HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 64 donations so far out of 49,000 members - C'mon guys!) ×
Dafi,
Happy New Year to you.
It is great that you are introducing the personal aspect of life on ship, particularly in wartime, it completes the the environment in which these sailing ships existed.
By the way (to take a very light view) have you seen the film "Carry on Jack"? It introduces a whole new (and very British irreverence) to the battle of Trafalgar.  :o  ;)  :)
Ian M.
Current build: HMS Unicorn  (1748) - Corel Kit
Advice from my Grandfather to me. The only people who don't make mistakes are those who stand back and watch. The trick is not to repeat the error.
Hello Ian,
I think I will have to see this one again :-)
Meanwhile a small picture of my ever growing family ...
Some already knew about the freshest member in the front. As I had lately some requests regarding my Victory fittings for USS Constitution, I finally managed to do a first sample.
These are the oob ones, not too bad for plastic ...
... and these are the original parts from my Vic :-)
Cheers, Daniel
Edited by dafi
interesting color texture in those two pictures........refraction of light perhaps?   the Vic parts would work quite well I see.......I think I would drill the holes over the existing detail though.   not only would it hide them,  not having a need to clean or sand,  but the hole marks are already marked up for you ;)   {just need to flatten them slightly}
think if all those hulls were masted........there would be quite a forest to be seen!   Happy New Years Daniel
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
  • 2 months later...
Hi,
Have you ever tried pre applied solder pieces when doing this sort of thing? On this scale it's fiddly. And probably best to leave the solder on the work surface. But if you hammer the solder flat and pre cut just enough for each joint. Then it's possible to create a production line and solder them one after the other. With the solder under the metal, the metal pre flexed or fluxed solder. I used both. Then just hold each piece in place with a wooden coffee stirrer shaped just right the touch with the solder iron. Only needs a second or two as its so small but there is no unsightly lump of solder as only just enough is used and you can go along them doing perhaps twenty a minute. Without over soldering one of them.
Izzy
And now something completelydifferent: the larch ...
It took me ages to develop the way of doing the chain plates as I did not find any documentation on the internet by the time that I was trying to find out how to do it. Tried lot of work arounds as I did not know how to mass produce in a satisfactory way and tried to avoid soldering which I never really did before. On the other hand I did not want any photo eched parts because they always look "flat" to me.
But in the end I realised, the only way that worked for me was to produce it the same way the originals work - just a lil´bit smaller :-)
First some 0,5 mm brass wire around the deadeyes ...
... putting it in a template with tree steel pins ...
... cut into lenght and the top part is ready for soldering.
The ring underneath is done out of a couple of rounds around two steel pins ...
... cut in one go - the gap underneath helps to access the lower rounds ...
... first a little bit soggy ...
... and straightend up - The real straightening up will be done just after soldering.
Here comes the lower part for the fore- and main-channels ...
... bent around two steel pins and  squeezed in the middle.
For the bolts I use sewing pins. I grind the diameter on a file by putting the pins into my Dremel and afterwards still reduced the hight. The needed lengh will be around 4 mm. On the left the original needle.
And now the soldering - what a hell to learn :-)
First the lower ring, then sliding it into the loop of the deadeye, putting it into the third hand for soldering ...
... and ready. Looks sooooo easy ;-) The black is not burnt but just some paint :-)
Here the ensemble is already in place, the part that is ment to go into the hole of the hull is lenghend in its place and bent ...
... putten into the hole and the needle forced in with it. Take a thread and check direction and angle. Secure it with a drop of superglue.
A package of tree with different lengths.
http://mediaharmonists.de/bilder/640_victory-ruesten2_9459.JPG
That is when I realized that the used Krick-deadeyes were drilled too unevenly for my taste ... As I did not want to discard my painfully soldered parts and get better deadeyes, I startet closing the holes with toothpicks and filed them even.
http://mediaharmonists.de/bilder/800_victory-rusten_9639.jpg
Just then I realized that because of the size and curved surface the planned drilling templates did not work :-(
At least I know by now why they those bastards are drilled the way that they are ...
OK, good old solid handwork, putting each part into the vise and mark the central line for the two middle holes ...
http://mediaharmonists.de/bilder/800_victory-rusten_0127.jpg
... and with patience, a template and a good eye drill the preliminary holes with 0,5 mm, set the third hole with a fresh eye ...
http://mediaharmonists.de/bilder/800_victory-rusten_0128.jpg
... and finish the drilling with 0,8 mm.
http://mediaharmonists.de/bilder/800_victory-rusten_0126.jpg
I usually drill small holes by hand with the drill fixed on a round material as it gives far more control as any machine! .
