5 hours ago, druxey said:
Nice explanation, Ron. BTW, rubbing alcohol is also an effective acrylic solvent and is cheaper than Brush Restorer!
Thank You, druxey. Your commentaries are always appreciated by this shop hermit.
Yes, rubbing alcohol is a good solvent for acrylic and many other things - and is about 1/10 the cost of the Restorer! I used rubbing alcohol to clean the surface of my new light table while fabricating my sails. The spray adhesive I use to attach the silkspan leaves residue on the bond paper that transfers to the light table: the surface gets quite sticky. Between sails I wipe it down with an alcohol dampened soft cloth.
Ron
Former Director, Nautical Research Guild, 2021-2025
@modelshipdood on Instagram
Current Build: HMS Diana Update
Completed Builds: HM Gunbrig Cracker #13 (HM Adder Gunbrig)Grace & Peace (Wyoming, 6-masted Schooner), HMS GrecianHMS Sphinx (as HMS CamillaOngakuka Maru, (Higaki Kaisen, It Takes A Village), Le Tigre Privateer, HMS Swan, HMS Godspeed, HMS Ardent, HMS Diana, Russian brig Mercury, Elizabethan Warship Revenge, Xebec Syf'Allah, USF Confederacy, HMS Granado, USS Brig Syren
8 hours ago, AJohnson said:
Your work is very neat, your Camilla is looking stunning already with the sails test fitted.
Thank you kindly!
Admittedly my process is quite complex, but if you want realistic-looking working sails on your model(s), the investment of energy is well worth it IMHO.
I work almost exclusively in 1:64 scale (3/16" = 1 foot). I believe my sailmaking technique is good down to 1:72 and up to 1:48. Building in scales outside of this range may not be as convincing.
Ron
This post continues with further details explained in the previous one on the mainsail's rigging.
Paying attention to their additional rigging is an important part of making a sail look like a realistic working one. A critical area with both the Main and Fore courses is the Clue rigging at the lower corners of these large sails. These two sails are also mounted to the ship's largest yards and uniquely, have long lines that extend fore and aft to manipulate them. Getting these sails to appear convincing starts with setting-up and running the critical rigging to their rope cringles; these were formed by the boltropes mounted to these sails in the previous post..
The Mainsail's clue components, up close. Three separate lines will exert forces at the corner(s) of the Mainsail. The Clueline block and the Sheet block have been stropped and fed through the sail's Clue cringle as shown. After these two blocks have been inserted, the Tack line is fed through and a "stop" is lashed into its end. In practice, a large and complex knot was the "stop" that held the other blocks in position within the Clue cringle. The metal ring shown here is a 3.5mm dia. "jump ring" of oxidized brass which is stropped to the Clueline block and simulates the special configuration of this block. The clueline block had to remain flexible against the fore/aft counter-forces to this sail exerted by taut Sheet and Tack lines. The Clueline is also the principal sail hoisting block, whereas the others work in tandem to pivot the sail during Wearing and Tacking maneuvers (turning the sail to optimize the capture of the wind).
After stropping the Clueline block, the Sheet block and prepping the end loop in the Tack line, assembling them to the cringles is straightforward as shown in the first photo. In the photo here I've measured the length of the tack ropes and temporarily rigged them into the assembly with their "stopper" toggles. The toggles are made from a colored toothpick inserted into a lashed loop at the end of the tack line. The hand tools are holding the sail's leeches and foot flat so that the clue corner assemblies will be easier to make.
I've suspended the Mainsail from its yard temporarily to depict the three lines that rig to this sail's corner Clue cringle.
Another view of the completed rigging assembly on the Mainsail. There are three tension forces on this sail: the upward one from the Clueline block, the aft force of the sheet block and the fore force from the tack line (which has the mounting stop - also called a "toggle"- to hold it captive to the sail). When a ship was underway these blocks all worked in concert.
A clear view of the Clueline block's rope that is lashed to the main yard, leads downward to the clue line block and then runs up through another single sheave yard block that, in turn, feeds the end of this line down to the Midships bitts.
