Fine work on the Head works Bug, a great job you're doing. B.E.
- 2,191 replies
- confederacy
- Model Shipways
Glasses for detail work (changed by mod)
Blue Ensign replied to Bob Blarney's topic in Modeling tools and Workshop Equipment
Bit difficult when you're working on rigging detail on the model and yards prevent getting closer to the detail B.E. -
It's all looking very shipshape and Bristol fashion Bob, very nice work. I can so relate to your thoughts about future models, I have already decided that Pegasus will be my last square rigger, too testing on my eyes. B.E.
Nice touch shaping the Fore Channels Martin, and neat profiling on the Swivel mounts. I'm not convinced that my individual approach to the Entry steps will stand the test of time, but I always thought that it was a simple adjustment to make to revert to the plan configuration. B.E.
- 467 replies
- fly
- victory models
Magnificent! B.E.
- 2,625 replies
- kaiser wilhelm der grosse
- passenger steamer
Books for historic rigging reference
Blue Ensign replied to pshrynk's topic in Masting, rigging and sails
Not a great selling point when seeking a response to your enquiry. B.E. -
How Realistic Can One Make Sails?
Blue Ensign replied to Julie Mo's topic in Masting, rigging and sails
I've used it for years Antony, do all my rigging by reference to it. Steel is the basis of most modern writers on ship rigging. I do have a hard copy of Steel's Elements of Mastmaking, sailmaking, and Rigging, printed in elephant folio format by DN Goodchild. USA. It's a nice thing to have, but I use the online version constantly. Cheers, B.E. -
You may find the answer here. http://www.hnsa.org/resources/manuals-documents/age-of-sail/the-elements-and-practice-of-rigging-and-seamanship/sail-making-vol-i/ B.E. -
Nice job on the Crowsfeet Bob, they're not on my favourite job list either, in fact I've still not tied them off just in case I disturb them during the later rigging process. Interesting that Peter Goodwin indicates 1½" circ line (0.20mm diameter at scale) for the Crowsfeet; Steel shows ¾" circ line (0.1mm diameter at scale) in his tables for sloops of 300 tons so I went with 0.1mm line. A quick check between Goodwin and Steel's tables shows that Goodwin indicates slightly heavier rigging lines overall, and he quotes Lees in his sources list. I wonder if I could have got away with 0.20mm line, I think slightly heavier line for the Crowsfeet would make life easier. B.E.
Burton Pendants Guidance Please
Blue Ensign replied to markjay's topic in Masting, rigging and sails
Hi Mark, the Burton Pendants have nothing to do with the Main Stay. They are the first item of rigging over the mastheads and are used to attach tackles for heavy lifting. This can be by a thimble spliced into the end of the pendant into which a tackle is hooked, or by a block spliced into the end. They are followed over the masthead by the shrouds, back stays where appropriate, and finally the stays. Hope this helps. B.E. -
The problem with parrel trucks is that unless you are working at large scale they are very small particularly for the upper yards and my opinion is that scale is more important than material. Wood is fine if the scale suits but I had to resort to glass seed beads at 1:64 scale for the topsail yards, and micro brass tubing for the T'gallants. If authenticity is what you're after it should be borne in mind that parrel trucks are slightly barrel shaped rather than round. B.E.
Impressive result with your ships wheel Don, beautifully executed. B.E.
- 653 replies
- trabakul
- marisstella
Neat work Bob, I'm glad to see that you have had the foresight to fit the Main Topsail Brace lead blocks to the Mizen, something I missed to my cost in time trying to retro fit them. B.E.
Thank you Kirill, I must have missed your April post; the old forum with the full build log no longer exists, but I do have all the details fortunately. JPAM, glad you like the build B.E.
- 126 replies
- le superbe
- heller
Lol the mast pins were the last thing I saw before Jason's reply, now it makes perfect sense. That belay pin arrangement on the Mizen is the same as shown on the Pegasus kit plans, but I opted for the cleat arrangement. Glad we cleared that up B.E.
Very nice work on the masts Bob. Re the mast 'pin' is that simply to secure the yard to the mast as a modellers aid to rigging? I am a bit confused because you mention cleats as the usual fitting, The only cleats I am aware of in that area are the sling cleats on the yards. I have used small pins on my Pegasus to hold the yards whilst I rig the parrels etc. it makes life easier. B.E.
