keith! What a fantastic journey it has been following along. Can’t wait to see what the future holds for your next project.
-Brian
Link to comment
Just a wonderful model Keith and a testimony to your efforts and talent.  I'm looking forward to the gallery photos and also your next model.
Link to comment
Excellent work Keith. Quite the journey on this build lots to absorb.
Michael
Link to comment
What an outstanding model Keith; it has been a true pleasure to watch you bring her along.  She is a testament to your skills.
cheers
Pat
Link to comment
Keith, perhaps you should put a cheap tablet or something like that to the model that shows images of the path and also images of those things inside that are barely visible?
Otherwise, I can only echo, what the others have already said 👍
Link to comment
Eberhard - I sort of had a similar thought. I was wondering about getting a name plaque made that includes the web address of this build log and maybe even a QR code. This begs the question about the longevity of MSW or maybe even the internet. I wonder what the shelf life will be of internet information - possibly longer than a tablet.
Andy - sadly not, I think I would be alarmed!!!!!
Thank you Brian.
Brian / Mark - I think I am well on the way to amassing enough information to attempt Cangarda. 1:48 or 1:36 scale would be sensible but I am wondering about the non sensible scale of 1:24.
Andy Druxey, Keith, Brian, Rick, Mark, Michael, Richard, Pat, Roger, Eberhard - Thank you all for your comments and also thanks to all of you that have contributed to and like the build over past 4 years.
Just think it, 4 years older and according to my wife not an hour better!
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
 I can't wait, a pretty lass with steam power to boot.
Link to comment
1 minute ago, Roger Pellett said:
 You better check ceiling heights before deciding on a scale!
 It'll be the floor model. :)
Link to comment
Half-cut away model showing a (non-working) scale steam-engine and boilers?
These old steam-yachts are a lovely, steam-punky sort of crowd ... some years ago, we happend to be in Nice, when a childhood friend of my wife called her to wish her 'Happy Birthday'. When she asked, where he was, he said "in Nice" (he works on 'super-yachts' as an IT engineer). When we asked, where to find him, he replied "that's easy, just look out for the biggest boat in the old harbour, where normally cruise-ships berth". However, in spite of the 'glitz', helicopter and all, I found the old 1920s steam-yacht on the other side of harbour much more classy and desirable ...
Edited by wefalck
Link to comment
I will definitely following along on that beauty! Looks like fun, can't wait.
1:24 *cough *cough....😁
-Brian
Link to comment
Keith, thanks for taking the time to share this remarkable build with all of us. There was so much great information, particularly the metalworking, that taught us all a lot. A wonderful accomplishment!
On to Cangarda! I'd expect she'll be an easier build, given the simpler rigging and less deck hardware, unless you decide to do a cut-away and depict below decks and the engine room. In that case, probably twice the work, at least! :D
Or... how about a working steam-powered pond model?
送料無料 斎藤製作所 SAITO モデル スチーム エンジン MODEL STEAM ENGINE T3DR - 【クリアランスセール】 - active-sports.main.jp
ages of sail - Contact Us
Edited by Bob Cleek
Link to comment
Bob - many years ago I built a pond model which in the end I never sailed because I was wary of it getting damaged. Ever since I have focused on display models.
I am planning to represent some of the engine room and other below deck areas in so far as as they can be seen through the skylights. One of the reasons for considering the 1:24 scale is that I can do a much more accurate job of the deck house interiors.
The deck and rigging complication is that they are the areas where I have the minimum of detail. In due course I may be putting out a plea to MSW members for any photographs they may have.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Great subject for a build - especially if you can take the wife cruising in it.
Andy
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
