good evening every one
thank you for comments and likes
day 13 hull faired
the weather here has been pants recently, with snow and rain, so i have been doing some smaller projects on the build, but i will post photos later on in the build as I would  like to keep this log in some sort of order, (never achieved that before)
the deck has been sanded and varnished with a water based varnish @50/50
to day a few days delay the hull went outside to be sanded, brilliant, oh thats getting hot fizzle bang me mouse blew up
anyway an trip to Wickes (other palm sanding tool outlets are available0
this is what i have now
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
On hold
MHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72
U552 German U Boat - Trumpeter -
1/48  Amerigo Vespucci     1/84 - Panart-
HMS Enterprise  -CAF -  1/48
Finished
Belle Poule 1834 by Kevin - OcCre - 1/90 - French frigate - started June 2024 - -
Hercules by Kevin - OcCre - 1/50 - Tugboat - Finished - May 2024
Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished
 Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished
Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
1 hour ago, Glenn-UK said:
I need a new palm sander also.
I have noticed that you have not removed the upper and lower gunport strips from the quarterdeck doorway. Is there any reason for this?
The fairing looks good, so the planking should not be a problem for you.
ooops on the door way, im sure a couple others things are still needing attention, and when i got back in i found that i had forgotten to put the bracing beams inn thats how strong this build is
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
On hold
Finished
Good evening everyone
Day 14 port side Gun port templates fitted
well i never expected to be at this stage after 2 weeks, but here i am, and loving it, and i have not had any issues to criticize the build, or instructions,
after the hull fairing i test fitted the gun port templets, no other sanding was required
the bottom of fwd template forms where the first run of planking under it goes, so a pencil line is drawn, the rest of the plank aligns along the top of the port sill , at this point the template can be removed
IMG_5911.thumb.JPG.689da0beaf559863945d522f4e434f5b.JPGIMG_5914.thumb.JPG.73b598139ad1ef91b512c7dbe48846a1.JPG
first plank
2nd plank
IMG_5917.thumb.JPG.20347f5deb1dcd99326d32516b459bbd.JPGIMG_5919.thumb.JPG.a6f0871813beff9f351bb28d885dcc86.JPG
the after template fits on the top of the 1st plank and lined up with the top right corner of the last gunport, instructions need to be read to be aware of where the glue is applied, as a section of the framework has to be removed at a later date
a templete fits between and the area over the ports is covered, using limewood
rough opening of the gun ports when the glue has dried
IMG_5922.thumb.JPG.9c19311c9c9a2bc1e6706c6cab6525d9.JPGIMG_5923.thumb.JPG.20fff39320553e6ed2d5767875496471.JPGIMG_5924.thumb.JPG.c520e365462468b1177f175fc9b440b4.JPGIMG_5925.thumb.JPG.a8d34f433a43c3acd56988af6997e670.JPG
Edited by Kevin
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
On hold
Finished
You are moving along at quicker pace than I expected. All the work looks really good.
Jim
Current Build: Fair American - Model Shipways
Awaiting Parts - Rattlesnake
On the Shelf - English Pinnace
                        18Th Century Longboat
I stand firmly against piracy!
good evening everyonr
day 16 1st planking
port and stbd side templates fitted
stern tuck, caused me some aggro fot a couple of hours, so the fixed planks were cut back and the stern was re faired allowing the 3rd plank to twist and turn
Edited by Kevin
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
On hold
Finished
57 minutes ago, Glenn-UK said:
The planking is looking great.
ty glenn, it did take me a good few hours to get them right, and only then after cutting back the first two under the template and re faing the stern
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
On hold
Finished
26 minutes ago, James H said:
Those planks look great as they go under the tuck.
Thank you James
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
On hold
Finished
Nice tucking, Kevin.
Ron
Current Build: HM Gunbrig Cracker #13 (HM Adder Gunbrig)
Completed Builds: Grace & Peace (Wyoming, 6-masted Schooner), HMS GrecianHMS Sphinx (as HMS CamillaOngakuka Maru, (Higaki Kaisen, It Takes A Village), Le Tigre Privateer, HMS Swan, HMS Godspeed, HMS Ardent, HMS Diana, Russian brig Mercury, Elizabethan Warship Revenge, Xebec Syf'Allah, USF Confederacy, HMS Granado, USS Brig Syren
Very nice job on the planking. Everything looks nice and symmetrical 👍
Jim
Are you using nails only when you need them?  Also, did you leave all the char on and remove it once the keel and its parts were complete?  I have the Sphinx on my table and am watching your build with great interest 😃
18 minutes ago, Glenn-UK said:
Hello Kevin
I have just noticed, when looking at your build log, that you do not seem to have added the two stern filler parts 29 to either side of the keel under bulkhead 18, as per build steps 82 and 83.
Glenn-UK
they are in now, about an hour ago, thank you for keeping me in check
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
On hold
Finished
i use nails all the time and then remove them after the glue has set, the only char removed so far has been for fairing of the hull
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
On hold
Finished
Hiya Kevin mate,  found  your build at last,   what a fantastic  build it is - you are doing a wonderful job,   looking forward to each and every  post.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
7 hours ago, Malcolm Greig said:
Kevin
Excellent build log, thanks for posting, very interested and I'll will be great to tag along and follow your progress.
regards
Malcolm
everyone is welcome to follow my trials and tribulations of wooden ship building
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
On hold
Finished
9 minutes ago, Morten said:
Exelent work on a exelent kit.
thank you. we look forward to seeing your build soon
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
On hold
Finished
good evening everyone
Day 18 1st planking
as soon as i left the make up of the hull, i have had to start thinking about things, and this has resulted in some redo's, lol no matter how much fairing you do, there is always more
anyway the hull is is about 50% done and although bit messy in places, i have a sound basis  to work on
and yes i am still missing one part number 29 stern post filler, and the one fitted need working on
Edited by Kevin
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
On hold
Finished
day 20 1st planking
the bow is 1st planked, - absolutely nothing special, but will serve as a good foundation for the 2nd layer, i look forward to many hours of sanding before that happens
the stern will be completed in the next day or so
Edited by Kevin
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
On hold
Finished
good evening everyone,
day 21 1st planking port side complete
i needed to fair the parts 29 on the stern post, so i then continued with a rough grit sanding pad and gave the hull a once over, i was real happy with how it turned out, no where ready for the top coat though
i am about an hours work from completing the stbd side, will try and finish that tomorrow, but the boi is in for an operation at the vets, so i might be to stressy for that
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
On hold
Finished
Good luck at the Vets my friend , man can you build fast,very nicely  done , is an understatement  WAH  !!!
"Start so you can Finish!"
In progress:
Astrolabe 1812 - Mantua 1:50; Golden Hind - 1578-Air Fix.
In queue:
Pegasus - Amati 1:64
Completed:
The Dutchess of Kingston - 1:64 Vanguard Models 🙂
Santa Maria - 1:64, La Pinta - 1:64, La Nina - 1:64, Hannah Ship in a Bottle - 1:300, The Mayflower - 1:64, Viking Ship Drakkar -1:50 all by Amati. King of the Mississippi - Artesania Latina - 1:80  Queen Anne's Revenge - Piece Cool - 1:300  The Sea of Galilee Boat - Scott Miller - 1:20