Now came the tricky part of straightening everything up, worked best upon a cutterblade, even the smallest loops :-)
http://mediaharmonists.de/bilder/800_victory-rusten_9640.jpg
http://mediaharmonists.de/bilder/800_victory-rusten_9641.jpg
And finally I had a complete set of deadeyes and preventer plates for the main-mast channel on my adhesive tape. :-)
http://mediaharmonists.de/bilder/800_victory-rusten_0227.jpg
Hourray
... and finally came the montage :-)
First à la nature ...
http://mediaharmonists.de/bilder/800_victory-rusten_0249.jpg
... then with a little bit of colour ...
http://mediaharmonists.de/bilder/800_victory-rusten_0257.jpg
http://mediaharmonists.de/bilder/800_victory-rusten_0258.jpg
http://mediaharmonists.de/bilder/800_victory-rusten_0259.jpg
... and it looks like it was all simple! ;-)
I also added the missing fitht support bracket to the channel and also the missing small deadeye n# 8 which unfortunately is too tight and bends the channel. It will be replaced upon a later occasion. I see by now, that the channels would have had needed the thickness to be increased by 0,5 mm or more. ****, but thats too late by now, even for me ;-)
Liebe Grüße, Daniel
Ongoing builds,
SCutty Sark Revell 1/350 (Mini Nannie)
Cutty Sark Airfix 1/130 (Big Sis)
Will (Everard) Billings 1/65 but with wooden bottom, because I can
Also, if I'm understanding what your issue with the holes is they would have originally been grooved as well as holes. This can be recreated by usin a "brick saw" which is simply a twisted piece of wire. The twists in the wire are sufficient to create grooves but do so slowly and leave a very smooth finish. In the same way rope would. Obviously true brick saws used steel wire but fuse wire works great on this scale and can be used to enlarge holes that sould be irregular or even cut out hard to reach parts as the frame that's hold the "blade" is purpose made from strong rod for each use.
Ongoing builds,
Hello Ian,
Cheers, Daniel
Sorry to be picky but aren't the groves for the ropes on the wooden deadeye going the wrong way as the rope would have gone up not down. Just asking for my model as I'd rather do it right and if this is just a show and tell image rather than a final look then I know not to copy or to copy. No offence meant.
Izzy
Ongoing builds,
[you mean to say I'll be the only one full rigging EVERY gun?
Sorry but not only was I also an art student but an art student in the last even years who did grouch design so detail is absolute:-)
quote name=dafi" post="3107" timestamp="1361120716]And what is that for???
Until now she is a nice ship but as I mentioned already in a earlier post, it is meant to be a martial piece of war technology ...
... and I simply realized that I will not be able to push much further away the wonderful and lovely task of building the hundred cannons ;-)
First came bolts and some color shading: highlights and shadow - as usual. Then the apron for the secured one ...
... the flint look for the one in use and the breeching ropes.
Even though it looks short, it is long enough that the muzzel can be retrieved inside for about a meter. The rope will be replaced still by a better one :-)
For the rigging there are so many different versions found in the literature and in Portsmouth, so I decided to try that one for the secured one:
Now come the freshely build blocks ...
... but looks strange ... *think* ... *read* ... ok ...
... block and lanyard were the wrong way ...
... and here on the secured one.
And as it pleases here some more views :-)
Now welcome Hell-O-Kitty ;-)
Remark 1: The side lanyards are not meant to stay that tightly pulled to the back, they are meant to be loose on the floor. But it was less disturbing for the work :-)
Remark 2: No, even I will not do all the guns this way on the lower decks! But to work out simplifications, I have to know the real thing :-)
All the best, Daniel
Ongoing builds,
Just an observation from another angle. That's exa how thread is started when sewing leather so that it can't pull through and "makes a small splice". I fear I may get to involved with the ropes myself as knots are another of my passions and I hate doing them wrong. Even on this scale...
And now to something completely different:
Halleluja, praise the heavens!
Why? Because also small things can make me happy :-)
Looking back: A year ago I was already working on the improved gunport lids but had a grandious failure on the gunport tackles:
Looks like a ball of hair straight out of the shower plughole :-(
These days I broused through Gil Middletons wonderful Jotika-Victory and dicovered the splicing that he presents there:
We proudly present: The Powersplice
It is simple but effective:
Thread - here 0,3 mm - through the ring, neadle through the thread, it is more easy than it looks ...
... make tight, secure with a drop of glue ...
... and once more through it with feeling ...
... pull thight and ...
here we are!
Great, isn´t it???
All the best from a happy Daniel with thanks to Gil!
Ongoing builds,
It looks like and would probably work if you were to make a small diarama of the carnage of battle (-:
What do you want with the axe, James???
Disclaimer:jg
The following pictures are nothing ror the weak at heart! We will not take over responsibilities from any side effects you possibly may suffer  ...
Shiver with fear!!!
This is the lower gundeck with the riding bits, that are with me now for several years already.
