I've never seen upper stern framing constructed off the model before; an interesting approach! Lovely work, as usual.
I am enjoying your progress.  The level of precision is remarkable.
If memory serves, there are three openings aft the capstan labeled "Gra," "tin," and "g" which is to say, "Grating."  Also, apertures labeled "Hatch" or the like can have gratings as well.  Dashed lines on these openings indicate a shelf in the timber to receive the grating.
Well done and inspiring.  Thank you for sharing.
Wayne
Wayne
Thank you, Wayne, it is a great pleasure for me to know that you and Allan follow my work, I consider gratings where Hatch is written as well
Thanks, Druxey
Cutting those sill mortises perfectly is no easy task Matiz. As usual your work is perfection. I like your little mini-clamp which you are using to prevent the frames from shifting while working on the sill mortises.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Thanks, <Greg, and thanks for the like ☺️
Love the symmetry!
John
Member: Hampton Roads Ship Model Society
Current Builds: Tugboat Dorothy  Newport News Shipbuilding Hull #1 (complete)
                           Iron Clad Monitor (complete)
                           Sardine Carrier which I will Name Mary Ann (complete)
                           Pilot Boat John H. Estill Newport News Shipbuilding Hull #12 (my avatar)
                    Harbor tug Susan Moran
                    Coast Guard 100' patrol boat
                           Light House Tende Beech (complete)
Just catching up!  Wow.   Your carpentry is superb and the detail...   this is going to be quite the piece.    I look forward to following along.
that is just beautiful
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
Ciao Matiz
I am not sure I understand.   The lower deck drawing shows the bread bins and scuttle that leads to the bread room below which, if I remember correctly,   was a platform on the Orlop level.   I believe the bins on the lower deck had doors into them from the sides.
The upper deck in that area aft has the great cabin, bed place and coach, and there would normally not be any access to get below to the bread bins these areas.
Maybe I am missing something here and Wayne can clarify.
Allan
