Very nice, Karl. The finish is perfect, may I ask what is the wood?
STAY SAFE
current builds:
Thanks to all for the kind comments.
Part 4
Auxiliary construction built for the alignment of the frames,
five double frames installed, gun opening fixed.
To consolidate the construction , the entire external planking was atteched.
Karl
(Google Translator)
1 hour ago, pollex said:
Are you using the J.Boudriot books or plans as the source of your data. ?
I also have Boudriot"s books (4 volumes); also several other Ancre Monograms.
They are EXCELLENT !  Pollex, Calgary
Yes, " Le Vaisseau de 74 cannon" , Jean Boudriot.
Karl
Wonderful!
STAY SAFE
current builds:
22 hours ago, Dziadeczek said:
Out of this world!     :omg:
May I ask you, how did you carve (?) this lettering "DE 36"?
Thomas
Hallo Thomas.
Ich kann momentan nur auf Deutsch antworten.
Schrift auf die Lafette übertragen,
Konturen der Schrift mit einer feinen Nadel nachgestochen. Fertig.
Grüsse
Karl
Translation from Moderator:   Hello Thomas. I can only answer in German at the moment. Transfer the writing to the mount, engraving the outlines of the writing with a fine needle. Finished. Greetings
Thanks to everyone for the kind comments and likes.
Update:
Part 9
Production and assembly of the blocks on the cannon.
I would have had to work on the hooks a bit,
grind the tip etc.
I just forgot, now it's like that.
Karl
