Flakpanzer T-34(r) by Backer - FINISHED - UM - 1/72 - PLASTIC
Welcome to the build of this unique T34.
This was not a standard conversion but a "in the field conversion" of a German unit.
The 34
https://en.wikipedia.org/wiki/T-34
The 2cm Flak
https://en.wikipedia.org/wiki/2_cm_Flak_30,_Flak_38_and_Flakvierling_38
brief history
https://forum.axishistory.com/viewtopic.php?t=8225
UM is a company from Ukraine,  these kits have usually good details and are easy to build
https://henk.fox3000.com/um.htm  (link to the website from Henk of Holland)
Plans20210930_184316.thumb.jpg.7ca3c7dbc4800d324809f9e5ed2d510d.jpg20210930_184332.thumb.jpg.50132efd91a9c86a6e343af6a9f224d1.jpg
Parts
Rubber tires on tankwheels, very unusual
Building the chassis. And for the first time problems with a UM kit.
Where is part C47?? And... the fenders are too long
20211001_184422.thumb.jpg.e6a067cc75dca5115b98b41a110191bf.jpg20211001_192810.thumb.jpg.36c67d947fe3d2a7b31da102a5282c6b.jpg
Problems solved (a piece of sprue is a new part C47 and the fenders shortened)
drill out the exhausts
Chassis and wheels ready ( needs some more sanding here and there)
I'm in Patrick,  is it based on a captured Russian T34 tank?
I'm also looking forward to more of these in your military modelling season😉
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Yes, the chassis is a standard T34 (turret removed).
And, indeed, Military modeling season is started :pirate41:
Ammo rack in place
The Germans used EVERYTHING they could lay their hands on off the battlefield.... (but then so did the Russians) The US army was well known for using captured 88's as anti aircraft guns in the place of 90mm's when they had production shortages later in the war.... They had captured over a thousand 88's and a mountain of ammo... They even wrote their own tech and service manuals for them as foreign issue equipment.... (they even had 100's of AA crew prisoners willing to teach)
In total war you make use of everything you can no matter where you get it from....
Edited by Egilman
Quote:
Bingo!  Spot on.  Things haven't changed much in that regard since the earliest times in history.
Building the 2cm flak
Dry test
The Flak and the parts of the turret
Everything is ready to assemble the wheels and tracks
Thanks for following
glad I didn't miss the whole build  ;)    saw one of these on oldmodelkits........but at a larger scale.  it's good to see more of your fine work  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks for the nice comments.
Wheels and tracks are in place.
The vinyl tires have one disadvantage. Normally these plastic tracks can be glued with regular plastic glue. Now it is necessary to use CA glue.
20211015_182231.thumb.jpg.c50b79dceb6d629711d9b6e42f76c6db.jpg20211015_185050.thumb.jpg.0848381eeb6cb666643d5d002c798cb3.jpg20211015_192113.thumb.jpg.737e7133b95d456d77df015fe3260428.jpg
very nice progress :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
More progress
Painting in base color
Add a cable (2 russian towingeyes and some rope)
turret parts glued together
made "a mess" with some mat Black  😇
turret installed
A free style 3 tone camauflage  (the black mess is a bit less messy 😉)
20211020_184412.thumb.jpg.fc41ed62c4cd98faa37271625f081e92.jpg20211020_184424.thumb.jpg.ef7840c5aba1d8f6e3122822f30a3f13.jpg
dry brushing with light grey
metal parts painted and ammo boxes in differend colors
to be continued.
nicely done!  really coming to life ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Time to finish this build
Added some rust and some bare metal here and there.
Glued the model on a base plate and gave a matt black wash.
20211026_142642.thumb.jpg.d3377f1238d447b2aeb1bb8d8a21bb50.jpg20211026_142656.thumb.jpg.2d008b73937c7ff7e74a7b44cad80b6c.jpg20211026_142730.thumb.jpg.25bfa6877de1b277431441298a4daf48.jpg20211026_142907.thumb.jpg.488518567909b49fb123abd2f4d96892.jpg20211026_142930.thumb.jpg.b15f9af04d7c66ac581fe0061859036e.jpg
Tagged and stored with his T34 and SU brothers and sisters.
Thanks everyone for following, comments and likes.
Beautiful work on an obscure variant.  A model to be proud of.
Thanks for the comments
But if I look closely at the photos. My painting and weathering skills have become a bit "rusty" after a summer of rigging and sailmaking on my Pelican.
Next model will be better 😇
nice finish.......remember the 'mottled' factor  ;)    with use.........comes abuse  ;)
........I could come up with a few more..........you did a fine job! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
