14 minutes ago, CDW said:
Anatomy of a rusty exhaust stack
And the very very top of it including the stack cover would be powdery black from the soot... (that is if it was an operating tractor)
Beautiful work my friend.... The heavy iron master...
Edited by Egilman
Quote:
Observe the hand crank on top of the engine cover. The crank is connected to a vertical shaft that makes a 90 degree turn toward an object on the side of the engine. The hand crank is used to start the engine vis a vis a “pony motor”. The object on the side of the engine is the pony motor. When the pony motor is started using the hand crank, this auxiliary motor actually is the starter for the Diesel engine. Not an electric start. As a matter of fact, one of the first things we are taught when working on a gas pipeline is to quickly throw a rag over top of the air breather in the event we ever strike and rupture a live gas pipeline. Unless choked for air, a Diesel engine will rev up uncontrollably once it starts breathing in natural gas.
Nice work on the stack. Looking good. 👍
Like EG said, need more soot around the top of the stack. My Case tractor was like that. And we kept a bucket over top of the exhaust unless we were running it.
Ken
Started: MS Bounty Longboat,
Fantastic  Work  - Really nicely done.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Very nicely finished out and detailed Craig.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
As said by others, it looks like a real thing.
Dan