A low perspective view of the Mainsail's Clue assembly. Because of the translucency of the sail, in this backlit view all the linings are quite evident across the sail and along the foot and leeches. The reef points and robands have yet to be mounted.
The Mainsail will look similar to this view when it's fully mounted and rigged. Some lines have been temporarily rigged to illustrate the importance of this particular rigging.
The identical processes will be used to rig the Clue assemblies of the Foresail.
Edited by hollowneck
added text
Ron
10 hours ago, Blue Ensign said:
Impressive work Ron,  great photos of the clue set-up, well done.
B.E.
Thank You, B.E. Without a set of course sails these rigging details are slightly puzzling - or have been to me in my early models. When one “bends” sails to these large yards it becomes quite clear what these running rigging lines and tackle are all about! My hope is that showing the details from a couple different perspectives this important rigging detail will be - uh….demystified.
3 hours ago, druxey said:
Nice demonstration of the triumvirate of lines at the clue of the sail. Now no-one seeing your photos will be clueless!
Thanks, druxey. I’m gradually learning ‘the ropes’….The complex confluence of this variegated trinity has been…uh, demystified. I’m also pleased that it’s you who couldn’t resist the opportunity to pun!
Cheers
Added humour
Ron
I've been busy with sailmaking rigging details and here are some photos of this work over the past couple weeks. This work is very tedious as the spaces for the additional sail rigging lines get's very constrained. Additionally, to add sail rigging requires a number of block additions and belaying decisions. When adding sails (with attendant management lines), my "rule" is to work "top-down"- starting from the gallants, progressing to the topsails, then finally down to the main courses. The bowsprit/jibboom sails (two on this model) are outside this metthod as is - of course - the lateen spanker sail at the stern.
Here are some more sail prep details.
At times, progress seems sooooo....sllllooooowwww during these final rigging stages. But, I'm not in a hurry. Are You?CAMHullPaint01.thumb.jpg.c7c73c3a3fa55374ed41de3cd1db3c2d.jpg
However - to break the repetitive monotony of the sail fabrication final details and their complicated rigging, I finished some unfinished business on the hull. This acrylic color is my choice - AGED WHITE. The lighting makes the paint in the bottle appear considerably whiter than it is: the actual hue does have a yellow cast to it. It's from Vallejo and this particular bottle is for airbrush work (less viscous consistency) which I also like by applying by brush (three coats). An airbrush isn't necessary for this. I masked-off the waterline with Tamiya tape,  per normal, and then brushed on three thin coats. A brighter white color would be much too stark; this paint during the era would be a hue resembling "tallow."
A view of the waterline painted at midships. As anyone who follows this thread knows, my model will be displayed in a waterline diorama. Hence, painting the lower hull was minimal and even this small area will be largely covered in diorama "water." I haven't decided on the angles of heeling and the exact tack of the ship but I'm pretty confident I won't be lifting the hull much above the wave action. This part of my project gets very interesting in the final stages because I'll soon need to decide on the sail bracing(s) and yard positions. I've decided to set a total of 11 working sails including both large fore and main courses - as well as both spritsails. All the sails will need to be positioned in a sensible manner depending on how rough the depicted seas are and naturally, the wind direction.
Another waterline view at the bow. This area of the model is always dramatic in a diorama: the cutwater/stem will likely be splashing large amounts of water up and around the front of the hull. When I paint the water I add  some translucency to the colors so that below waterline ares of the hull can be partially seen (in some places). I accomplish this translucency (like real water) by layering colors and mixing a medium into them for the sea and waves.
There are dozens of reef "points"  to add to several of Camilla's large sails (these are the thin ropes that secure partially furled sails when the conditions call for "shortening sail"). Making and affixing lots of these reef points is more tedious than doing ratlines - in my estimation. There are about as many of these to do as there are ratlines required to tie to the shrouds. Ugh.
Once the reef point ropes are cut and inserted into the completed sail, they must be affixed in-place, at the proper lengths, fore-to-aft: I use Liquitex Matte Medium acrylic for this. The "points" on the aft side of the sail are much longer than the ropes on the non-windward (fore) side of each sail that carries these lines.
