I finally succumbed and started work on my Christmas present, the second version of the HM Alert 1777 by Vanguard Models. I also picked up my first foray into the Anatomy of the Ship series, The Naval Cutter Alert 1777 by Peter Goodwin. I'm not certain how much I will stray from the kit (certainly not as much as Blue Ensign) but I think that it will be a useful guide and will hopefully help resolve any questions that I have as they arise.
I think I might need a bigger workbench to fit that beautiful manual on.
I started by removing the false keel and the bulkheads and here you can notice one of the differences between the initial release and this second edition. The false keel and the rudder post are not keyed together anymore. This allows the rudder post to be added after (at least, I don't have the errata sheet in front of me) the initial planking.
After a dry fit (bulkhead 10 is installed incorrectly here 😬), I added a bearding line to help with sanding down the false keel. Working on the half hull planking kit from the NRG helped me understand exactly what I was doing in this step.
After sanding down the keep I sanded down the last bulkhead to get the proper angle.
Dry fitted the false deck (I hope I'm not messing up my terminology) and gently rested the ship in my new building slip (and wow is this building slip overkill for this model).
There are a few questions that I have to ponder since the manual still reflects the initial release instead of the second version (with the keyless rudder post) so I have to consider when to install bulkhead 10. I'll probably finish up my half hull before continuing too far on the Alert, but I had the day off and the half hull was in a different location so I couldn't resist starting.
Edited by VTHokiEE
1 hour ago, Blue Ensign said:
Good to see another one started VTH, it’s been very lonely on here for the past seven months.😉
B.E.
Glad to be part of group 😁. I’ve been watching your build and I simply couldn’t put mine off any longer. Thanks for such a detailed log as well, it has already helped me out regarding the bearding line and syncing that with my half hull kit. I’m certain that I’ll frequently be referring to your build.
I arrived at the stern frames, which I believe were slightly redesigned for version 2 and unfortunately they still gave me a slight issue regarding the fit. As cut the outer stern frames didn't align with the cut slots.
I filed the slots slightly and was able to fit the pieces, but the outer frames look like they are under some stress. Now that I am studying the images I think I may have had a eureka moment but unfortunately I don't think I can do anything about it at this point. The slots in the transom look angled to me which suggests that the I may have installed the transom backwards (I don't recall seeing anything anything about this in the instructions and after rereading them I don't believe that I overlooked it), but the transom has been beveled so there isn't any going back now unfortunately. EDIT: The more I think about how these would have been laser cut I can’t possibly think this really would have been a one-way part so I suppose there simply is some force there on the outer frames. I probably should have filed an angle into the slots on the transom but since the pieces are fragile I was nervous about removing them.
Edited by VTHokiEE
Ugh, “disaster” struck tonight. The deck needed to be bent to get it on:
and while I was dry fitting it was quite snug against the bow and unfortunately:
The part gets cuts away eventually but I’ll have to determine how to attach it back in the meanwhile. Slightly frustrated with myself at the moment :-).
B.E. - Thanks for the splint suggestion, with it I was able to make a fix (it isn't quite perfect, but such is life).
I made my splint:
Then I glued it to the bulkhead and shaped it. Unfortunately I couldn't get it perfectly back together, probably a downside of MDF, but I think it will be fine.
I then sanded the inside edge of each bulkhead to make the fit of the deck a little easier and cut out a larger notch in the deck to fit around the repaired section.
Now the deck is attached. I believe the minor off-center issue in the bow notch of the deck is due to my repair. I plan on sanding this even with the braces.
Thankfully, tonight I feel better about the whole ordeal than yesterday when it happened.
You may want to score your split with a slight saw cut on both sides. You’ll be breaking off all the tabs later, scoring will make that a little easier.
Regards,
Glenn
Current Build: HM Flirt
That’s not a bad idea. I don’t want to weaken the joint until I finish fairing the hull. After that it probably makes sense to score it before planking. Thanks!
47 minutes ago, SpyGlass said:
Sorry i was going to suggest -  maybe too late now -that you made a card template for the bulkhead repair from the plans. to make sure it was right.
