John My only concern with placing the post here is that there is little room for a knee other than bridging between the posts. I can shorten the pawl a bit so that i can get the post a little closer.
Michael
Steve,
In this close up of the windlass on a small British coaster you can clealy see the anchor cable around what are also clearly wooden staves on the drum.  It sounds crazy, but there you go!
Michael, it this photo you can see that the post is almost touching the windlass.
John
Steve, John. The source for my design was this set of pictures from Working Sail the pictures are in the set called "on deck" in the banner.
John that is very close.
Michael
Steve thanks for that compliment.
Michael
Ok so I will clean up things and set the post close to the winch like this and add the second pawl and a small knee in front of the post.
I need to smooth out the brass rings and solder the parts together now, plus cut the square holes for the mooth part of the drum.
Michael
John thanks for all your help this afternoon.
Mark, thank you for your confidence in my abilitiy.
Well I finally got down to brass tacks and set the bolts in the staves cut the hole in the deck made a new knee for the post, I made the post a little smaller in cross section than the other posts.
The anchor chain was pretty heavy so I used the extra leverage with the special bar.
The pawl dropped onto the next tooth nicely as I turned the winch all the brass and wood are now glued together on the shaft I will make the small brass plates with the square holes to reinforce the square holes on the barrel, and the second pawl tomorrow.
The winch and post are still removable from the deck at the moment.
It's been a pretty long day so now a cup of tea and relax
Michael
Michael,
Super nice windlass.  Is there anything on this model that won't work?
Well done Michael,
Wow only 24 hours since my last entry and look at all the construction you did, let alone the engineering.  I like the way it finally ended up, I can just imagine myself there helping to lifting the anchor.  Great fun.
Bob
Current build:  SS_ Mariefred
Russ, John, Mark, Bob, thanks for stopping by.
Mark My plan is to make everything that would work on the full size boat, also work on this model within reason.
I took a break from the winch this morning and finished another shackle this one with a ring instead of a threaded section.
The ring is made from some .011 music wire.
the pin diameter is .073" or scale 5/8th inch the gap is 1 1/4" in scale
Michael
John Thanks.
Back at the block Factory, A long time ago I purchased a small board  of Lemonwood or Degame to make some wagon type wheels, the blanks were cut but the wheels never got made. I re-cut the small curved sections to use for blocks. the wood is quite hard and takes a fine polish it is similar in texture to Boxwood but a little darker. I wont be using this many double blocks, after shaping the profile I will cut a number of them in half to make single blocks like the ones on the right.
and a metric rule
The big blocks are Lemonwood the small ones in the front are Boxwood
I also worked on a maple one with a metal frame
The pin is 3/32 in diameter
the new block attached with yesterday's shackle
Michael
That's one big model.I love the sleek look of her. I'll be back for another peek.Oh, that sounds like I'm reading a magazine, nothing rude intended. She's a beauty.
Michael,
Love the blocks.  They’re so nice you could sell your extras as jewelry.
Bob
Michael,
When I'll grow up, I want to become a ship-modeller like you!
Now, seriously, I enjoyed every bit of this log, but especially the metal works.  Your work is really inspiring!
cheers
Stelios
Current build: not decided yet.
Previous builds:
Traditional Greek vessel "Symiaki Skafi" (scratch)
Traditional Greek vessel "Perama" (scratch)
HMS Bounty (kit)
Hi, Michael !  Your The blocks and shackles - good and beautiful work  :)
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
you continue to amaze me Michael........your blocks and shackles look great.....actual rigging....wow!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I woke up this morning to an unresposive desktop computer. seems that the keyboard and mouse were not responding.
this being typed on my laptop which normally is not connected to the web, I just use it off line. so today I needed to get things updated and protected. needless to say XP found 122 updates for this laptop which it still installing it seems to be taking all day. also I had to purchase and download virus prtection.
all this seems to be taking a great deal of time. The desktop is in for repair.
So this is slow at the moment. I did work on shackles today
Well adding that pic that took ten minutes so until qall th updating and fixing is finished I will wait to upload any more pics. the lock rings were cut off the ends compression springs in the spring scrap box
I will respond to comments tomorrow when this thing has finished it's work.
This is really frustrating, I cannot imagine how frustrating dial up is these days.
Michael
Thanks John.  It is still installing updates..... will this never end?
Michael
well I finally got tired of the explorer updates and cancelled it I use firefox anyway. and now it sweems to be back to a semblance of nomalcy.
Michael
Russ thanks.
Mathew thanks for looking in.
Bob, Jewelery now that is an interesting idea.
Stelios, "when I grow up" :D :D
Garward thanks for your kind words.
Popeye, yes actual rigging.
Germanus before I forget thank you for your comments regarding the need to balance the size of the shackles, I had realized this.
If I missed anyone my apologies
While this computer was doing the updating  I did spend most of the day working on the shackles I set up a small travelling steady to cut the pins for theshackles
after drilling the holes for them .
Each shacle was placed on the wood bar and clamped in the mill vice to drill the holes.the holes are .073 inch
the retaining rings were snipped off the ends of these compression springs from the spare springs box. I did make some from the .011 thou piano wire but they were a little too fine .
Michael
Thanks Michael for these deatails. I renew my congratulations
Alex
If any of you cry at my funeral, I'll never speak to you again! (Stan Laurel)
