Fillerblocks
All filler blocks are glued
Sand evenly with the angle grinder 😇
After a few minutes :dancetl6:
Dust, dust, dust.
Never do this indoors 😷😉
The final sanding was done by hand.
The base for the hull is ready. With all the extra plywood and filler blocks, this is a solid base that will not warp later.
What is already noticeable is the pointed shape of the bow. I did not expect this at all from a carrack and certainly not from one of this size
20230405_184123_1280.jpg.3c6cd2c5e8c0855a9e73bc7cf2b21098.jpg20230405_184235_1280.jpg.4a944efc8014dcf847068499ac875ec0.jpg20230405_184305_1280.jpg.72d6fd670a86be00e5915c6277b7b704.jpg
In the meantime, i have looked at where and how wales planks keel etc.. come.
Planks (oak) in the lower part of the hull were 10 cm thick. Respect to the builders 500 years ago for getting this done
The position of the wales and decks on section 1 3 5 6 8 and 10
The stern has also been studied.  Although not proven but also not disapproved. two stern chasers will be provided
20230401_142906_1280.jpg.2b7f45aa990b1823590ac29314b03475.jpg20230401_142959_1280.jpg.87a74927b5d0c9ca8da043a52397da3f.jpg
to be continued, thanks for following
1 hour ago, Baker said:
Fillerblocks
Dust, dust, dust.
The sanding job looks very smooth and precise.  How did you preserve the exact curves of the bulkheads when sanding down the filler blocks on each side of them (i.e. how did you avoid also sanding the bulkheads down at the same time)?
Thanks.
It is best to give the bulkheads a dark color.
Then it is sanding off the excess material, except for the parts in the dark color. And regularly testing with a plank until the shape of the hull is correct
The rest is practice, experience and "fingerspitzengefühl"
Thanks for the comments, much appreciated 👍
Determine the position of the lower wale with the laser.
The dimensions found on the sections are plotted on the hull. The laser is very useful for this purpose.
20230406_181903_1280.jpg.9faec694d94d82084c1b383c5cff5c0e.jpg20230406_181813_1280.jpg.4ad6687734c5d72b1d0ade7f62dce09f.jpg20230406_182103_1280.jpg.c884f547fbcc853fab162831fdbeda2b.jpg
The "dummy" wale in place
With this dummy as example a line is drawn in pencil where the real wale comes later
Half a day of free time and good weather
and cherry firewood becomes cherry shipmodel wood
20230411_140219_1280.jpg.f1d22bcd3a000653005b9068c0b0a340.jpg20230411_145945_1280.jpg.09068689a4cb0a692bafb368c24e66a6.jpg20230411_145953_1280.jpg.b1a44fb98e36d70021b922e245f47997.jpg
A first batch of different thicknesses
and a batch wood for planks, wales and keel.
Now i have to make the complex keel out of 3 pieces, each with different shapes and thicknesses
Thanks for following
Love all your work Patrick and this will turn out to be another gem!. I wouldn't have the heart to burn cherry wood, glad to see you're making great use of it👍
Michael D.
Patrick --- Just catching up - as always your research is top notch 👏
Regards,
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Nice work and good looking wood.   Are you saving the small off cuts?  If so, to use in the fireplace, soak in water for several hours and then toss them on once the fire starts making the red coals.   You'll get a very nice smell.
13 hours ago, Snug Harbor Johnny said:
  Your progress is impressive ... This is bound to come out well.
thank you,  with time and patience this will one day become a model
Michael D.
Thanks, this is verry good wood for model making. Not too hard, not too soft, and bends fairly easily
Regards,
Thank you Michael
Good idea
But I'm going to recycle all of this nice wood.
A ecologically built ship model 😉 and all other wood into the stove  😇.
The keel,
The keel consists of 3 parts. The front and back part are made of elm, the center part is made of oak like the rest of the planking.
So my center piece is made of cherry, the others are made of ramin (the last leftovers from my previous project).
At the front and rear there is a groove for "stealers" that are intended as a filler between the keel and the garboard.
20230415_071947_1280.jpg.c479422a3856d430dd672e6265628717.jpg20230416_103358_1280.jpg.1af5c53435452ac2e8c464eb0efedb35.jpg20230416_103408_1280.jpg.6c911427522c4f0f9179dc5cb2a3baef.jpg
preparation for the sternpieces
The first piece of the stern
Then the keel is glued
And the second piece of the stern is also glued.
This piece is now way too long. Shorten it later is always easier than lengthening 😉
The scarf between keel and stempost did not survive time.
So there is some space for a "free design"
scarfs in the keel
20230422_074325_1280.jpg.b453b1fb7806bbdc8d29395184c8cb5f.jpg20230422_074333_1280.jpg.a4c9bee35a93b57412b1138c9c7ebc0a.jpg
Bringing the keel and stempost into the right shape will be done later when the planking is sanded.