Or also you could have used the "cut out edge" from the mdf sheet as a former . I NEVER throw away the sheets they always come in handy !
I don’t think it’s too late (but maybe a little trickier). I had given this some thought (and probably should have given it more, but I think I can still put it into practice.
I’ll probably trace the bulkhead from sheet onto a piece of card paper and then try to match it against the installation to see where I am. I can then trim up the bulkhead as needed, but I think, based on the deck layout, that I need to build the bulkhead up some.
48 minutes ago, SpyGlass said:
sand the deck ply notches NOT to sand the stem cutout
Thanks SpyGlass, that is my plan - leave the MDF alone and widen the notch in the sub deck ply to allow the entire gap in the stem to be accessible.
I’m pondering how to install the rudder platform. There is a gap:
At first I thought that I should build up the back of the pieces so that it pressed flush against the false deck. However, closely looking at the manual it looks like the gap may have been filled in front (extending the false deck) instead. I do know that the pieces should be vertical; maybe it would be fine either way. Any thoughts?
my suggestion is to bring it forward to align with that center keel piece, a little extra space at the stern isn't going to hurt anything, it will be planked over on top across the back. My two cents without knowing the rest of the build plans.
Regards,
Glenn
1 hour ago, SpyGlass said:
Nah  it will fit properly if I know Chris  - he may well reply anyway on here but I will have a quick look at my plans and put in my tuppence worth !
I am not sure what gap you mean if you look at the relevant pages - there is vertical piece part 56 ?to fit as well and have you got those tricky bits at the back fitted properly
Thanks for the suggestions. One of the reasons that I haven’t made a decisions is because I was waiting for this to arrive:
I also bought some gratings as well:
If I was going to plank the deck myself I think I could have done either choice but with the laser etched deck I wanted to be precise. I was going to guess that the laser etched deck would be the exact same size as the false deck (it is). So I believe this means I should press those pieces forward to be flush with the main deck. I was a little hesitant about getting the laser etched deck at first, but wow it looks superb to me and I’m quite glad that I bought it.
29 minutes ago, Gregory said:
That deck looks a lot better than some I have seen..
What was the source?
Chris Watton (Vanguard) made it:
The light in my garage is really, bad but the pictures from Chris’s post are much better. I’m really impressed.
Edited by VTHokiEE
As a respite from fairing I'll add a small update as I am lowly progressing further along. I attached the pieces in question above to match the curve of the deck.
Unfortunately when I went to remove the keel pieces and install the keel I noticed that the laser cutter did something funky and didn't cut all the way through the sheet for this (and one other part) and may have caused some overburn (?):
It was a little bit of a struggle to remove the keel pieces (I unfortunately left a touch of it behind as seen in the above image) and creating a tight fit left a small gap at the stern where the rudder post attaches.
This will all be painted white in the end so my current plan is to taper to rudder post slightly to meet the keel and fill in the hole with some filler. When I get to that other piece that may not be quite symmetrical I'll address whatever modifications are needed (and hopefully do a better job of removing it from the sheet. Now back to fairing...
And so it begins.
First plank on down 4mm from the bulkhead tops. This feels like a huge achievement for me but I promise not to bore you with pictures of every plank that I lay down. I'm currently prepping the corresponding plank for the opposite side. Given the time it takes me to prep and place a plank this log may go a little silent while I continue to work in the background. I'll post an update when I hopefully have several planks on each side.
I read everything I could on planking, I watched Chuck’s videos and I thought to myself my first layer of planking (and first planking ever) is going to be so smooth and beautiful.