Build as a small detail to create an interesting view through the gunports and shaped roughly out of balsa. As the standard of the model grew, I would like to put a first layer of wooden decks to ecxcercise my technics. For that I do not want to have to plank around obstacles  and also to replace the bits by better ones, heavy measures had to be taken ...
... therefore got out the heavy tools and realised that the things were well glued onto the deck. So after no blood but loads of sweat and tears the deck was cleaned ...
... and the rubbish big. Real after battle feeling ;-)
Here the gratings that were taken out: In those days I simulated them by taking a perforated sheet with 1 mm holes as drill template and forced the tip a small recangular file inside ...
At least, it did the job in those days :-)
... ok, I hope, that was not too tough for you???
All the best to the brave out there, Daniel
Ongoing builds,
Looking at these images. Would the same effect have been achieved buy cutting grooves in the wood with grooves going the opposite direction on the same side. The glue strips into a solid piece, more stable. Then when the glue is dry run the whole thing over the saw to create the grooves on the underside? I'm just curious as to if you attempted this before I might?
... and believed the 1mm gratings from the shop still were too big ...
... and so the tests began ...
... and her is the whole story ...
Literature always indicates to use the circular saw with a small guide beside the blade. So far understandable and comprehensive and does not sound scary. A first test free hand prooved that my wood was suitable :-)
Fastily changed the machine ...
.... or not that fastily, because untill everything was adjusted to the 0.5 mm blade, the right hight of blade and suitable thickness of the guide, and smooth cutting worked, it took some time. But then putted stripes of 1.5 mm thickness to cut ...
... and it looked a little bit tattered, see the stripe in the front. So gave it some clear varnisch and the stripe startetd to bend in all directions :-( Used some plastic foil as a separation on the topside and clamped it against another piece of wood to let dry. And luckiely it came out straight and after the second time through the saw it looked clean, see the stripe behind :-)
... and this is the bounty: material for the next years to come :-)
So came the next task: Cutting it into 0.5 mm bars without breaking its tiny teeth and without the bars disappearing in the machine. The latter was easily resolved with some tape. The first came out of the problem, that with the standard guide, the line was rubbing against the blade. So made a new shorter guide that releases the bars immediately ...
... adjusted the distance with a 0.5 feeler gauge ...
... and glued same sheet on the side of the wood to get the fingers further off the blade. So managed to cut nice bars :-)
Next thing is mentioned neither in any book: The cutting is just one thing - the gluing is the bigger problem ...
... used some soft adhesive tape and tried to put it together with 0,5 x 0,5 mm toothless bars - looks nicely uneven ...
... so printed a 0.7 grid onto paper and used transparent double sided tape and a loupe to fix them together. Nice meditational work :-)
So it is filling up:
The caliper is set to 1.4 mm.
And my little worker was so kind to lift one up to show the underneath :-)
... and the result is a cute 0.7 mm grating and soon I will be able to show where it will end up :-)
Ongoing builds,
Hello Thom,
I used brown package tape - just try different ones :-)
Liebe Grüße zurück!
Amicalement, Daniel
Having had a similar issue except full size. I used two 1” eye bolts looped into each other. Not simple or easy. Then into a large tube or dowel ends. This worked great as a universal joint worked both ways and even in three directions. Also if a tube is used even on the end the a collet can be inserted to hold the bit with the tube threaded to take a domed nut with a hole in the dome to tighten it. IMO
Ongoing builds,
Observation but you've got no bucket in this scene which was vital in times of full on battle as the sponge and rag often came out smoking or even burning.
After I had a lot of work to be done lately, no bigger things could be moved, but I found a smaller task to keep myself happy.
I realized that a lot of crews for the models were treated with much care concerning the painting and the historical correctness of the uniforms: But still they kept the positions they were delivered in - mostly these are people that were meant strolling along, nothing to do with the hustle and bustle and the action on a gundeck or working the sails.
So something to investigated: Take three times the same train passenger with luggage and leave once à la nature (right side) and strip  the other ones off their bags, dissect them and reconfigure them ...
... and look daddy - some real boys :-)
Open the footfall, twist in the upper body, moving the center of gravity to the edge of the standing area, turning the head into an opposite direction, moving the arm ...
Here they are helped by a ex-diver, once organizing his equipment, same operations ...
... and now busy with organizing the flintlok. And a nice blondy, once meant to relax on the swimming-pool towel ...
... and stirred, not shaken, is a useful member of the guncrew :-)
And a small excursus into some moping up ...
... and the enlightment, that the sponge can not be held too upright because of the restricted hight of the gundeck - so had to change the first version of arms of the holding crew member.
And here it is the hustle and bustle and the action of half a gun crew ...
