Richard
I just enjoyed reading your blog all the way through. I appreciate all the little things I learned along the way.   It is wonderful when folks with your skill show us trick.......your set up for soldering such little pieces. It is so much about how does one hold things in place.    After building my Bluenose at 1:24 ,where one can actually hold onto things, it is a marvel that you keep andeven expand on the detail at this small scale
congrats on a great build and thank you for sharing.
jon
On 2/8/2020 at 10:41 AM, KeithAug said:
Me too Richard - in 1969 / 1970, in my mind it's not that long ago, it's in my body that I notice the years.
My Apprenticeship was from 74 to 79 in Poole Dorset and totally agreed with your statement 😄
On 2/9/2020 at 10:54 PM, The Lazy Saint said:
Well done Richard, you are making a fantastic job of you Bluenose, it is very inspiring indeed. Thanks for sharing it with us.
Best wishes as always,
The Lazy Saint.
Do appreciate your kind words Lazy Saint I am thoroughly enjoying myself building this great Canadian schooner
12 hours ago, Jond said:
Richard
I just enjoyed reading your blog all the way through. I appreciate all the little things I learned along the way.   It is wonderful when folks with your skill show us trick.......your set up for soldering such little pieces. It is so much about how does one hold things in place.    After building my Bluenose at 1:24 ,where one can actually hold onto things, it is a marvel that you keep and even expand on the detail at this small scale
jon
Thanks very much for looking at my blog I hope I can help other modelers, I have looked at other modelers builds and it sure has helped me, you are correct regarding how you must hold pieces to solder you cannot have them moving at all if you want to solder multi pieces together, I do like making the small scale I always am thinking how am I going to make the pieces 🙂
Again thanks for your posts
Regards
Richard
Changed the height of the catheads now they look like the drawing I must have not divided by two :huh:
Made a stand which helped me hold the model while I painting the hull black
Now started to look at the cabin and this is what they give for details
Started by making a jig to match the inside of the coaming so that I could build sides of the model, this had to be made with the concaved shape stern to bow and convex starboard to port
Then took the shape to make the outside coaming which was the same as shape which is on the model
With this I can start making the sides
Took a piece of 1/8" square boxwood and machined flats as per corner detail
Then cut some planks four for each side height took off drawing put them in a bend jig used the male jig to know what the bend was and put a dab of CA to hold
Cut planks which were glue to length and also the 1/8" square corner pieces mounted in the female jig and got the shape I wanted
Check to see if ok with coaming
So this all worked great and have four sides glued and at the same time I added 1/8" square boxwood all around the top
Regards
Richard
Just stunning.   Another one of those "God I hope to get there one day..." builds.      Really, really nice.
6 hours ago, mugje said:
really, really beautiful! It is a joy to look at!
The Bluenose was a beautiful ship and I am trying to capture her look thanks Mugje
1 hour ago, The Lazy Saint said:
I totally agree mugje.
The Lazy Saint.
Thanks again Lazy Saint forgot to say I added some beams across the top for roof support
Until next time
Regards
Richard
Richard,
Beyond so envying your skills :imNotWorthy: I can now also dream about having a shipyard as perfect as yours. lol
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Beautifully crisp and clean work Richard. I love the attention to detail.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
8 hours ago, md1400cs said:
Richard,
Hi Michael I was taught how to use machines and how to fit by just using a hacksaw and then file and had to be made to thousands of an inch in my first year as an apprentice  at a technical collage, and the teacher would check our work with a vernier and if we were out he would chuck it in the bin, I tried not to have anything chucked in the bin :D
Found a house here on the Island with the basement not done so I had a plan to build and did include making it for my wife to enjoy her hobby as well :)
Thank you Keith do love the detail
Regards
Richard
Put some beams in and then added beams were skylight and companionway would go just went off drawing for dimensions, then made a couple of air ports out of wood but might change them to brass.
Cut some cherry and made the side rails for the roof
Next up was to grind a shape on a blade to match the moulding shown on drawing, then made a jig to hold boxwood while I scraped
This is how it came out, for the corners I machined a contour approx same as moulding and cut into four
Cut some boxwood planks 1/16" thick for the roof each one was then tapered to fit
Last one to go in, and at the same time cut cutout for skylight
Then a light sand
Got the skylight made up again using boxwood for sides lid but used a small bit of cherry right on top
I was looking at a picture of the skylight and I could see that there was a recess for the glass and underneath was the bars so put a recess in to hold glass, pictures is to help with build if not allowed please delete.
to make the bar grates I cut a strip of boxwood 1/32 x .025" cut into four and drilled .016" holes spaced .039" apart then glued in the bars
Then installed inside still have to make hinges and add the glass/plastic
Again thanks for all your comments and likes
Regards
Richard
Edited by Retired guy
Richard,
Super well detailed. That razor blade trick is something that I always have wanted to try - your work is just perfect.
Under the table:
Completed:
Vasa-Corel -
I’m just starting to build a generic fishing schooner and am following your log for ideas and techniques. I am in awe with what your are able to do and hope mine is a tenth as good. I’m also amazed how fast you are moving in this.
Superb work on the mouldings Richard. Have you considered scratch building?
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thanks Keith, have done a lot of scratch work using brass, plastic but would like to build a boat from scratch.
3 hours ago, jwvolz said:
Coming along beautifully Richard!
Do like this Model shipway model Joe she is beautiful and find I am having a lot of fun building her
Regards
Richard
First let me say your workmanship and attention to detail is astounding, congrats on doing such fine work.
One question. When creating your razorblade scraper is the molding shape done by eye, using some sort of template or perhaps drawn first with a stylus?
Dave
Previous build: NRG Half Hull
Previous build: MS Bluenose
Ooops,
FYI mates; Just remembered (I had forgotten) that some time back I had purchased this set of pre-shaped edge trimmers. Have not used them yet.
Regards,
Under the table:
Completed:
Vasa-Corel -
Hi Jeff thanks for looking in and commenting on my build, what fishing schooner are you building it would be nice to see your progress
Dave
Thanks very much Dave trying to capture her in all the nice detail, and yes did grind the moulding shape by eye, used my Turbo carver with a diamond bit then finished it off with a very small diamond file
4 hours ago, md1400cs said:
Ooops,
Regards,
They look nice can you tried one and shows us what comes out, what is the thickness of them?
Regards
Richard
Richard, nice diamond file set. Where did you get them please?
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Keith they are very nice, got them from Gesswein Canada but they are an American company
This is how big they are
Bought quite a few tools from this place.
Regards
Richard
8 hours ago, mugje said:
Very nice micro file set! Not very cheap tho :P
No not very cheap but as one says cheap = break 😁 since I bought them I have used them a lot
31 minutes ago, CPDDET said:
It's about what I paid for my set of Swiss escapement files. Good tools don't come cheap.
Dave where did you buy your Swiss files
Regards
Richard
Regards
Richard
First try - May need to re-do my current ship upper deck railing details hmmmm?
seems to work just fine on a harder woods as well - need to go-back-and-forth several times of course
FYI: Don't know this site.  https://www.towerhobbies.com/cgi-bin/wti0001p?I=LATR7300
IMG_1191.jpg.8f16906ce94f1d63fbe02aa4309aaae2.jpgIMG_1193.jpg.7011e8d6b42a7e991587fb948720ebd2.jpg
Edited by md1400cs
adding info
Under the table:
Completed:
Vasa-Corel -
I believe I bought my set of Glardon Vallorbe escapement files at Rio Grande, a jeweler supply house. But it may pay to shop around.
Dave
