Your decking looks great.  nice and crisp.  Did you use chisels to get that clean appearance?
David B
Thank you guys for warm words!
David, I use mostly needle files and sand blocks, then I have better control over edge, and chisels for final cut by inner corners
Alex
Current build: HMS Sphynx, 20 gun ship launched in 1775 at Portsmouth, Hampshire.
On the drawing board: HMS Anson, 64 gun third rate ship of the line, launched in 1781 at Plymouth
  • 2 months later...
Hello,
today only a small update, the work going slowly. The fore part of planking was most complicated one, I decide to make them as one piece of three plank to achieve clear rounding. The first image show the principle:
Here both pieces glued in place:
Overall view:
First plank of after part is also glued.
Alex
There are some very fine models shown on this site and yours is amongst the very best Alex, exceptional craftsmanship.
cheers
Pat
Beautiful work Alexander,
your build log is a treat to study...... :)  :)
Nils
Current builds
-Lightship Elbe 1
Completed
Greetings Alexander. Being able to contemplate and study the extraordinary work he is doing gives me the opportunity to see and learn from his great professionalism.
Thanks friend, a hug, Liberto
I only registered to say... I don't know. this is... this is,... oh man! I was just searching the web for some 17th or 18th century ship plans to make a 3d model (it's been on my ToDo list for a while), and I stumbled upon this forum and this... this... I'm completely and honestly speechless. INCREDIBLE WORK!!!!
cheers!
Denis
In Progress:             HMS Pandora 3D modeling
Finished Builds:       Swan Class HMS Pegasus for Admiralty Models 3D Build
                                German Type VIIC U-Boat 3D model
My other 3D work:  Artstation
  • 2 months later...
Hi,
make some progress on F'castle and Q'deck. The Forecastle is preliminaly sanded mow, final sanding will be after nailing.
It takes some time to bring the images in right order... ;)
Alex
Hi Alex;
A very nice job you have made of her indeed.  The quality of the work is very high.  Tapering deck planks look so good.
I am intrigued to know if the scarph joints in the margin planks on the quarterdeck and forecastle are your own thought,  or is this based on an example you have seen.
All the best,  and happy modelling.
Mark P
Previously built models (long ago, aged 18-25ish) POB construction. 32 gun frigate, scratch-built sailing model, Underhill plans.
2 masted topsail schooner, Underhill plans.
Started at around that time, but unfinished: 74 gun ship 'Bellona' NMM plans. POB
On the drawing board: POF model of Royal Caroline 1749, part-planked with interior details. My own plans, based on Admiralty draughts and archival research.
Always on the go: Research into Royal Navy sailing warship design, construction and use, from Tudor times to 1790.
Member of NRG, SNR, NRS, SMS