In the photo here, I've inserted individual ropes through holes in the reef lining bands (can't be seen in this view), added a tiny drop of adhesive to hold them so they don't slide out of position and wait until the matte medium dries, which is fairly quickly. The next step is tricky because the ropes want to point in every direction but the way you'd like them to hang downward - loosely; as a simple solution to hold these ropes I created a simple jig which is a ruler's edge (supported by a simple clamp on both ends of the ruler - one seen here). The edge of the ruler holds the loose ropes in rough alignment for adding yet another tiny drop of matte medium adhesive to secure the ropes a few millimeters below their pass-through holes. The ends of the ropes will be trimmed evenly after this step is completed.
As can be seen in the photo, the top band of reef points is higgledy-piggledy (that's a shipwright's technical term). The sail's linings are clearly seen here as are the bolt rope on the leeches and foot and clue cringles. Holes for the bowline and bunt line cringles will be made after the reef points are completed. This sail is the mizzen course. The holes for the sails robands have been drilled through at the head of the sail. The robands "bend" (mount) the sail to the yard.
A toothpick suffices for daubing the tiniest amount of matte adhesive to the aft reef points. This secures them firmly. I chose a gluing spot a few millimeters down from their through-holes. On working sails, these lines will be moving with the wind and at any given sailing moment will not be uniform across the sail, and shouldn't be. The lengths of the ropes will be trimmed, but they'll be loosely arrayed as they would appear in real sailing conditions. On the fore sides of sails with reef points, the matte adhesive is used to affix much shorter lengths of the reef ropes. These points are more uniformly arrayed across the fore side of their sails with considerably less randomness.
It's getting very busy in Sail City.
Here, Camilla's two spritsails have a majority of their sail running rigging affixed. Keen eyes will see that the Spritsail topsail - at the tip of the jibboom - still needs it clues to be rigged...which leads to the next photo.
As mentioned earlier, adding sails requires a host of additional blocks and decisions about where to belay the falls that result.
In the case of the Spritsail topsail, blocks need to be added to the foretop. I should have remembered to do this at a much earlier stage of my build, but - I didn't. Thank goodness for my trusty #72 thumbdrill. After two holes are carefully drilled into both sides of the top, an eyelet (bolt) will be glued in (facing downward). There are sufficient number of P/E brass eyelets left over in the kit's rigging provisions; the "eyebolts" are painted black. The eyelet will hold a single-sheave, stropped block UNDER the foretop and receive the clueline from the Spritsail topsail.
The arrow points to a guide that I used to determine an unimpeded run from the topsail's clue (sail corner) up to the foretop. The guide helped me to determine the exact position of the hanging block for the sail's  line. It's a perfectly straight, 1.0 mm square piece of spare pear stock and I've inserted it to an approximate location of where a block will be later positioned.
Both undersides of the foretop need a single-sheave block for the spritsail topsail's clue lines.
Here is the block for the spritsail topsail clue stropped to a hook that hangs from the eyebolt that I added to the foretop.
Speaking of additional sail rigging blocks: there are now five (5) rigged blocks at the very tip of the jibboom. I've added the double-sheave block- the darkest one - for the top gallant bowline; the line will lead back through the fairlead on the lower bowsprit and tie-off deckside.
The bowlines for the fore topsail require single-sheave blocks mounted atop the beeblock at the end of the bowsprit. These sail lines will also feed through the fairlead.
Last, but not least, the forecourse bowlines require two single blocks. These are mounted to the stay rigging lines near the open heart blocks that secure the foremast. These blocks are 3.0 mm, single-sheave. Blink, and they'll disappear! The arrow points to the port side one squeezed into the existing rigging. The bowlines will run unimpeded back through the bowsprit fairlead and terminate on deck like the other bowlines. I should have added these blocks earlier too. Oh well... build and learn.
A gulls eye view showing how I'm working "top down" with the sail rigging. Fore topgallant nearly rigged. Fore topsail is bent to its yard, but no clue rigging yet. The robands will be trimmed-off ala' the topgallant above it.
