4 hours ago, Matthew13 said:
Hi just got a question about hms snake it’s going to be my next build
just asking if it’s possible to plank the deck before fitting if I take inner bull work planking in to account as I want to do paper seams on the deck planks and trying to clean the planks up afterwards when the false deck is in stalled might be a bit of a struggle
thanks for any advice you may be able to offer
matthew
I gave quite some thought to planking before fitting (it was suggested in one of the downloadable manuals from Jokita - not for Snake though).  Decided not to, mainly because the deck has quite a camber which varies fore and aft. Planking while the deck was flat would make it very stiff and I don't think it would bend enough for installation.  It might be possible to set the deck up in a jig, but given how tight a fit it is, I wasn’t willing to risk it.
As Jason says, there is pretty good access once installed.
It's great to see how everything is coming together.  I really like your work on the bowsprit netting, it's a delightful detail.
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
@Mike - thanks for the kind words!
@Martin - I guess I'm located in the valley just over the hills from the Litchfield Hills of Connecticut 🙂
Rope Coils...
Before any more rigging can be completed, rope coils really need to be attended to.  Once the remaining braces, cluelines and sheets go on, access will be impossibly restricted.  I'm not a fan of gravity defying suspended circular coils which don't quite look right to my eye.  I really wasn't quite sure of the approach to take, but I knew I wanted to try to replicate the shear mass of heaps of rope often shown on period photos and try to give the rope some mass, but knew that doing so would be very difficult using the kit rope.
After many attempts, a mock up of the pin rail was made up and the rope stretched around a belaying pin and some wire.  Dilute PVA was then applied to ensure it kept its shape, and some extra rope wrapped around to keep the shape.  Once trimmed and the glue has dried, these can be hung over the desired location.  These still require some fettling and wanted to see how I feel about them in a few days with a number on position before securing or trying an alternative approach.  I'd welcome thoughts and suggestions...
IMG_2574.thumb.JPG.cbd46beea360850feb8446f3ddcd2fb6.JPGIMG_2576.thumb.JPG.064dbfec6f1ac91751a145e2a3f9ac2d.JPGIMG_2577.thumb.JPG.8fa9d87932d334a6b2826592c782ce8d.JPGIMG_2578.thumb.JPG.f23bb6306205204e261d03c4056b8d42.JPGIMG_2579.thumb.JPG.717ea0c5eff5b4f10eaa24ce77923ee8.JPG
Cheers,
Jason
In the shipyard:
I'm gonna stop you right there, The rope police is here!  I have a link to a video from Tom Lauria about making really nice belaying hanks. I also have a picture of some I made using this his method. I also have a picture I took of the Niagara that I used for reference.  Your ship is one of my inspirations and I hope this helps!
https://www.youtube.com/watch?v=bgWHqw4Pg8Q&list=PLnXLeuhOqKhLCIrq2IsF78Qv0UUuQmdYU&index=1&t=1s
Edited by BenD
About time I caught up with myself...
@Ben - I'm going to have to stand guilty as charged!  Appreciate your post, this was something that I have been wrestling with for some time and fully recognize that the approach taken is a compromise.  My thinking has been as follows, and I suspect that every model builder will arrive at a different place.  Your coils are certainly excellently executed!
  • Quality of rope used:  Having used the Syren line on 'Jason', there is just no comparison between good quality custom rope and the 'stuff' supplied in kits.  My skill levels are just not up to achieving consistent coils following a seamanlike practice (that look anywhere near acceptable).
  • Scale:  This seems to be a variable from modeler to modeler, but to my eye many of the coils using this technique just do not look right at scale, especially when many pins are used on a rail adjacent to each other. Much of the rope used per kit instructions are much thinner than your prototype - mostly kit supplied 0.25mm line which is not very substantial and subject to gravity making floating 'ovals' distracting
  • Quantity of rope (on the actual ships):  Looking at many older photographs of ships, the one thing that stands out to me is that the quantity of belayed rope used on contemporary working vessels just looks far more voluminous for whatever reason than that seen on modern 'museum' ships, maybe because of longer working lengths, necessity to be worked by many hands etc etc.