Next to do,  the stern assembly.
The stern assembly
The intention is to achieve this
The plywood needs plastic surgery 😉
Glue the first part
second part
and the final last parts
The keel is adjusted.
And, it looks like on the drawing 👍
Planking (from keel to first wale)
Plank dimensions
Thickness : 9,4 to 10,5 cm (yes, about 4 inches).
width  23 to 47 cm.
length : 1,47 to 9 m.
Wale dimensions
thickness : about the thicknes of a plank + 11 cm.
length 3.25 to 13.8 m.
scarfs between 2 wales 71 to 180 cm.
shape : :default_wallbash: see further in this post....
Planking diagram
green color : the 2 stealers in front and back
Red color A very wide plank at the bottom of the bow. I'm going to replace it with a less wide one, otherwise I could get into trouble
Bleu color : to be studied later.
Construction of the wales.
For some reason they gave them a rather illogical shape.
I made a scraper in the desired shape
method clamp the wood to a flat plate
hold the scraper at an angle to rough shape
finish with the scraper at 90°
result
The cherry wood bends easily
After drying it is glued to the hull
Planking is also started
20230428_102147_1280.jpg.5dbbba6d6acfc19ec1bde3d0285cdcdd.jpg20230501_091621_1280.jpg.3e300edffdf502250fd3bcd4bc6e33fc.jpg
assistant is supervising ;)
Thanks Jeff
But it would be nice to know why they used this specific shape for the wales.
totally illogical in my opinion.
Planking the lower hull, progress.
I'm kind of slow in planking, the idea is to do an update on this about every 2 weeks.
made an extra batch of planks.
Planking
transom
16th century planking is something like ordered chaos (my idea). that's why there are pencil lines and notes all over the hull
and sometimes things go wrong
a pencil line is drawn
a simple but effective solution ;)
problem solved, the next plank will fit
Current status ( ps, the wale is not as bent and bad looking as in the picture)
And building this way gives a nice space under the model to organize all the tools
Planking update
At the bow there is a very wide plank. Why??.
An extra wide plank
The plank is first made approximately on the correct arc
Made wet and bent
20230513_192756_1280.jpg.75757e7fac752f30edc99a3b8170af30.jpg20230513_192935_1280.jpg.750dbfbf43be89d68dbf31b1d7e8ffa7.jpg
ready to glue
done
work in progress
20230516_121943_1280.jpg.cae18632f8b1120429ad3421ae123870.jpg20230527_070226_1280.jpg.6d93eeb546f4b206449a429d50f5f585.jpg
current status:
Looks good, so far. There will be a lot of sanding to do...
20230603_160737_1280.jpg.3e247738d2c445320903e1b27089b945.jpg20230603_160751_1280.jpg.9f90c0bac7eef6dec18ebcd41f4ac160.jpg
Made an investment for my retirement.
Went on holliday, and found a new toy in southern Spain  :pirate41:
https://en.wikipedia.org/wiki/38.1_cm_/45_Model_1926_naval_gun
Quote
They are joggle planks. They are visible on the rest of  bow - they are very eroded, but they are there. Look at the pictures I added.
I think some similar of them are on the aft. BTW, look carefully on the hull. No one plank is the same, each one is the original😉
Jan
Finished:       Ark Royal 1588
                      Mary Rose 1545
                      Arabian Dhow
                      Revenge 1577 ( first attempt )
                      La Couronne 1636
                      Trinidad 1519
                      Revenge 1577 ( the second one )
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
On the table: Sovereign of the Seas 1636 - continuing after 12 years
All of them are paper models
I think it's a custom made plank
In this case a plank that is the same width as the two connecting planks together.
I think that back then all the planks were unique. Adapted to the situation and determined by the existing timber.
So there is no particular need to attach an oversized plank at this point t.
It just happened that way during the construction process.
Alvb
Edited by Alvb
11 minutes ago, Roger Pellett said:
In reality it’s a dropped strake.  As the strakes approach the bow, the hull girth becomes less.  By taking the place of two strakes very narrow planks are avoided.
Same idea on a steel plated hull ( below the hawse pipe)
Roger
Thanks Roger.
I knew roughly what it meant.
but did not get it worded correctly in the English text .
You are answered already instead of me, thanks a lot. It was beginning of the 16 th century... nobody know if these planks leads straight to forward, or they again divided to two before the bow.
The best way is not to complicate the model by unimportant things. What if on the other side of the ship was the planking different ?....
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
1 minute ago, firdajan said:
Baker, Alvb, Roger: You are answered already instead of me, thanks a lot. It was beginning of the 16 th century... nobody know if these planks leads straight to forward, or they again divided to two before the bow.
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