Another progress view of the foremast rigging with two of her three sails in various stages of additional rigging.
That's All For Now , Folks.
Back to more sail rigging prep. Sheesh.
added text
Ron
18 hours ago, Landlubber Mike said:
That looks fantastic Ron - amazing job!  Thanks for sharing your techniques with us.
You're quite welcome Mike. I hope my details for making sails (and their required rigging) helps those who would like to add working sails to their models. I realize that for most, "working sails" on a stationary model - and not cruising in a diorama - is something that most will choose not to do.
Ron
Coming along nicely, Ron. Will the spritsail have water drainage holes added?
Thank You, druxey. Here is a slightly better photo showing the waterholes in the corners of the spritsail (lower).
I'm going to add a thin painted "rim" around the holes to indicate they're grommeted (stitched) around the openings.
Ron
Continuing Inspiration for sailmaking...a book of wonderful paintings... as well as my choice for building the casework for Camilla's diorama.
Within the last few weeks, I was fortunate to acquire a beautifully printed volume of 18th-century, aquatinted engraving reproductions in Naval Achievements of Great Britain by James Jenkinsa limited edition publication and 1817 homage to the British Royal Navy. This particular volume is also a limited edition reprinted one from 1998 by London publisher, Sim Comfort & Assoc.; the original edition as well as this latter one features fifty-one color plates along with extensive explanatory text that covers the subject of each color engraving. The beautifully-bound, large volume ("Octavo"size, about 14" h X 12" w) features the detailed artwork of one artist (Thomas Whitcombe) who was commissioned by publisher Jenkins to memorialize famous sea actions of the Royal Navy between 1793 and 1815. Uniquely, Whitcombe had been an officer in the British navy and his knowledge of warships was first-hand and intimate.
Every page reveals important and interesting details of the sailing warships in this era in both artwork as well as textual references and data. When I study these photos, I immediately think that these paintings are the "Instagram Photos" of the early 19th-century. Black & white photography wasn't invented for a good 30-40 years after the original volume was published.
The 1998 second edition book explains that the color pages of many of the original publication from 1817 were literally torn out and framed as wall paintings by those who couldn't afford to purchase original artworks by esteemed painters of the era. Although arguably the re-printed engravings in this volume may be perhaps even nicer than the original printing of 1817, I have no plans to rip-out any of these to hang in my shop.
I have been perusing the depictions throughout (all 51) as I lean into the final stretches of my build of HMS Camilla and her impending diorama. Admittedly, I'm still taking breaks from the tedious sail rigging.WhiteRiverCasing02.jpg.cc6646913d35d6d4eecf50700e6b5caf.jpg
HMS Camilla's diorama requires a "pan" of sorts to not only feature the completed model but contain the "water" setting as well. I have sourced a very specific architectural wooden millwork made from poplar. This millwork is normally used by interior finish carpenter artisans for door casings who go to similar vendors I'm purchasing this stock from.
Per my previous diorama depictions, I plan to make a simple, mitred-corner "box" with this millwork. The "height" of this casing is 4" with a thickness of approximately 3/4". The 4" depth will be wholly adequate to support the model's keel as well as allow for a varying water diorama depth; the casing's height also won't overwhelm the overall presentation. A straightforwardly-constructed 1/2" plywood base will hold the millwork decorative sides in place.
I haven't decided on the final colors for the casework but I am leaning toward a natural wood finish and then adding highlighting to the relief details with either a darker hue of stain or even possibly something more dramatic like a blue color stain (over the natural wood stain color - as yet undetermined). An accented coloration to the wood will flow into the details of the casework "carving." The carved details are, in fact, pressed into the soft poplar at the mill to form a continuous pattern. I  plan to order a length of 94" for my case (the longest available length) and because this is a custom order I've got to order soon as it will take a few weeks to receive it.
I anticipate that after I've gathered the "pan" materials it will take about a week to build and another few days to finish before starting on the diorama's water construction.
Back to the bench...
Ron
I just realized the second photo in my last post (carved wood section) may be slightly obscure without better context.
