That boat is fantastic.  I like the idea of only planking one side.
Toni
Member IPMS
                           Utrecht-1742
Dear Giampiero! I have not seen the drawings of Your boat, but I am sure that You may have made a mistake in the location of the stern and the bow timbers.  P.S. It's possible that I'm so wrong... Sorry then!
Edited by aviaamator
That appears to be the armed boat used by the army.  It had a cannon, as I recall and was used to ferry troops across rivers and also land them from transport ships.  It's bigger than a ship's boat and also much later (1834) than the L'Amarante (1749)
That is a sweet looking boat, Giampiero.    Maybe I missed it but how many ship's boats will you make?
Giampieroricci,
yes, you made a mistake on 11 bow frames /wrong side/
you are right!
I did not consider that the floor plates have to be reversed towards the stern, but now I can not change them....   :-(
Yes, Mark! There is another more little boat that I have to build: it will be placed within the larger boat
I have finished the boat, I only spend the last coat of paint.
Probably, in its final form, I will have to remove the benches and rudder because inside will be held the spear, that still I have to build (and already I shudder because this was a very demanding job!).
Edited by giampieroricci
Giampiero,
When I click "like this" I wish there were, other adjectives available (:-)))) - Absolutely superb work indeed.
Cheers,
Edited by md1400cs
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
En 25/2/2017 a las 6:09 de la tarde, giampieroricci dijo:
Él Acabado el barco, Solo Pasar La última capa de pintura.
Probablemente, en su forma final, voy a Tener que quitar los bancos y el timón Porque en su interior se Llevara un cabo de la lanza, Que Tengo Que todavía Construir (y ya tiemblo Porque era this Un trabajo muy exigente!).
Hola, ¿de dónde sacas esas grandes monedas?