The bottom line though is that there is enough on this build that continues to bother me (both mistakes and things that I have since learned) to push me to continue  with an eye to completion.  I'll apply for parole at the duly appointed time...
Rigging (almost) complete:
After nearly 7 years, with all the main rigging elements in place, I can start to smell the scent of completion.  The only outstanding rigging feature (in addition to some remaining decorative coils) are the spritsail sail sheets which will be added when I'm confident that the anchor placement won't cause problems.
Braces:
One of the bigger challenges were the braces, mainly because many of these are bent onto various stays.  At this scale the rope doesn't behave well, and preventing the stays being pulled into all sorts of unnatural alignments by the much thinner braces, and keeping the braces taught, meant taking this very slowly, ensuring line had time settle into place and in many cases using dilute PVA while attempting to keep the stays in position.  This proved to be especially challenging for the fore and fore topsail braces which bend to the main stay in one rather tight spot.
Sheets, tacks and cluelines:
Petersson was a big help here to illustrate how these worked in practice as the instructions are simplified.  Given that both the main and fore require these, with 3 belaying points for each, some planning is needed to ensure sufficient working room as once in position access is even more severely limited.  The tack is the most substantial of the running rigging used and 0.75mm rope was used as per instructions.  At this thickness, it proved necessary to coil rope on the deck after belaying to pinrails.
I took the same approach to BE on his Pegasus build in having the sheets and tacks go outboard of any standing rigging, although the sheets are yet to be finally secured.IMG_2584.thumb.JPG.5d6b8118bc8a65f99f330b6e21cc7abd.JPGIMG_2588.thumb.JPG.23f606959b60bcb03c6dbb8123f38150.JPGIMG_2587.thumb.JPG.ef3508ab4c29ae04264821503ac0060e.JPGIMG_2592.thumb.JPG.0ee08bbda6fa74dd1cbffc04810358ab.JPG
And finally, some overall shots..
IMG_2589.thumb.JPG.9dc284da611e9116bd9b99a9b4e73b2a.JPGIMG_2590.thumb.JPG.8c466ee811b75bc5d1571a71a33aa439.JPGIMG_2591.thumb.JPG.b03956fd56812e1ec12047bc9b3aa912.JPG
Edited by Beef Wellington
Cheers,
Jason
In the shipyard:
What a great ship model. He is really very impressive. Well done !
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • HMS Winchelsea 1764 - Syren Ship Model - 1:48
Thanks whitejames, Eamonn, Joe, Martin, Stergios, mugje, Mike and all the 'likes' for the continued interest and encouragement.  Happy New year to everyone!
Anchors:
Adding some appropriate features here at the bow will do much to enhance the overall look of the model, the kit itself leaves the bow area a little sparse, especially the rigging which has already been commented on.  The kit provides 4 full sized 'bower' anchors.  However, Steele indicates that a ship of Snakes size and class would only carry 3, in addition to a smaller kedge and stream anchor : “Ships of 110 to, 100, 98, and 90 guns, have seven anchors; from 80 to 20 guns inclusive, 6 anchors; ships of 300 tons, and sloops, have 5; and brigs and cutters 3 anchors.” - This would include the large (best, small, and spare) bower anchors, stream and kedge anchors.
As for positioning, per Steele:  "The spare anchor is stowed on the starboard side, and is seldom used, but when one of the others is lost......The stream anchor is stowed on the spare anchor; and, when used, it is sent in the long-boat or launch, with its cable bent, and let go at any particular spot, either for steadying the ship, when riding by only one bower, or to assist a ship when in shore, or to warp her, &c. ......the kedge is stowed on the stream and spare anchors, and is frequently used to stop a ship for a tide in little winds…”
A number of years ago (!) I had purchased a smaller Caldercraft anchor for the kedge anchor, and luckily was able to find it.  Not much to cover in the making up of these anchors, which had previously started some time ago.  The ends of the stocks were rounded of and tapered.  One mistake I did make that I am now aware of is that there should be gap between the two halves, speculating to retard rot.  I found the 'puddening' particular challenging to complete as the pieces are hard to hold securely but finally got there - once again the 'springiness' of the kit supplied rope seems very capable of undoing work at the most inconvenient moment.
