1/48 Seafire Mk. III (Late)
1 hour ago, Egilman said:
That would be my suggestion also, and, I believe that Testors put out a spray decal fixative also.... mostly intended to seal inkjet printed decals but I remember someone using to to fix weak decals...
Thank you bro.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Share on other sites
Right  I attacked the other decal sheet  our of the Eduard kit  "much much better"    funny how different makes   - make a huge difference,   so I used the roudals and other small decals  and from the other  set  I used the Royal Navy  and serial  decals  looking ok I think.
OC.
Current builds
Completed works.
Link to comment
Two steps forward and one back but you keep slogging on, good rescue work.
I'm with Lou on the hairdryer,  give it back to the Admiral or at least take the plug off🙄😋
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Thank you Edward,    the hairdryer does have its usefullness  (just need to rember to ease off near canopies)
OC.
Current builds
Completed works.
Link to comment
And decals, and paint finishes, and........................?B)
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
OC.
Well, they do yes, that being said, if it has to do with drying paint, drying decals, or drying anything else on a model, it is best to let nature take it's course..... (I learned this a number of years ago, read as decades ago, that all heated forced air does well is melt and deform plastic or hard shell and crack paint and split decals....
But then that is only my experiences, others may have different experiences.....
One thing and one thing alone works well on model finishes... the old standby, time and patience.....
If you can brother, lay off the blow drying as much as possible.... (preferably eliminate it, your modeling will be better off for it my friend)
Quote:
Link to comment
I do agree  with the caution note on uisng a hardryer  "but"   up untill  my recent  canopy  error  - I have never had any issues, its  low powered  dryer used on its low setting and just giving out more of a warm heat than and intense one, it was Fully my own fault  over the canopy  as I wasn't paying attention or concentrating  and left it too close to the canopy for too long.
I would never use it on decals   but the  gentle heat does help  the paintwork  and does help to speed things  up abit so work  can take  less time.
But thak you all for the  heads up about using intense heat.👍
OC.
Current builds
Completed works.
Link to comment
Mark, the real hard core builders have 2-4 builds going simultaneously. I've got 3 right now, 2 refrigerator cars and a covered hopper. All plastic kitbashes of basic cars into something modified to a greater or lesser degree. They're a lot of fun, re-engineering the basics into the desired cars.
Ken
Started: MS Bounty Longboat,
Link to comment
Hi all. more progress on this today  -  I started on the main undercarriage, these are a Three piece assembly  and go together very well  - some loverly details on the oleo legs,  after  careful painting and detailing  they were then glued in place  - paying attention to the correct angle of the wheel against the oleo's.
OC.
Current builds
Completed works.
Link to comment
I am particularly  happy the way its turning out  as this was the kit I threw out when I first started it as an IX Spit  due to many reasons,   so glad I just put it in the cupboard and returned to it with fresh eyes  and a new project idea.
OC.
Current builds
Completed works.
Link to comment
Evening all,
More progress  tonight   -  I fitted the rear tail dragger wheel  and painted/weathered, then I sat her on her wheels for the first time:cheers:
Then it was time to make the spinner and props  - but could i find the frame for the props to fit in  (not a chance)   so I found a round  collar  and ligned the props up at 90deg  and ran my round file to create some cut out, then I sat the props and applied a good measure of glue to fix them.
I returned to the bench  and found the props/frame glued down to my cutting mat  - so eased away with my knife, I saved the  spacing by glueing the assembly inside the  spinner cone  and  set them up aligned.
After a few hours I was able to handle the assembly and paint them Sky/Nato Black  - I fineished off by adding the one decal on each prop, then glued it in place on the front.
OC.
Current builds
Completed works.
Link to comment
Looks good to see her sitting on her wheels, OC.
Link to comment
Thanks Mark,   was so undignified  having her sat on her bumb  - just needed a bit of adjustment to get her hight correct both sides.
OC.
Current builds
Completed works.
Link to comment
She's come on well, considering she was destined for the bin!😋 Nice!
Current builds;
Completed:
Link to comment
Thank you Edward.
OC.
Current builds
Completed works.
Link to comment
Evening everyone,   so I'm calling this "Part Finished"  pending a top coat,   I added the  aerial and  rear view mirror.
Thank you for all the comments and looks - It didn't turn out to bad   (not the best)   but considering it was nearly a bin resident.
OC.
Current builds
Completed works.
Link to comment
Don't be too hard on yourself OC, I think looks fantastic, very royal navy, wouldn't look out of place on HMS Illustrious.
Edit: further research suggests that mk3 were on Hms Victorious and mk2 were on Illustrious
Current builds;
Completed:
Link to comment
An excellent recovery brother..... Look at it this way, what your learning about yourself in the hobby is more valuable than any one individual model or technique...
Keep going my friend, it only gets better.....
Quote:
Link to comment
Thank you kindly Edward,   she is a kind of  "mk.III  +"    with a few mods prior  to the Griffon  engine replacement,  another reason for the paint scheme  as most mk.II  and  IIIs  were still wearing camo schemes.
OC.
Current builds
Completed works.
Link to comment
Thank you sincerely brother,    next stage  .............Mossie.
OC.
Current builds
Completed works.
Link to comment
A nice job.
A question-  How did this “marinized” Spitfire perform as a carrier based fighter in comparison with the US Navy’s purpose built Hellcat?  I am assuming that these Seafires flew from Royal Navy carriers when they operated in the Pacific in late 1945.
Roger
Link to comment
30 minutes ago, Roger Pellett said:
A nice job.
Roger
I think they were  very popular  because  of thier  great agility and turn of speed,   the vesion I built  had the same engine (with a few Naval mods)  as the Spitfire IX   and that was some  machine  able to out run and out fly a  FW190  (and thats saying something)  they carried the addional tank under the belly to extend the range as in fairness  the Seafire and Spit did mot have a massive range on pure frame tanks, this did reduce there  max speed  a bit though  but it was still very very good.
OC.
Current builds
Completed works.
Link to comment
2 minutes ago, Jack12477 said:
Came out real nice looking OC. I like the color too. Great job.
Thank you so much Jack, I like it as its a different scheme from the camo jobs.
OC.
Current builds
Completed works.
Link to comment
11 minutes ago, marktiedens said:
Nice recovery - looks great!
Thanks Mark, much appreciated.
OC.
Current builds
Completed works.
Link to comment
Turned out nice OC. Do you have a better place to put it than back into the bin?
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
Yep,  she is going/has gone in the display unit   - just need to juggle the shelves around to make space.
OC.
Current builds
Completed works.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
