Very clean and crisp! A joy to look at Augie. Great to see you getting some bench time in again.
A question, I struggled with my ladders. Even with a jig I felt they were not a consistent as I would like. How did you do yours?
Sam
Current Build Constructo Enterprise
Augie, as mentioned before I have the Confederacy waiting, and I enjoying every little bit of your build log.
Question: Do you think it would be possible to plank the deck with thicker strips and no false deck; type Bluenose? Just curious.
Respectfully
Almost anything is possible, Dr. Per !!  The decking strips supplied in the kit are 1/16" thick and the false deck is 1/32" so you would obviously need 3/32" thick planks.  However, as you have the kit right there, you will see that the false deck includes deadly accurate laser engravings for positioning the hatches, masts etc.  It also provides a nice solid base to lay your planks over.  When I did Chuck's Syren, there was no false deck and that worked out fine.  But to be honest, laying the Confed planks on top of the false deck just went a lot easier.  So, IMHO yes, it's possible ---- but I wouldn't do it myself.
Can't wait to see your rendition of Confed.  She's a fun project.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Augie - I wouldn't hold my breath on Dr. Per actually starting the Confederacy. He currently has at least 3 projects in flight. :o LOL
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
you would have to take into account for the framing........that might take up some thickness.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Augie, I have been following your Confederacy project and enjoying it very much.
You are doing high quality craftsmanship and taking excellent photos. I am
building the same model so your tips and advice are very helpful. Keep up
the good work and thanks for sharing.   Chizelguy Pete
Thanks Pete.  How about brightening our day with a build log???
Augie
Previous Builds :
augie
Could you also pm a copy of how youdid the ladders. I have not had good luck on previous models.
Flying Fish --  MSW
Essex ---  MSW
Constitution  --  MSW
Confederacy -- MSW
Philadelphia -- MSW
Chaperon -- MSW
San Felipe -- Panart
Portland -- Bluejacket
Just got caught up on your log Augie...whew, I have been gone a long time. I still say your work is exquisite, and breathtaking. I can only hope to be half as good as you in my own building.
BTW, I was in Denver last weekend, and plan to return in 4-6 weeks, do you know of places to visit to see models?
Robbyn
If you risk nothing, you risk everything!
Current builds
Syren (Model Shipways) version 2.0
AL San Francisco II
Mordaunt (Euro Model)
Completed Builds
18th Century Longboat designed by Chuck Passaro
In the closet
Battle Station
Al Charles Morgan (1980s version)
She looks as fresh as the day you stepped away! Nice details, your companion ways look superb ;)
Bill :)
Passion is Patience...and I am a carpenter in any scale.
Current build;  Endurance - 1:70 scale, Occre
Current build;    H.M.S. Surprise - 1796, 1:48 A L
Maritime museums are not really big out here, Robbyn.  Unless you like Prairie Schooners  :) .  But if you contact DSiemens here on MSW, he's a member of Rocky Mountain Shipwrights and he might have some suggestions for you
Augie
Previous Builds :
Gun Preparation
Each gun port on the gundeck requires 4 eyebolts to secure the gun tackles and breech lines.  The holes were drilled and the upper eyebolts fitted.  The lower eyebolts will go in with the breech lines:
As a review, I'll be using Chuck's brass canon from the Syren Co. in place of the kit-supplied white metal canon:
You can see a small bit of flashing in the trunion hole in the uppermost canon.  For this purpose, keep a 1/16" drill bit handy for (gentle) easy removal by hand (12 pounders) .  In the case of the smaller 6 pounders, a #67 bit will suffice.  Also, keep a small sanding stick ready to smooth the ends of the trunions.  I cleaned the guns by soaking in acetone before fitting the trunions.
Here's what the guns look like with the trunions installed:
Although one could choose to solder in the trunions, I chose to simply use the smallest dab of thick CA for this purpose.  It gives you time to work .
The next step will be fitting the brass rings for the breech lines to the guns.
Augie
Previous Builds :
Augie, those are some nice looking cannons! I wish Chuck was offering hem back when I bought mine. I would have paid half the price I think.
I dont envy you putting all those rings etc together. I only have 14 to do and find after stropping 2 or 3 blocks I am done for a while.
Looking forward to your next update.
Sam
Great guns, Augie.  Obviously well worth the time and investment.  Will you be blackening or painting the barrels?
Thanks all.
MARK-  I'll be painting the barrels.  That way it will be reversible.  I need to check Ben's log to see if he used only 20 coats.
Augie
Previous Builds :
What a difference in the quality of the guns! Well, you are awarding a magnificent built with the right guns!  :)
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
No 20 coats on the cannons Augie!!
I pickled them in vinegar! If you use CA for the trunnions DO NOT pickle in Acetone, it is a CA debonder, as I found out.
As for paint, I used tamyia primer in the spray can which gave a great even and light coat without hiding details, then as recommended by some scratch builders I tried the black automotive flat black from Testors and was very happy how they came out.
Ben
Going to send you a PM in a little mate, you might find it handy.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
PM received.  Many thanks, mate.  I love the fact that this Forum provides a mechanism to receive valuable input from shipmates halfway around the globe.
Augie
Previous Builds :
Chuck's cannons are great. I have bought a few myself.
I am really enjoying following your build log. Stellar craftsmanship!
- Tim
At 700 HRS. into the build, it's time to finish off the cannon barrels.  We'll be using 1/16" eyebolts with just a short length of the base left to insert into the gun:
The hole was drilled with a #76 pin drill at an angle so that the ring sits hard to the small knob.  A very small dab of thin CA was applied prior to insertion.  Here's the 32 gun cannon 'forest' ready for painting:
Now ready for painting.......see you in 2 weeks!!!
Augie
Previous Builds :
Augie,
Looks great!
What will you be painting them with?
Thanks,
Tim
