James H
Administrators
Posts posted by James H
  1. STAGE 76: FURTHER COMPONENTS FOR THE LEFT UPPER ARM
    Again, another liner is pushed into the socket on this left arm part, and then the shoulder joint is added.
    Biceps and triceps now laid in place over the assembly.
    Both left upper arm parts re now sandwiched together, and screws used to secure the muscles. I found I needed to use a rubber tip hammer to tap the main arm parts together at the shoulder joint, but they did fit nicely after that.
  2. PACK 8
    STAGE 71: ASSEMBLING FOOT PARTS AND ATTACHING THEM TO THE RIGHT LEG
    This pack is a continuation of the right foot, and also sees it complete. It really is very important that the photos are studied and the orientation and numbers of the parts. There are 2 rods per toe and some of these have a slight kink in them to accommodate the lie of the toes as they sit on the foot. These are assembled as before, and also using some thread lock on the grub screws. Care is also needed in orientation in fixing these to the feet too.
  3. 17 hours ago, VTHokiEE said:
    Is there any long term issues with this method? The results are awesome - is there a link to how/why this works?
    Nope, none whatsoever!
    Just add some to a small brush and brush the area you want to add PE to. Properly wet the area, then add the PE. Use a dry brush to wick away any excess and leave to dry. Seal with another brushing of Klear/future.
  4. 1 hour ago, Rustyj said:
    😂. Thanks Jim. One question. When you attached the PE details to the out side of the hull what did you use? It's so clean and no glue marks.
    Thanks Glenn, Yes I used Tamiya tape and then regular painters tape over that.
    Thanks for all the likes too!
    I used Johnsons Klear (Future) floor polish.
    Just brush some in there and plop the PE into position. Wick away any excess and leave to dry for 30 mins. I then brushed some extra over the top. No glue and it's settled solidly into place with no glue marks.
    As for using Tamiya tape....don't waste your money. Buy Tesa Tape. Same stuff and a fraction of the price for the quantity.
    https://uk.rs-online.com/web/p/masking-tapes/9139532/
    Same grade. Same tack. Exactly the same, I promise.
  5. 40 minutes ago, BigDan said:
    Sorry for the intrusion that got you so upset. It was my first time posting something on MSW and I hadn't figured out how it all worked. Again I apologize, I am slowly getting the hang of it. Thank you to the administrator for sorting it out by "splitting" away my post from PJG's.
    No worries!
    Your build deserves to have its own log so it can be referenced. If you've any more photos, please feel free to add to your log.
  6. 2 hours ago, PJG said:
    You know you haven't been keeping up on your build when you return to find that someone else's model has taken over your log 😂😮!
    Not that I don't think BigDan did a great job on his Fifie (I do), I'm just not sure the middle of my build log is the right place for it.
    1 hour ago, Blue Ensign said:
    It certainly confuses the issue, I did a double take when I first saw the post I thought blimey he's moved quick, he's reinstalled the hull and finished off the model.😀
    It is bad manners tho' to invade another modellers log, I see James has tried to give a large hint, to which Dan seemed oblivious.🙄
    B.E.
    Ok, I've split those photos into a separate build log.
  7. 16 minutes ago, reklein said:
    I'm currently building Trumpeters 1-350 Intrepid. The deck requires extensive decaling. I have applied  the base coats and am now ready for decals. Is it recommended to clear gloss coat the whole deck before decaling and then flat coating after? I see a lot of plastic  or any modelers doing that before decals.
    Bill
    You're always best glossing before decals, and if there's lots of moulded details on the deck, consider using a decal setting solution too. Once your decals are down, gloss over them before any weathering and a flat coat.
