Antony the section looks like it is nearly finished. The film you mentioned for the copper plates how does is follow all the surface modulations or is it some sort of spray?
Michael
Hi.
Thanks for your nice comments and likes :)
Michael . The film is very thin and flexible 100% clear plastic. It comes in a roll in many widths.
Needs a lot of care putting it on as there is NO second chance to get it right.
Would not be suitable for normal hull as there is very little stretch in the film.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
  • 2 months later...
just caught up with your build - Fantastic
the black card as caulking is so much better than the permanent marker way
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Hi Divarty.
Thanks for your kind comments :)
I must finish this soon as I now have two ships in dry dock.
Just got to cast the rest of the cannons. And install all the bits onto the different decks.
Make a stand and case and it's done.. Sounds easy in words doesn't it :)
Starting after the half term break.
Thanks for looking in. Antony.
Completed Mayflower
Antony,
I found your log today. Your section looks really wonderful. I love these big scales
Regards Christian
Antony,
I would love to see the steps you follow in putting film on the copper plates.  I have been trying to figure out what I might use for my Syren.
thanks
Richard
Richard
Member: The Nautical Research Guild
Hi Richard.
I would not recommend using the film on a curved hull. Very little stretch.
You can spray on a film. Link below.
http://www.ipmsstockholm.org/magazine/2002/11/stuff_eng_tech_sea_water.htm
I have NOT tested this but it should be fine.
Regards Antony.
Completed Mayflower
  • 8 months later...
Hi.
Well its the end of this build and its been a nice steady build.
Started in September 2013. with a couple of breaks IE summer holidays. Daughters wedding.
A few photos are in order..
The Enclosure is made from Fire resting poly-carbonate, as its Health and Safety thing.
Top .bottom and back are 12mm plywood.
There is also a Mirror at the back of the model..Gives it more depth. Doctor Who cheat.
The Red button is a press to make switch. and holds the power on for 30 seconds.
Lights that are in the Hold and Orlop deck flicker like oil lamps.
The two Dolphins are carved from Boxwood (not by me) . Local shop sells then cheap.
I did not put gravel into the hold in order to keep the weight down.
The drawings are bits that I had lying around.. They cover the plywood nicely.
The tape measure is showing the physical size of the enclosure
I really appreciate the help and encouragement you people have given me throughout this build.
I would also like to thank my friend Roy for supplying my with the timber for the build.
And of course the person who keeps everything running in the house while I have my head buried in the model. Marian.
And all the likes... There are soooooo many. :)
Any questions.. Please ask.
Regards Antony.
Completed Mayflower
Antony,
    I have been watching this from the start. You have done an excellent job, something to be proud of. Thank you for sharing this with all of us.
Wacko
Wacko
Joe :D
Go MSW :) :)
Beautiful build, Anthony.   Are they any more pics of the build in progress? I was beginning to think that you had given up on this.
I just found this wonderful build.  You've done such a beautiful job I'm sure I will refer to this build many times.
Bob
Current build:  SS_ Mariefred
Hi.
Thank you all for the likes.
I am looking forward to delivering it on Monday PM.
Regards Antony.
Completed Mayflower
Hi Paul.
Thank you for your nice comments.
I always keep my saw blades sharp and feed the wood into the saw at a slow and constant speed. Also keeping the wood pressed against the guide.
If the wood is on show I will pull a sharp edge across the length. This makes it almost planed finish.
As far as the grates.. There are some brilliant tutorial on MSW that cover making gratings.
Most of what I have done I have learnt from this Forum.
And welcome to MSW by the way.
Regards Antony.
Completed Mayflower
Hi Anthony,
Beautiful workmanship!!! You have created a detailed and accurate cross section of this famous ship. Congratulations on the completion of your build
I'm looking forward to the next one
Cheers :cheers:
Jeff
Current Builds;
 HMS Supply
Completed Builds;
AL Swift 1805; Colonial Sloop NorfolkHMS Victory Bow SectionHM Schooner Pickle
I am another one who has followed your lovely project from the start - congratulations
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
  • 10 months later...
Hello Shipmates.
A large update as I have had a lot of time building.
I made up some mesh for the hammocks my using some tights (fishnet) stretching them and then applying PVA glue until dry. The knit does not show when in place on the ship.
The Hull completely planked.
Upper part showing planking. Port.
Upper part showing planking. Starboard.
Tree nails Holes drilled on Quarter Deck.
Coppering the Hull completed.
Nice and shiny. :(
View into the decks with the hull upside down.
Close up of the copper plates. Port.
Close up of the copper plates . Starboard.
Have also faced off both ends of the ship (Fore and Aft ) makes it mush more pleasant to look at :)
Will cover the copper plates with a very thin film used to cover book covers. This will stop little fingers pulling off the copper plates.
Regards Antony.
Nice and clean plating-structure Antony,
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils.
It's much easer to do on a cross section as you do not have the curves to plate.
Not looked at this build since it was finished.
Thanks for the likes.. I missed seeing these.
Regards Antony.
Completed Mayflower
  • 1 year later...
Anthony,
Thanks for visiting my build - Allowed me to discover your Amazing Victory -you are indeed a master builder - stunning work!!
Regards
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
  • 4 months later...
Hi John.
Thank you for your kind words.
I am a beginner compared to most builders on this forum.
What I like most on this forum is the vitality of skills members are willing to share to improve the skills of others.
Regards Antony.
Completed Mayflower
  • 9 months later...