The next question was how to install on the model.  Info on anchor handling practices seems to be a little sparse, with diagrams and descriptions appearing in 'Lever' being replicated in other reference books.  Other logs, especially BE's fantastic Pegasus build, helped fill in areas of confusion.  Again Steele sheds a bit more light:  “The best bower is then placed forward near the bows on the starboard side; the small bower near the bows on the larboard side, a little abaft their respective catheads; and are secured by their stoppers, from the catheads and shank-painters. The stopper has one end clinched round the cathead; the other end passes through the ring of the anchor, returns upwards, and leads over a large thumb cleat bolted to the cathead, and is made fast with several turns, and the end hitched round the head-rail and timber-head, on the fore side of the cathead.”
Anchor hawse clinch:
The approach to attaching the hawse to the anchors using a clinch is shown pretty clearly in 'Lever'.  A bight is made by lashings ("no larger than the anchor ring") and the hawse fed through the anchor ring and the bight.  Nothing too complicated, but this was rather tricky to execute because it needed to be done in situ, a tin was used to rest the anchor while this was performed.  Before the last bight lashings were put on, the intended end of the hawse was seized to prevent it unravelling once cut.  This approach seemed to work well, and the extra untrimmed length of the hawse was helpful in keeping things positioned to allow the last lashing to be put in place.
IMG_2607.thumb.JPG.e6327068146fafd12faeb4eb5fc4fe55.JPGIMG_2608.thumb.JPG.2ba1f7ad3fb873f1497cc759ed4265e8.JPGIMG_2609.thumb.JPG.f7a5fc6d2e1c3d88dc709f2fd011e848.JPG
Anchor stopper:
Per Steele:  "The stopper has one end clinched round the cathead; the other end passes through the ring of the anchor, returns upwards, and leads over a large thumb cleat bolted to the cathead, and is made fast with several turns, and the end hitched round the head-rail and timber-head, on the fore side of the cathead."
The rope would likely need to be reasonably substantial, and given a diagram in Lever which corroborated, 0.75mm rope was used.  Although the size looked appropriate, the poor quality of the kit rope led me to look for options, and a solution became clear after looking at some photo's of Victory.  It seems the stopper was served (presumably for protection), so this was replicated and it went a long way to improving the visual appeal.
Cat block:
The cat blocks seem to be a nice feature to add for visual interest.  The blocks were made up from a couple of kit 7mm double blocks and shaped.  Card was used for the iron band and brass ringbolts used for the hook and the simulated axle.  A small PE eye bolt was installed on the rear of the cathead and 0.5mm line attached and fed through the block before securing to a cleat at the base.
IMG_2611.thumb.JPG.56382107e705330520f087f26ac35ef2.JPGIMG_2615.thumb.JPG.d91193db5cbf6643a80781d772b42169.JPG
Shank painter:
Per Steele:  "The shank-painter hangs the shank and fluke of the anchor to the ship's side outboard; and when stowed, the shank-painter is passed under the inner fluke round the shank of the anchor, and made fast with two or three turns, and the end stopt round timber-heads on the forecastle."  Lever also has a well replicated diagram showing how this would be used.
Luckily I had some spare chain left over from the rudder, and this was used for the shank painter together with some 0.5mm line.  At first, I felt this was a little oversized, but looking at photos again of Victory it doesn't seem too out of line.  Against the black background of the hull it sits OK with my eye.  I suspect that the end of the chain ended in a hook, but this detail was omitted for convenience, as it would not be very visible.
Undecided as of now whether to leave the port anchor suspended from the catblock or replicate that used on the starboard side.
Cheers,
Jason
In the shipyard:
Very admirable job, I enjoy watching your builds develop. Happy new year!
