What was done before part 3:
some more details shots:
batteries and switch for the lighting
inner planking
First carving
Cabin
More carving
just before painting...
Have fun,
Michiel
Edited by Michiel
Finished models: Botter, President
Current:
Prins Willem by the book of Ketting,
HMS Beagle - OcCre
restauration of a Statenjacht
Nice to see your back. Please keep the Post and pictures coming. I enjoy this build and will be watching all the way to the end.
Wacko
Joe :D
Go MSW :) :)
Nice to meet you on this forum too Michiel !
As you know, I've followed this build closely on a dutch forum. I'm still impressed by the amount of detail you add to the ship.
If it doesn't bend, it breaks.
Michiel,
Reposting has not tarnished this at all. It's a wonderful build.
The underwaterschip is now painted:
I see now on the picture that some corrections are still in order :mellow:
the bow:
and the first work on the second gundeck:
Have fun,
Michiel
Current:
HMS Beagle - OcCre
Thanks Jan,
We just had a many page discussion on the schaarstokken... including comments from Ab,
But I think your right in all drawings of pinas's they do, the thing is that the hatch is rather large here, I stick to Ketting and with the batteries there I can't make it smaller. The distance between the main schaarstokken is now ~7 feet, and with that is fits nicely around the other hatches and the anker spill. So it's a bit of a compromise..
Best,
Michiel
Current:
HMS Beagle - OcCre
This is an amazing log, Michiel!
Did you make sculptures by yourself?
Alex
If any of you cry at my funeral, I'll never speak to you again! (Stan Laurel)
Sculptures are really well done! Compliments!
Another question: how did you make hull's nailing and caulking?
Regards
Alex
Thanks Alex
The nails in the hull (cherry planks) are made from chestnut thorns
like this:
I drill 0.5 mm holes, then I pull a thorn from a shell a dip it in some glue and stick it in. When it's dry I cut most of with a small pair of scissors and than sand it further. Finally a scrape the entire section and apply danish oil. For the deck planks I find the thorns to dark and I just use tooth picks, without any further processing, just pushing them in so that they fill the 0.5mm hole. Again after oiling you get a very nice contrast due to the grain direction difference.
The planks I make black on the sides with shoe polish from a tube with sponge, (the sponge is attached to the tube). You get the best result if you sand the side just a bit as well, especially the short sides. The shoe polish is instantly sufficiently dry and does not get into the wood. The sanding does fill the space between the planks a bit which may seem to diminish the effect. However, after applying the oil they come out nicely again (not if you apply a lacker though! then the sand dust stays in there and makes the effort in vain.). Obviously for a bit more historically correct color you could use a dark brown polish...
Current:
HMS Beagle - OcCre
Thanks for explanations, Michiel.
The final effect of your work is really good.
Alex
Very nice work Michiel.
Michael
I don't remember seeing the musket rack.   Is this new?  I love that candle.
I showed a picture before of a single musket, the rack is new. Next thing here will be a rack over the windows for dining plates. There will be an other bench on the aft side as well, eventually. I also finished the bed for the captain but it still needs sheets and a blanket.
the wiring for the candle runs through one of the legs, I drilled a 0.5 mm hole through a toothpick....
Best,
Michiel
Current:
HMS Beagle - OcCre
Hello Michiel,
Love the lighting effects and your clean work.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
