On 12/13/2020 at 2:44 PM, Ekis said:
Thank you all for your answers and comments! 🤪
@Kevin I use all kinds of products such as diluted India Ink, diluted wood stain, but also products from AK interactive for wood aging (wash for wood), or different colors for mold or moss (Slimy Grime Light and dark) or rust.
In general, this is enough for weathering. But it still lacks the vegetation (grasses, mosses, soil, etc...) that will come afterwards on the whole.
been out today and bought some Indian inks, pastel chalks and acrylic paints
thank you
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
attacking roofs is hard........always an uphill battle  ;)    beautiful work my friend......no matter which way the Euro is positioned :)  { I think he glued it there ;) }
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I finally finished this last block of houses!
They were the last ones in the village. I still have one or two walls left to finish the enclosure and then I go to work on the pedestals.
While waiting for some pictures of the block with its roofs full of angles...
A series on all the houses that form the central stop of the village (with the covered passageway that connects them),
Some views of the hall that I never took the time to do on a neutral background,
Some pictures of the Windmill on a neutral background as well...
stunning work my friend
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
:imNotWorthy::imNotWorthy::imNotWorthy: all hail grandmaster of the lodge of stone masons.
Absolutely stunning!
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
I am almost saddened by the possibility that this village may be coming to a close. I have been enjoying each new installment for so many months now and will truly miss your updates.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
@lmagna
Don't be so definitive about the future of this village!
First of all, there are still a lot of things to be done, starting with the work on the bases, then the paving and all the vegetalization...
Afterwards, maybe there will be a -small - break, but ... : 😁
Harbour?
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
1 minute ago, Kevin said:
Harbour?
Ooh! I do hope so😁😁
Current builds;
Completed:
5 minutes ago, Edwardkenway said:
Ooh! I do hope so😁😁
That would be fantastic! Are the ships you are showing 3D printed?
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
A seaport or river harbour, I don't know yet (as I told you in PM)... But I'm collecting things to think about it. 😁
I'm also thinking about which side of the village could have an extension.
There are buildings I've been thinking about for a long time that I can't do with the village, such as a warehouse with pontoons, a wooden quay or a medieval washhouse.
And then for a very long time, I've wanted to try resin to simulate water! This village with an extension finally gives me the possibility to do things !
Well, I'm not saying it will be right away, but when you start to think about it often to visualize things... I'm weak, I tend to let myself do it ! 🤣
@lmagna Yes !
There is not much to create a boat from the 14th to the HO scale... So, a friend offered to help me to have a cog that is perfectly consistent with the time, while remaining focused on the construction without spending months only on the boat!
And as it's one of the best I know in 3D with a perfectly adjusted printer... The image above is one of the prototypes in progress.
Edited by Ekis
A 14th century floaty thingy tied up to the quay? that would be the bees knees!!!! Beyond any doubt.....
Hey maybe you could offer some tips on getting into 3D..... (now that resin printers are becoming affordable) That hull looks gorgeous!!!!
Edited by Egilman
Quote:
@Egilman No, I don't have the skills at all to advise you. That's why I'm calling on a friend who has mastered...
As much as my job could be useful in photography or graphic design, as much in 3D, I'm really bad, except for a few basic notions like everyone else here. ☺️
The only thing I can say about this hull is that the departure is a classic paper plan for a boat of this era.
Once this hull is assembled (in 6 pieces) at the right size, I'll have to do the rigging... and put it in the dock in the middle of other small fishing boats...
I agree  with everyone and some  -  its a privaledge  watching your  building work  here,   every  new post is a  walk  into  a  small scale  piece of mastercraft,   I feel that the only things that could hold you back  are the  - physical  restraints on how much room you have,   and  how far you want to go.
Thank you Ekis  for choosing us here to share your imagination and skill.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
I have been fortunate to have followed you from the beginning.......watching you evolve,  and the village thrive.  I am so impressed with your workmanship,  balancing the use of wood and mortar...your vision is quite strong  ;)   you latest creations are absolutely incredible.  what looks like the edges of the parameters are met......you see the vision that there are no barriers and your world is infinite.  that is the earmarks of the perfect model....no matter how much you add,  it does not create overkill and doesn't upset the applecart!  {I'll bet there's even an applecart in there somewhere ;) }
where do you plans on showcasing this masterpiece......don't you think it ought to be put there,  before you reach the vale?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you for this very complimentary post!
I'm just answering this part: there is no particular place to display this village, except at home like all my other models.
Maybe one day, I will have the opportunity to participate in an exhibition, but for the moment, nothing else.
I'm currently on the terraforming of the bases of the village: not much to show you, it's a long and tedious work!
I also took all the roofs to make them appear more "14th" with older shades, dust between the tiles, moss and a bit of dirt everywhere. It's also quite long to do and I have to make sure that all the roofs have the same weathering.
As soon as I have something interesting to photograph, I'll show you!
In the meantime, I wish you a very happy holiday season! 😉
And thank you all for following this thread... :imNotWorthy:
Think I will be calling on you (frequently)  when I tackle my  Dio build  (the figures are the easy bit)
OC.
Current builds
Completed works.
Ekis,
I’m guessing that like me you won’t be overly sad to bid 2020 adeu. Of course there were good things that occurred, but they were lost sight of with all the chaos around them. That being said, you certainly accomplished a lot this past year! My favorite building so far is windmill. I had forgotten to mention at the time but the attached houses have a fairly modern look to them. They wouldn't get a second look as being out of place or time in any village today. I am patiently waiting for that pissoir to be completed, I really can’t wait too much longer. Gotta go NOW!
Kurt
Some details on the extension of the Harbour for this village.
Here is a diagram for the situation:
At the same time, my friend (for 3D) offered me his help for all the equipment on a scale that would be almost impossible to reproduce in wood with such finesse: various carts, boats, wheelbarrows, grinding wheel, wooden crates, barrels... And I can stay focused on the construction without spending tens of hours on accessories. All this with things I already have in wood and cardboard will give life to the whole!
This is getting  - Better and better    so many places of interest to watch.
OC.
Current builds
Completed works.
wow that will just finish it off so very nice, lol all the things i would have to make
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
WOW that is a treasure trove of 3d printed items. They will go far in  bringing your village to life. Does your friend also sell any of his printed items?
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