I'm starting to lean into the design steps of my diorama here because these considerations are critical to how I approach making water depictions. I believe several MSWer's will be interested in this step as well as the actual water making steps and materials.
I still have lots to accomplish with my sail rigging, but for the most part this has been explained in quite some detail. My next updates will show completed "sections" with their finalized sails and their extensive rigging (Fore, Main, Mizzen, etc.).
Looking ahead...
Here are a couple photos showing a prepared base where I've placed my completed model(s) temporarily into a shallow "pan" of custom architectural millwork. You can see the custom sides of the case, the plywood bottom and attachment blocks that fasten the mill-worked sides to the base. In this instance, the depth of the case to contain the ship and its diorama was only 1 inch (after attaching the 1/2" ply base).
In contrast, the sides for HMS Camilla's diorama will be 4" high, mainly for the subsequent creation of a turbulent sea with large wave action but also to have enough "depth" to accommodate the model's hull.
These photos are from my last diorama project that features an 18th-C Japanese village being visited by a cargo ship delivering supplies.
There are photos of this completed model diorama in my gallery;
The ship model is nearly complete (there was additional rigging to be added). In the background is model of a Japanese teahouse that was included. I had an idea of what I wanted to see as a completed setting but everything didn't come together until I started depicting a shoreline and landforms. The rice bales and the figure were key to my final vision of the ship's "mission."
This is a graphic of the millwork section that I used for the sides of this "Takes A Village" diorama. I'll acquire the 4" high casing millwork from the same vendor for my Camilla diorama. This graphic is chair rail molding and it will be turned upside-down for the case sides. I plan to do the same thing with the door casing millwork for Camilla's base. You can see that the height of the chair rail molding is only 1.5". The sides for Camilla's base will be 4" high; the sides will also need to allow for an inside measurement that is less the thickness of the plywood base (1/2"- maybe 3/4"), similar to my other diorama depictions.
Ron
After a nearly three week hiatus - and having dealt with The Plague (Covid's latest variant) - I was back in the shop this past week. And finally felt like a human.
It's good to be back - even with attenuated shop time - working on the final stages of my HMS Camilla (now King Charles' Consort!).
God Save The King.
Obviously, I'm also pleased to be sitting in front of my computer once again, posting photos and some text on this Build Log.
It's also good to still be around after a mean bout...I've had all my multiple inoculations, but it still laid me low for a while.
Here's a photo update of last week's progress on sail rigging.
The Big Picture: nearly all sail rigging lines have been completed: clues, sheets, bunt and bowlines. The Mizzen topgallant is skewed and needs tweaking. Once the sail rigging is finished, the rigging clips that temporarily secure the lines get removed as the tension from starboard-to-port or bow-to-stern gets properly balanced. Once this is completed, then I'll make numerous rope coils for the belaying and cleat positions. The coils will be carefully positioned and then glued with Liquitex matte adhesive.
All the sails have been "shaped" to show them as working sails; I also refer to these now as "set" sails. The sails will be have some dry-brush painted "weathering" effects added once their final positions are secured. More on this to follow.
A view of the foremast with all her sails. The bowmast (bowsprit) has two spritsails, a first for me. This sail rigging was a little tricky as I've found scant information on where the sail management lines belay. It's a very tight fit in the foc'sle for all the necessary lines. I had to add additional blocks and cleats to accommodate some of these lines.
Another view of the sails on the foremast from midships.
It's a tight fit at the foc'sle's stem! Running and sail rig lines at the jeers have yet to be secured. I do attach these with CA glue after they're properly tensioned and trimmed-off. Once appropriate rope coils/hanks are positioned, they hide the CA glue terminated falls.
I haven't determined the placement for block & tackle on the spanker (gaff-mounted) mizzen sail. I'm researching how and where to secure this particular sail, hence the large clamp holding it in temporary position.
