Battle of Waterloo Attack on La Haye Sainte Farm 1/56 28mm
Evening all,    some more progress this evening  - firstly I dry fitted the  roof with figures to the house, slightly tight fit now - I will have to see what I can relieve before I fasten the roof down,   so I put the roof to one side and started building the Piggery and  small gate surround,  the surround was just a case of painting then gluing in place, the Piggery  is a Two stage building that needed building, I then started on the Whitewash on the walls and inside the larger of the Two.
The Piggery is just dry fitted to each and the wall at the moment.
OC.
Edited by Old Collingwood
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Share on other sites
Excellent work OC!
The farm is coming along very nicely 😉
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
3 minutes ago, Edwardkenway said:
Excellent work OC!
Thank you kindly Edward,      I am trying to build it is little stages  so I have more control over the detail and painting, then join each section as I go.
OC.
Current builds
Completed works.
Link to comment
Evening all, so where were we "oh yes - building the piggy pen"   so  I painted it in the same colours as the house, then a bit of a wash - then it was glued in place.
I also re visited the the house roof, and after a bit of fiddling  (putting a few of the  riflemen on a strict diet)   I was able to get a good dry fit, so I thought  "go for it"   and  without delay the roof was glued on, it needed a bit of PVA into both ends of the gable ends  and with the aid of heat - it was forced to make a good connection.
Admiral want's me to build a real version for us to live in.....
So this is where I am at the moment.
Current builds
Completed works.
Link to comment
Looking good, OC.   As for the admiral's comment..  will you take her up on that?  :D
Link to comment
Thank you Mark,     Imagine how long it would take to build😬
OC.
Current builds
Completed works.
Link to comment
Next job  -  make some flashing to go around both gable end chimney stacks, then paint/weather them,  do a bit of a wash on the lower house walls, and a bit of  dry brushing,   then on the outside wall  dab White the stubs that where glued in the wall.
OC.
Current builds
Completed works.
Link to comment
34 minutes ago, CDW said:
Looking sharp and neat! Well done OC
Thanks Craig,  still a long long long way to go yet  - that is just the tip of the iceberg.
OC.
Current builds
Completed works.
Link to comment
OC,
Nice Work!
This is picky, but I suspect that the snipers firing from the upper story windows would have sheathed their bayonets.   There would have been no use for them and they would have added to the difficulty of handling these already long weapons in and out of the windows.
Another thought.  Since you have defenders armed with rifles, wouldn’t they have been the ones at the windows?
Oops, I believe that these guys are riflemen.  I assumed that all riflemen wore green jackets.
Roger
Edited by Roger Pellett
Link to comment
8 minutes ago, Roger Pellett said:
OC,
Nice Work!
Roger
Thank you for looking in Roger, to be honest  I think you might be right about the riflemen firing from the dorma windows,  I just made the figures up using the rifles that came pre made like that  - I will adjust that though,   Major Barring  had the Red Jackets (5th KGL)  with muskets  firing from the farmhouse, they were the smaller contingent  but still quite a few of them where in and around the farm complex, but the majority were the Green Jackets  2nd Light KGL  with rifles.
OC.
Current builds
Completed works.
Link to comment
Looking very nice indeed. Its going to look spectacular on a base with the troops around it.
Alan
Link to comment
Alan
Thank you Alan,   its all a learning curve  - firstly the figure building and painting, then the buildings, then the scenery  trying to make that look lifelike.
This project always was set out to be an accurate Diorama  and not a  wargaming  set piece, thats why I will be placing the  figures  off thier bases and  glued down by the feet  (same with the horses).
OC.
Current builds
Completed works.
Link to comment
Evening all,    the  farmhouse  is now finished  and weathered  - just some basic wash and a wee bit of dry brushing.
OC.
Current builds
Completed works.