     Current:         Emma C. Berry Lobster Smack-Model Shipways-1:32-1866
        Back on the shelf:    USS Essex- MS- "Old Yellow Box" Solid Hull  Wall Hanger (Half Hull)
   Completed:    18th Century Armed Longboat-MS 1/24
                          USN Picket Boat-MS 1864 1/24
                          US Brig Syren by Sea Hoss- Model Shipways-1803
                          18th Century Carronade/Ship Section
                          Mayflower-Pilgrims Pride by Sea Hoss-Model Shipways-1620
                          18th Century Long Boat by Sea Hoss-Model Shipways
                          USS Constitution by Sea Hoss-Revel-Plastic
Breath-taking, as ever, Jason.  I need to install the catheads in the nearish future and was wondering whether to drill them out.  I see you have gone beyond that, but apart from the end of a pin proturding I cannot see what you have done.  Is there a sheave in there?
Edited by MIke_H
Hi Mike, think this picture from earlier in log explains it best (Post #323 on page 11).  Definitely a good idea to do this before installing the cat heads on the model as I think you'll get better results.
HMS Snake by Beef Wellington - Caldercraft - Scale 1: 64 - First wooden ship build - Page 11 - - Kit build logs for subjects built from 1751 - 1800 - Model Ship World™
Cheers,
Jason
In the shipyard:
Jason,
Have not commented too often -- should have -- :imNotWorthy:  awesome log along with brilliant work!!
Regards,
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Michael - welcome aboard and thanks to you and the others for the interest.
Nun-Buoys:
I've been trying to get my head around these for some time, there seems to be little info on these in sources but seeing how others have tackled these (esp. BE and Chuck) were of great help.  I seem to recall that the buoys should be around 1/3 to 1/4 the length of the anchor but for the life of me can't find the reference or place that I read that to confirm.  The body of the buoy was shaped from some spare dowel, and 2 ringbolts inserted at the extremities leaving some of the length exposed.  These would have been made from leather and would have been 'served' with leather strips as suggested by Lavery, but this was a detail I ommitted, and these were simply painted with brown and black paint.  In a slightly larger size, these would be fun items to add a little more detail on (as I think BE did on his on his Pegasus build)
To make up the anchor buoy slings, eyes were seized into some rope, and threaded onto the rope that will become the hoops.  I wasn't quite sure what size to use, but considering that in practice these would have been wormed, parcelled and served - presumably for protection - it seems likely that they would be reasonably substantial.  I used some Syren line to get a little definition, and used a black marker to darken as I only had some tan stuff handy.
Mounting the slings on the buoy itself proved quite the challenge.  Firstly, the hoops were made up with a single overhand knot, secured with GS Hypo glue, and then trimmed.  The slings on each end need to go underneath the hoop on the opposite end.  I found the best method was to suspend in some helping hands to fine tune, although this proved very fiddly.
Once everything was satisfactorily in position, the 4 slings were seized around the ringbolt (which simulates the loop the slings would make), and then trimmed.
This was then attached to a pre-made coil to represent the length of rope needed for given depths of water, and then secured to the shrouds for storage, and attached to the anchor.  On many models, these are shown as rather drab items, I have to believe in practice that these would have received some sort of brightly coloured paint to aid visibility, but I stayed with the more conservative muted tones.
So at this point, the only item remaining to be completed is an ensign of some sort, and some tweaking of the rigging...
Cheers,
Jason
In the shipyard:
Wow Jason,
I thought that the Snake was finished....
But it goes better and better.
I have now no regret that I bought the Snake yesterday 😃
I was hoping that i will get it today but i think tommorow.
So this build log will be my guide.
Thanks my friend.
Sjors
Looks fantastic Jason!  I seem to recall anchor buoys being about 1/3 the anchor length as well, but can't recall where I saw that (maybe in zu Mondfeld).  My approach was similar to yours, except I used clay for the buoy part.  The rope work around the buoy is a real pain but it makes for a nice detail not ordinarily seen in models.
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    Hs129B-2 1/48  SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32   IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48  Eduard Sikorsky JRS-1 1/72
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Very impressive, Jason.  I think there's a good reason this detail gets omitted so much, and that is, as you say, it isn't easy to figure out how to get them done.  Your detailed account solves that problem for the rest of us.  Many thanks!