Keen eyes will see that the main course carries no working sail; I'm fashioning a furled sail from silkspan only for this yard. The sail will be "foreshortened" and hauled to the yard with her buntlines and clues, and lashed to the yard. Unlike all her other sails, This sail will not have a core of bond paper as it isn't necessary and would be extremely difficult to fashion properly with the stiffness of the paper between silkspan layers. This will be the final sail to be mounted because I needed unhampered access to the mid-deck belaying points at the jeers and cleats.
Those who have been closely following my log will note that I’ve changed my mind on how to treat the large main course sail: I’ve wavered between: A. Omitting it entirely, concerned somewhat with what it visually hides of deck detail, B. Mounting a full working, billowing sail, or - C. A furled sail that hides only small details of it’s yard but completes the ship’s main, full complement of sails (minus staysails). As I’ve previously mentioned, I originally planned to add stunsails - the ones extended from the ends of the main courses and top yards - but these would have made the size of the overall model especially unmanageable in a diorama.
The starboard view of the fore deck. Those fore course and foretop sails are responding to a strong wind blowing across her open midships. Anyone who has sailed in a stiff wind knows that sails can take on dramatic shapes when they're closely hauled against the prevailing wind.
Another starboard view; a few braces and a couple clue lines for the topgallants and foretop are still on my check list.
I will note for others who may desire to add sails to this excellent kit that there is no sail plan included. Reference materials are available however, even these don’t deal with some of the realities of final ship configurations, especially on how and where the rigging lines were terminated. I consider this “creative problem-solving”, an exercise that some modelers won’t have the slightest interest in pursuing…
BREAKING NEWS
I just received the rest of Camilla’s “crew” who just arrived by Royal Mail (&USPS) from the U.K. In addition to Cpt. Pennypincher, there will be a full cannon team as well as a couple sailors recruited from Vanguard’s 3D printer in 1:64-scale…photos to come. Soon.
added text. Grammar fix
Ron
Sorry to read that the lurgy (pronounced with a hard 'g') laid you low despite the vaccines, Ron. Hopefully all will continue well for you now. The model is really taking on life: I can't wait to see her heeled slightly in her sea!
I've been following Camilla's progress very closely . . . she looks fantastic and now I'm thinking that I may be fitting sails to my Sphinx after all.  What a superb model you're making and I can't wait to see how the Vanguard crew shapes up!
Nipper
Current build:  HMS Sphinx 1775 - 1/64 - Vanguard Models
On the drawing board:  Dutch brig "Irene" 1815 - 1/64 - based on HMS Cruiser - Caldercraft
Completed build:  HM Cutter Alert 1777 - 1/64 - Vanguard Models
2 hours ago, Blue Ensign said:
Great job on the sails Ron, she is looking wonderful.
Glad you've recovered from the ‘plague’
B.E.
Thanks, B.E., as anyone who has also experienced this indicates, it’s no fun. Symptoms can run the gamut of unpleasantness.
Your Sphinx is looking beautiful and I wholly agree that your superb little boats will look perfect, “de-cluttered” from the ship’s skids. Congratulations.
Ron
Thanks, druxey. Having had all the “protections” I have no idea how the sneaky virus made it through my layers of antigens! I am feeling so much better now and besides, the virus has no idea how many more models I am determined to build!
Ron
Nipper
Thank you, Nipper, your comments much appreciated. Should you choose to have your Sphinx harness the wind, I hope you’ll be able to glean some details from my photos and techniques that might make the task rewarding- and fun. Notice I didn’t include the word “challenging,” as I suspect you already are aware of this…
Ron
As promised, here's Camilla's recently arrived crew: two proper tars and six cannoneers (including a powder "monkey").
I will paint them over the next week or so when I'm needing another break from the final sail rigging details. These 1:64-scale 3D printed figures are impressive. The height of the figures is approximately 1” or 28 mm. Once painted, the detail on all the figures will make them come alive.
I couldn't resist arraying them on the poop deck of my HMS Ardent (64). It's also 1:64 in scale and I wish I had these when I was finishing-up this build from 2014. I am tempted to possibly grab another set of sailors from Chris expressly for this model.
A close-up view of Cpt Pennypincher and two Royal Navy "Tars." The bases will be removed; I'll use either a Dremel or even a disc sander to remove them so they all will stand on their feet properly.
