Good evening everyone
all holes drilled for the steps
any mould lines that i can see have been sanded out
Hull sanded down several times with 1500 wet and dry
tonight i was playing around with the grill for the seawater inlets and outlets, the grill is over scale - but will support possibly some sort of netting over the top
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Goodnight
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
the funnel area progress, finding i am spending more time worrying about the weathering than the build it's self so have told my self no more painting until i am much further ahead, i am constantly checking build logs to avoid doing to much that i may rip out , the fitting kit that i dont have at present, replaces so much of the original (or should i say enhances a lot of the original)
there are 3 hangers on the build one of them is a double am hoping to be able to do some work so you can possibly see some of the internals
VERY NICE WORK!   :)
Cheers,
Tim
Tim
Future Build:
  • BlueJacket - USS Kidd (Fletcher Class Destroyer) Solid Hull
  • BlueJacket - U.S.S. SAMUEL B. ROBERTS, DE413 | Butler-Class Destroyer Escort
  • BlueJacket - 310' Destroyer "The famous "four-piper" of both World Wars"
  • Model Shipways - Pride of Baltimore II (Topsail Schooner)
  • Model Shipways - Willie L. Bennett (Chesapeake Bay Skipjack)
  • Constructo - Pilar (Ernest Hemingway's Fishing Yacht)
  • Sergal - Race Horse (Bomb Ketch)
  • Classic Warships - USS Salem CA-139 (Heavy Cruiser) Resin Kit
  • Pen Duick Schooner - Half Hull (Scratch Build)
  • CSA Submarine Hunley (Resin Kit)
  • Classic Warships - USS Washington BB-56 (Battleship) Resin Kit
  • Blue Ridge Models - USS Alaska CB-1 (Resin Kit)
Completed Builds:
Member:
Hampton Roads Ship Model Society
Hi Kevin,
I assumed the sea water ports would be a Photo Etch supplied part?
I wonder of flyscreen mesh which is glass fibre net would prove suitable, very thin strands and holes small enough to keep the mozzies out.  anyway just a thought.
Cheers
Slog
(PS I can post a picture if you like, didn't want to clutter your log)
Edited by Captain Slog
_______________________________________________________________________________________________________________
HM Bark Endeavour (First Wood, On Hold)
Borodino (1:200 Card, Current Build)
Admiral Nakhimov (card 1/200)
Mazur D-350 Artillery Tractor (1:25 Card)
F-8 Crusader (1:48 Aircraft, Plastic)
Hi Kevin,
Cheers
Slog
i was aware that the Grill were not included - but the suggestions quoted in another site that i follow - they have stopped selling it
, i have some netting (tule) that i am unable to use for the Victory build, and will most likely use this over the mesh already in place, might give it some sort of depth/ - even though the people that will see it when it is collecting dust on the shelf will say " why did you drill holes in the side - wont that make it sink"
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
And so it goes on - a decent airbrush now ordered, i dont suppose it would ever be used on a wooden build, for those in the know Harder-Steenbeck-Evolution-2-in-1-200-wi
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Hey Kevin.
I got one of those about 4 months ago for mini painting - loving it.  I have no experience with any other decent airbrush, so can't compare.
I am planning to use it on the wooden ship - I don't mind masking stuff, and getting a smooth layer of paint with no brushstrokes seems worth the effort (though I wouldn't spend that money to buy an airbrush just for wooden ships.
Colin
Current Builds: HMS Pandora 1/64 Scratch
                         Jeannie Johnston;
                         18thC Longboat with my son
Previous Builds: HMB Bounty - Caldercraft
Running Round my head: HMS Speedy (1782) - vaguely thinking POF
"If at first you don't succeed, try it your wifes' way"
it was because of these large builds,  that I took the airbrush back up.........loving it ever since!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Ahoy Kevin :D
There are a ton of "how to" air brush videos on YouTube. How I learned
Here are some  tips I learned the hard way.
Always tackle the hardest sections first. Common newbie mistake is to spray the larger area then try to hit the tough spots.
Future floor polish is great stuff. Use it to seal tape and prevent bleed or add a gloss coat for decals or washes. I do not like it for a final coat and I thin it. Dries in less then ten minutes.
Use acrylic thinner for airbrushing acrylics, "not" water.
Make sure you have something to cover your work when your done. Nothing worst then a perfect paint job ruined by some airborne particle
Weather affects airbrushing so your mix today might not spray the same tomorrow. Always test and adjust if necessary.
Develop a routine to clean your airbrush. Time spent on this comes back in spades
Airbrushing is a lot of fun but can be a love hate relationship
Edited by JPett
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
Happy new year everyone
the seawater inlets and outlets are grilled, the photos dont look that good due to over spay from painting inside the hull black, then to complete the illusion of depth, i put some tanks on inside, at least you cannot see daylight from the other side now
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
the kit does not contain a stand so i have made one
i used 2 curtain pole end caps
two bolts with nuts
two part expoxy
this is temp as i dont know how she will be displayed at the end of the build
the nuts are fixed inside of the hull and screwed from the outside
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
lol -  the stand may be the wrong way around
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Main deck is now attached to the hull - so in reality, in two months i have built 7 pieces, but a lot of the superstructure is built up, and i detail it as i go along
Next i have to add all the port hole PE and steeps, then prime the hull and main deck, i know the decking goes over it but a lot shows through, so will save doing it later
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
nice looking stand..........looking like the hull may be finished soon,  so it can be bolted to it permanently!   :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
this one is just temp - but i will keep the same concept for the final one- possibly board big enough to allow a glass cover to fit over it, must admit this has made the build very movable and given it some weight
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
75% completed the stern steps, driven me to book an appointment at the opticians, wait for the glue to set - then will ensure they are all level
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
1/100 remote control Bismarck - enjoy
http://www.youtube.com/watch?v=FkT2v7mwbW8&feature=youtu.be
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Hi Kevin, amazing video !! I bet you have 100 odd servos on order as we speak ! :) :)
Eamonn
Edit.. I have just realised the Video Bismarck is 1/100 compared to your one of 1/200 (And Your Bissy is flippin HUGE) :)
Edited by egkb
Current Build   :  HM Schooner Ballahoo
In the Pipeline :  HM Cutter Sherbourne, HM Mortar Convulsion, Emma C Berry & C18th English Longboat.. Eventually That Is..🙄
the PE on the hull has been done now as is the waterline, i am in the process of confirming that it is the correct position Trumpeter dives no indication of where it should be
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
the armament is now being built - the barrels are supplied in the extra's kit so they replace the plastic kit ones on the smaaler rurrents this means cutting of at the breach and drilling to allow the replacement to be installed
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
SWEET!!!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hey Kevin I'm watching your build with great interest. I just started my build as well on here. I just guesstimate on the waterline. I'm not going crazy with all the work some others are doing. It's enough for me just to get something I'm proud of and not spend a year building it lol
are you doing a build log, - i have several now, on different sites, but for the knowledge,, freindship and broad range of interests and no subscription  i like MSW  by far, it is the best of all,
In return i might even finish one of my builds off and move it from a build to a completed
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
.....and we'll be here to watch you  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Kevin
Looking good and a nice tidy work area compared to mine,I have been putting it off since Christmas :D I had a look at the movie,that is one spectacular model.I have 14 motors in my DSV up to now and I thought that was a lot :D He must be controlling the model through a laptop because my Futaba F14 is nearly fully expanded and it wouldn't come close to controlling half that :huh:
Kind Regards Nigel
Currently working on Royal Caroline