... and now imagine the melee with the other half also present and the those of the neighboring guns! What a throng ...
all the best, Daniel
Ongoing builds,
I've found over the years that citric acid. Very cheap and organic and almost harmless, it stings if you have a cut. But the blacking process takes about three days and so is very finely controlled. And leaves a natural dark color on steel balls like these. As well as removing all grease and no stains. Just put them somewhere warm to dry swiftly. And they look just right
Izzy
... and now something completely different :-)
The cannon balls I already presented quite a while ago, they came from here ...
http://www.kugel-winnie.de/epages/62136757.sf/de_DE/?ObjectPath=/Shops/62136757/Products/010101003
... and the blackening stuff from here:
http://www.amazon.de/ShoXx-®-Brünierung-Schnellbrünierung-Kaltentfetter-Entwässerungsöl/product-reviews/B004CFHNHC/ref=sr_1_1_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
First one to take the grease off, second the blackening and the oil for dehydration ...
... first the degreasing ...
... used a magnet to take them out ...
... well dried ...
... and like Roger Rabbit back to the soup, the blue one for blackening ...
... luckily used old china as the stains remained :-)
First I wanted to avoid the dehydration oil because of the glueing, but some of the balls turned brown :-(
So same procedure as every year James, back to degreasing - the rust come of the balls but not off the china ...
... freshely blackned and oiled.
Putted UHU Universal into a old syringe and gave nice injections  ...
... uand placed the bullets :-)
Used lots of glue but still some came off, the oxide is a ideal separation agent ...
So then, good luck, Daniel
Ongoing builds,
*blow*...
... waving the dust away ...
... oh really, there is a building report appearing :-0
Lots of work means loads of pennies for the building :-)
The only flaw is that there is little time for the builds, the only time for forums is when hanging in a boring telefone call or while the computer is rendering or saving. But it looks like times are coming back *joy*
And as everybody sayz to start with something small ...
Cheers, Daniel
One does what one has to do :-)
XXXDAn
Dafi was a taylor ...
... he shortened my coat and scarved my shirt ...
... he put my head right back in place,  ...
... and stuck paper tails on my bum.
...hihihihihihihihihi...
XXXDAn
... good old times ...
... you can leave your head on ...
... and who discovers the parts from entry of 09.03.?
Cheers, Daniel
Fabulous Dirk, you win a beer next time we see :-)
And we proudly announce ...
...hihihihihihihihi...
... my next modeling tool ...
XXXDAn
Edited by dafi
oh....oh!  a model has many mortal enemies............this is one of them :o
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I'm hoping it's the matchsticks you want and not the fire.... but one never knows. :D  :D :D  :D
XXXDAn
I wish I had some form of translator for that.......I did catch the word sprinkler.......was there a sprinkler system put in place on board?.....or am I mistaken..... :(   .....a very sad sight to see.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
prins Willem was a kind of replica originally built for a tourist attratction in Japan (by the name of holland village). The ship looked as the prins willem model at the outside. On the inside, however, it was more like a restaurant.
Couple of years ago it was transferred fromjapan to Den Helder in the Netherlands, were it was kind of major attraction in the old navy harbour.
It was open for the public, and you could rent her as a party centre. Due to health and safety (both in japan and the netherlands) there was a sprinkler installation. However, when there was a fire in the hold ( it started in the kitchen) that installation wasn't able to keep the fire down. As the ship was all steel hull, the heat was quite large, and the firebrigade could not enter. Exit ship.
The original builder bought the remains, and transferred them to Harlingen. They planned to rebuild the ship, and turn it ( again) into a tourist attratction. As there wasn't much left, and due to the crisis, money could not be raised. The remains were scrapped and sold to Hoogovens, for recycling.
That was the end of Prins Willem. As it was only outwardly a kind of replica, not much was lost. The touristic centre in Den Helder lost an attraction, although even there, there are much more interesting ship available.
Jan
Hyho, small dafi was aloud to tinker some more bits ...
... first the freshly pressed ones ...
... by the way that is the way they looked in their former lifes :-)
And as dafi likes to do messes ...
... but there is nothing better ...
... than a fresh caulked deck!
XXXDAn
Looking back in history, February 2010
"... and the carronades with wheels and elevation screw."
For those days a vast improvement towards oob. But since then things went a bit nuts, so time to look for Carronade 2.0.
The basic form fits so far quite well, fitted two more reinforcement rings on the original places, made from my tinnest Evergreen strips, but still sanded thinner and rounded with abrasive sponges. Also the iron sight was replaced and a base for the gun lock created. The bed of the carriage got the slot for the traveling part. The old coin and bearing were removed.
For one of the guns a new sliding part was tinkered ...
... and I enjoyed the detail of putting in the base plate for the elevation screw flush with the surface.
The rolls fitted for the carriage are 1,5 mm poly and comply to my understanding of a decent size of parts: fits into the "C" of a Cent ;-)
Also the gunlocks do justice to this specification ...
... the flaps were bent ...
... and with the monograms we approach version 2.01.
Cheers, Daniel
Edited by dafi