Link to comment
Next stage  started is the Stable block,   after viewing an over head  view of the  farm complex  it became apparent that this kit  is too  long one way but corect the other  - its supposed to be a square  more or less,   so I placed the stables  sections  on the table and looked at any ways to reduce the length of the one stable, I found out I would be able to trim it down with my sharp blade and ruler and create another slot, I did a similar thing to the outer wall of the one stable by trimming the end, this reduced it by about Three inches and will make the whole thing more square in shape.
OC.
Current builds
Completed works.
Link to comment
Just catching up OC. and your farmhouse turned out great.  I really like the interior work and the staircase looks particularly authentic.  Love the image looking through the window.  Very nice.
Gary
Completed Scratch Builds
Link to comment
Gary
Thank you so much Gary, I take your compliments as a real honour,  you are inspiration  with your builds.
OC.
Current builds
Completed works.
Link to comment
Evening all,   some boring progress tonight that doesn warrant a photo  -  I have been doing some  -  sizing, marking and cutting  to make the stables and base the correct size,   this took some thinking about  as the pieces  interlock  including a sloted section, but after a few hours I got there.
Tomorrow will be the start of painting the individual pieces including some more brick work.
OC.
Current builds
Completed works.
Link to comment
Evening all,   more work  this evening  - its "Painting time"    - the  stables  have Four main walls  each with  brick and paint detail,  I carried on my routine from the farmhouse  -  sand colour worked into the mortar gaps, then a  brick colour carefully brushed over the top, then the White built up in layers  leaving it thinner  close to were it meets the bricks  - lots more to do.
OC.
Current builds
Completed works.
Link to comment
30 minutes ago, king derelict said:
It all looks great OC. I am so impressed with how the exposed brickwork looks. It looks like the model is made with individual bricks.
Reading the updates on this build is one of teh highlights of my day.
Alan
Thank you so much for saying that Alan  - that was a really nice thing to say😊
OC.
Current builds
Completed works.
Link to comment
I should have said  - ignore that part on the left in my pic,    that will be locked away inside the other section of the stabbles - joined by the slot.
OC.
Current builds
Completed works.
Link to comment
Looking great, OC!
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
37 minutes ago, GrandpaPhil said:
Looking great, OC!
Thank you Phil.
OC.
Current builds
Completed works.
Link to comment
Evening all,    paintwork continues  - several coats of Flat White.
OC.
Current builds
Completed works.
Link to comment
Evening all,   more progress  - Black Paint time on the doors/frames and window frames,    oh  and look what arrived in the post  - my Two carts to go outside on the roadway acting as a partial defence.
OC.
Current builds
Completed works.
Link to comment
Evening all, a bit more progress on the stables  - I got the inside lower brick work painted Black (to match the farmhouse as its like that all the way round the inside walls)  but after chatting with the admiral  - as the room was starting to look like a  dump tip  with my table cluttered and messy  making the rest of the room look  messy, so I had a tidy up and put away  most of my tools/tubs etc, then latter when I returned to do some more work on the build I just got out what I needed not everything.
Its the pitfall of not having a  work area or man cave.
Anyway  the next bit of work that was started and finished was a pre cut section of  floor  flag paving  -  I  put a sand  fill in down first, then picked out the different flag stones in different shades of Grey, and finished off with a couple of dirt washes as it would have been well worn.
Foregot to take a pic - will  tomorrow.
OC.
Current builds
Completed works.
Link to comment
Evening all,
Firstly a Huge Thank You to Everyine for pushing  this to over 30K  - amazing😲
So  those pics I promised  -  I have assembled the Two stable blocks  - still awaiting some touch ups and the roofs.
OC.
Current builds
Completed works.
Link to comment
Evening all,
OC.
The slate floor looks like the real thing.  I hadn't appreciated the size of the farm. This will be a spectacular diorama.
Alan
Link to comment
Alan
Thank you kindly Alan,    yep its got a fair amount of area to it - when the whole farm complex is assembled it will be roughly Two Feet Square, my display case is Three Feet long by nealy Two Feet wide.
OC.
Current builds
Completed works.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