Cheers,
Martin
Eammon - I think you and many others deserve a perseverance award for sticking around
Sjors - Its great that you'll be starting a Snake build as well, there are a number now in progress, and there is still a chance you will finish yours before me 🙂
Mike - Thanks for reminding me that you put these on your badger, she really is a nice looking model
Martin - Hope it helps, like always, we stand on the shoulders of those who go before
The Ensign:
Really the only missing item at this point is an ensign.  Making one's own is really the only option as aftermarket items are the wrong time period (the cross of St Patrick in the Union Jack was only introduced after the Act of Union in 1801), only white ensigns are available and they seem somehow a little too perfect, and the material they are made from seems overly heavy.  There seem to be a couple of very similar approaches to making these, and here is how I approached it.  This was my first effort, and although results are not the height of perfection, I'd say this is something that any modeler should feel comfortable taking on.  I am not quite finished in that the final article needs to be 'folded' to sit more realistically, but I'm stepping back for a moment to think through options as I'll probably need to use some steam to help make permanent - and this seems like it could be a little catastrophic if approached incorrectly.  Open to thoughts here!
The first decision was to decide what sized ensign to create.  I printed on paper various sizes to see what looked good to my eye before committing further.  I'm rather taken with the majestic look of a large flag, and have erred on the side of larger size, even if it would be perhaps more appropriate to use a smaller size for a ship not under sail or in battle.  If I could make one recommendation to a modern navy, it would be to use larger ensigns!  The other factor that played into my decision to err on the larger side was that when tweaked to hang more realistically, it will look smaller and less obtrusive to the eye.
The first step was to soak some modelspan tissue in water and stretch over a frame to dry.  I used an old cheap picture frame which worked quite handily, and the modelspan tightened quite nicely.  Once dry, dilute PVA was painted on, this causes the paper to stretch and wrinkle again.  Once dry, it becomes taught again and the outline of an ensign was very lightly drawn on with pencil tracing from an appropriate pattern.  After that it was a simple case of slowly layering dilute acrylic paints.  I was somewhat limited to what I could get my hands on, using Tamiya XF-7 Red, XF-8 Blue and Vallejo 'Off White'  used on the cutter.
IMG_2629.thumb.JPG.8b33a7b994f5e5dffdd17f1245b09dab.JPGIMG_2630.thumb.JPG.5feb2f6d2a3ed539f05a84fede205c3d.JPG
Some masking tape was used where the hoist will be to try and limit mistakes in that area, and while this did work, masking tape did not seem to be able to provide a clean edge for the rest of the flag so it was pretty much all painted free hand.  Both sides were painted, and for the field of the flag, brush direction was alternated in horizontal and vertical directions.
I forget how many dilute coats were applied, but I stopped before the colour became too solid and while there was still some translucency when held up to light (the horizontal and vertical lines were still somewhat visible).  Once removed and cut to size, the hoist was trimmed to an appropriate size so it could be doubled back on itself and hard crease introduced.  This is just visible below at bottom left of the flag.
In reality, the ensign would have been attached with either toggles or loops to the halyard, I decided to avoid reproducing this exactly because it would likely look a little out of scale and introduce some unnecessary complexity.  In the end, a length of rope was lightly glued into the crease of the hoist, which was then then lightly glued back into place.  Two knots were then placed into the rope where this would normally attach, and a false seizing placed above (on the top) and below (on the bottom) to give the impression of a loop.  The hoist was then tidied up with a little off-white paint.
The ensign could now be trial fitted by threading the halyard through the small block on the end of the gaff.  An ensign staff would have been used on larger ships, and even some earlier smaller craft seem to have a temporary mount to be able to place a staff.  With the platform, there is really no space for such a feature, so I'm going to proceed with the ensign flying from the gaff.  Given the spartan, utilitarian approach to the rest of the ship design, it does not seam unreasonable that this was the approach taken, similar to what I understand was done for smaller cutters.  I'm also proceeding on the assumption that the ensign halyard would just have been secured to a cleat on either the side of the stern.  I would welcome some additional insight or correction on this point.
Cheers,
Jason
In the shipyard:
Nice job!
Mike
Wonderful job on that flag!