This photo’s color is reasonably accurate for the unpainted resin. The shirtless and shoeless "powder monkey." The dashing sailor with hat, jacket and kerchief. I need to do a little research on late 18th-C sailor garb before cracking open the paint jars.
Captain Pennypincher stands along side a female Grey Whale and her calf. After completing the above model I wanted to give some indication of scale and there simply were no good, accurately-sized figures available at that time. I searched for the next closest thing which - as it turned-out- wasn’t perfect yet helped to convey the enormity of the vessel: the whales are reasonably scale accurate to the ship. The Pegasus serpent pedestals? Not so much...
I haven't decided WHERE I'm going to place my minimalist crew on Camilla. Perhaps on her stern q'deck, like I've shown here. The cannon crew is for a long cannon, not a carronade, so this position may not work for the six figures. We'll see...
Typos/added text
Ron
8 hours ago, druxey said:
You could always 'bash' the figures' poses....
Good idea . . . I was thinking of doing the same with Chris' figures to create a larger crew.  I've bashed an Amati figure (metal) to make a hatless captain to go in the great cabin, but I haven't yet tried bashing a resin figure.
Nipper
They look excellent figures Ron and have come along at just the right time to man your Camilla.
I'm not sure the athletic member of the gun crew with the admirable 'six pack', whose job it is to insert the charge down the barrel, would be pleased about being called a powder monkey.
Perhaps Chris will produce a young boy, short and nimble, to transfer the charge from magazine to station. 😉
B.E.
Edited by Blue Ensign
B.E.
Or even a nipper?!!
Nipper
5 hours ago, Azzoun said:
Great work painting the captain.. looking forward to seeing it all together.   urg, i should start a build log..... maybe ;)
Joshua
Yes you should, Joshua.
The last sail and its rigging...
There will be a couple installments to this post as this last sail gets pre-made and then mounted to its yard. Hopefully, I'll be able to carefully fashion it into an acceptable shape resembling a "dangling sail."
After studying many 17th & early 18th century ship paintings (the photographs of the era), I decided to bend a hauled mainsail to Camilla's main course yard. I then tossed a full working sail into the waste basket that I'd made previously. I had also considered creating a fully-furled one, gasketed tightly to the largest yard on the ship before deciding to try something different.
Since my model shows her with a majority of her sails deployed and "at sea and in action" I decided to mount the partially brailed large sail across her midships. So many of the paintings I studied for reference showed this particular sail in this state (in many cases, also the foresail), especially in sea actions. I concluded that rarely would a patrolling ship have furled sails unless they were headed into very foul weather, anchored or in safe harbor.
Starting from scratch, I've created a main course sail with a single layer of silkspan, unlike her 10 other layered sails. This overall piece is roughly half the size (vertically) of a full sail. and is the full width of it's corresponding yard. The single thickness of silkspan will allow me to more easily shape it and then apply a fixative to the resulting folds to show a loosened sail, ready to be quickly hauled when needed. I liked the whole idea of this working sail ready-to-go, rather than one constrained. I've made furled sails but I've never attempted to create a partially hauled and brailed one. We'll see how this turns out!
To a single layer of previously colored silkspan (a leftover from Camilla's previous sailmaking), I carefully drew cloth panel lines in pencil to only one side (bow facing) and then added reinforcing tablings to the head and to a central portion of the foot. The roband ropes were added to the head and two holes for the bunt line cringles were added to the foot. To a portion of the foot and fully along the leeches I added a boltrope and the clue cringles as these will be prominently seen once the sail is in position. I anticipated the tabling reinforcements would be important as a single layer of silkspan would be subject to tearing and ripping easily with extensive finger manipulations to come at a subsequent mounting stage.
The sail's corners are folded over to show the approximate position of these clue corners once the sail is bent. The walnut dowel (from the kit) is shown simply for scale reference and is about the actual diameter of the main yard.
Camilla's Mainsail will be mounted here, rigged to its control lines and shaped to show a partially hauled sail.
grammar
Ron