I was wrong, completely wrong. I’m not completely certain but I think that I didn’t fair the bow of the ship anywhere near as well as I thought that I had. I believe this caused a clunker effect to develop which, to put it lightly, was quite disheartening. I think the pictures make it look a little worse than it really is, but a beauty it is not. I’m learning a lot in this process and, since this is a first layer, I’ll be able to use some filler and I believe everything will clean up just fine but I need to, and have, reset my expectations for this build. I blame you all with your beautiful masterpieces (sarcasm) 😁.1659DD32-DDCE-4984-A271-661F0F0401A4.thumb.jpeg.263d952c0cc7b117f8881128f184e18b.jpeg122E576F-9824-4EAB-93DA-3F541506CA0A.thumb.jpeg.259970a389d1d8f29fa7b277cf8a5564.jpegFA46E30C-727F-421D-AA3C-F7749A670292.thumb.jpeg.ed63fc8da2a60a5c1aa006eeca3622e3.jpeg18AD6BCC-AE20-4046-9723-616BB51A294E.thumb.jpeg.61bf6a21884067f538ca492fb7ee3e35.jpeg
I'm used to seeing the planks narrow at the bow. I wonder if that will improve the lay of the planks for you?
Doug
Current BuildsBluenose II - AKrabbenkutter / Prince de Neufchatel / Essex Cross-section / Syren / Barque Stefano / Winchelsea / Half Hull / Maria HF31 - Dusek / Bandirma - Turkmodel
On the Shelf: Santisima Trinidad and Cross Section / HMS Cutter Alert / Tender AVOS / Confederacy
Suspended Build: Bluenose II - Billing Boats Nr 600
20 minutes ago, SpyGlass said:
I would further recommend  when planking that you soak and clamp the strips to position and let dry there  - much easier to shape and get correct a strip which is already bent to fit
This is what led me to believe the issue is with the bulkhead fairing since no amount of soaking/heat would solve my problems 😞.
21 minutes ago, SpyGlass said:
Remove the planking you have done .
As much as I dread this, it’s be foolish to ignore someone with more experience. I used PVA glue (but glued the edges of the planks). I’ll try to pull off the planks and restart.
Do you think that I could number the planks and maybe reuse them? If not I need to order more planks...
9 minutes ago, mcpwilk said:
is a lot easier to plank a clinker hull from the keel upwards than try from the wales
Thanks, unfortunately I didn’t want a clunker hull, my inexperience in planking simply created one. Time to restart and hopefully salvage what I’ve done.
It may not look like it in the picture but the planks are tapering. I made some tic strips to guide that process so I feel relatively confident about the taper.
1 minute ago, Blue Ensign said:
you have towards the stern looks far too much, I don't think I needed to taper very much at the upper stern on the first planking
Thanks for the feedback, given this I think I need to order more planks.
Planks are off, that was much easier than I thought. I soaked them in some isopropyl alcohol and gently pulled them off. They came off in “sheets” though so there will be no reuse.
It looks like Cornwall sells the right lime replacement planks so I’ll probably order replacements there. I think (?) basswood strips would work as well but the OCD side of me fines it hard to mix and match.
Edited by VTHokiEE
2 hours ago, SpyGlass said:
Brave move but I think wise.
Now FAIR !!
The general rule I use is that you always need a bit more off than you thought  - as long as you leave the appropriate one edge of the BH untouched. And the stern BHs especially true.
The edge of the deck ply gives a good guide to roughly the angle that the BH needs to be at the top.
You can also use the cutout scrap from the deck piece as a template.
Thanks, I’ve been sanding away and things look better. The planks touch all the way around at the top edge of the plank but seem to have a tough time “twisting” at the bow to make contact all the way through to the bottom of the plank. I soaked a plank and clamped it against the bow to let it dry today in the hopes that it helps. This is quite the learning process (and I can see how you can frustrate yourself quite quickly).
EDIT: Thinking further I think the filler block right on the stem is my issue. With the stem in place this is a very tight spot to sand. I’ll have to think about how to address this.
Edited by VTHokiEE
8 hours ago, SpyGlass said:
Pictures please?
This was the issue, it might be hard to see but the planks weren’t laying flat.
However after significantly fairing that front filler block things are looking up.
I still have a good bit of fairing to do on one side (and make certain that it’s good for the full run in both sides). It’s a tough place to get into with the stem on but I’m getting there.