For folding it you may find that 2 dowels of different sizes will help get realistic "curls" with the size of the curls getting progressively smaller as you work your way away from the upper, inboard corner toward the lower, outboard corner (assuming you want it to look like there is a little breeze - in a dead calm the folds would be more equal). If you look at the online instructions for the Brig Syren on the the Model Expo site, the last page of the last chapter has a great pix of a very realistic looking flag. I used that method for the flag on my Olympia build that you can see in the link below my signature.
Keep up the good work - I can't believe this is you first build!
Edited by schooner
Tim
Current build: Continental Navy Frigate ALFRED (build log)
Past builds:     Steam Tug SEGUIN (build log in the kits 1850-1900 section)
                         Liberty Ship SS Stephen Hopkins (Gallery & Build Log)
                         USS Basilone (DD-824) (Gallery & Build Log)
                         USS Olympia (Gallery)
                         USS Kirk (FF-1087) (Gallery & Build Log)
Ensign...conclusion:
A tiny bit of steam was used to soften the ensign while various "rounded implements" with different radii (dowel, metal file shafts etc.) were used to try and introduce various folds.  I'd love to be able to describe a reproduceable scientific process, but thats not what happened.  It was really just a continual serious of tweaks, leaving to dry and most importantly trying not to introduce creases.  Steam worked fine to initially soften and allow the structural folds to be introduced, but isn't really a good ongoing solution as it tends to undo any previous work.  Real care is also needed to not 'over wet' the painted flag, not sure I was completely successful here.  Final tweaking was done by wetting very gently any tools used and trying to hold in position while it dried and the fold takes.
...and with that milestone, I'm declaring this build FINISHED!
This was my first wooden ship build, and first model I've built for over 30 years.  Its taken probably 8 years to get this far off an on (probably 7 years more than it should), but I have to say I'm glad I was able to finish her.  I've come to realize that I enjoy the journey more than the destination, and I certainly experienced moments when I could easily have put her aside permanently, mainly due to me recognizing unfixable mistakes or compromises that that could so easily been enhanced had I known more at the time.  Given the length of time taken to complete, this progression in knowledge and execution is very apparent to me, but I hope is less apparent to others.  All in all, this was a most enjoyable project that exposed me to the necessary knowledge and techniques that I hope build on and leverage in the future.  I still need to make up a protective case, and will probably continue to see needed fixes and touchups before she (hopefully) is put in a place of rest.  I would like to thank this entire community for the ongoing help, support and encouragement - without which I would not have reached this point.
Few pictures to celebrate, apologies that these aren't exactly studio quality.
IMG_2642.thumb.JPG.86d56e2efc295e6d71265b638c1bb0c8.JPGIMG_2656.thumb.JPG.7dfa1c8c29c493cf2fc69a0e8d3f0f34.JPGIMG_2657.thumb.JPG.f7247818a917721affa2807c731f3cc1.JPGIMG_2641.thumb.JPG.119b08d2f538295afdbc5eb2c712bd7f.JPGIMG_2644.thumb.JPG.b05f5952684f081b2535fab6e312ce3e.JPGIMG_2645.thumb.JPG.2b3d64c19a746449baa4ce3ce0ec8361.JPGIMG_2646.thumb.JPG.fb579d38e42769c1f3eee7ce4660b0ee.JPGIMG_2647.thumb.JPG.a85ac5e4d509080ea73abe8c070128f2.JPGIMG_2648.thumb.JPG.6d2ff16f4a98501e7e4dbb15bd750980.JPGIMG_2649.thumb.JPG.00ac8fea40146a5d45831c349cd82739.JPGIMG_2650.thumb.JPG.d8aa851032d30c2840050362ab730fc0.JPGIMG_2651.thumb.JPG.961f4abe83cc883ffd4fac0d0b2c30a7.JPGIMG_2652.thumb.JPG.c265a203b13b2e5bb277198673adfce5.JPGIMG_2653.thumb.JPG.89e48de6d2cb9096f7efc6e6840af0a6.JPGIMG_2654.thumb.JPG.02f8523406d2aa3c475d69bab6426a94.JPGIMG_2655.thumb.JPG.4f526ba266bc1ca2c013639ad7ca8e18.JPG
Cheers,
Jason
In the shipyard:
