Everything posted by hof00
Hi Chap, Regarding the Rigging for this, there's sod all in the Grand Scheme of things. Shrouds/Ratlines, a few Backstays, Winch Lines and a few Coils of "Rope" on Deck. (My build anyway) I used Wire for the Antenna Stuff. (Incidentally, I am almost out of 0.25mm "Beige" for the PD but have a reasonable supply at hand "Post" Cutty Sark build. I intend to try my best to keep up the resources I have to hand. ) Cheers....HOF.
- 130 replies
- mare nostrum
- artesania latina
Nice work Steve. Regarding Rigging material, I didn't have any issues of quantity, but, this was prior to the A/L downgrade of course. Cheers....HOF.
- 130 replies
- mare nostrum
- artesania latina
Very nice Sir!! Did you do the Rail first or the Bulwark Stanchions? Cheers....HOF.
- 130 replies
- mare nostrum
- artesania latina
Hi Steve, Yes I did.... Did it make it easier? I don't recall but I must have had a reason for it at the time. Have I helped? (Probably not) Cheers....HOF.
- 130 replies
- mare nostrum
- artesania latina
Yup, Thanks Steve, All Power Tools deserve that respect. After my first few goes with the Small Proxxon, I managed to cut into the end of my right Index Finger, believe me, it cut really quickly!! The Kerf is very fine, so compression and a week of Band Aids, all good. (I now use "Push Sticks" whenever possible.) I too have the Full sized machinery for Cabinet work, Etc. (I want to keep my Fingers firmly attached thank you. ) Cheers....HOF.
- 130 replies
- mare nostrum
- artesania latina
Thanks Steve, Good description, thank you. I use the Line covered in CA, about 20mm, and before the CA dries, I wipe with the "Digits." If the line isn't stiff enough, do it again until it is. You have then got a nice rigid thread you can push through all manner of tiny holes. (Blocks/Deadeyes/Rings) Once through the hole in question, grab the end with Tweezers, Hooks, whatever. Have a go on something "Off Ship" first. If the "Bodkin" gets brittle, (As it does after a few holes), repeat the CA and your good to go!! Unsure of where I got the tip but use this method exclusively, much easier than a needle threading device when the Rigging gets "Busy." Cheers....HOF.
- 134 replies
- artesania latina
- mare nostrum
Ditto Doug, Mixed version looks really "Sharp" Esp. after the finish!! Awesome job and kit Upgrade/Upgrade!! How are you getting on with the "Fish Box thingies?" I stacked mine after building the Wood Lattice that they rest on and Pinned with Brass Wire through to the Deck, no glue, so the "Stack" looked more or less like wot was on the Box. Cheers....HOF.
- 130 replies
- mare nostrum
- artesania latina
My two Cents worth, Make a "Bodkin" on 20mm with a bit of CA to stiffen the thread/line that you want to thread through. Cheers....HOF.
- 134 replies
- artesania latina
- mare nostrum
Hi Chap, The Blade does retract into the Table and also tilts. The Blades have about a 1.5mm Kerf but there is the option of the "Super Fine" 0.5 mm Kerf. (Not used in Anger yet. ) Cheers....HOF.
- 130 replies
- mare nostrum
- artesania latina
Yup, Got two Proxxon Saws, one tiny one, like yourself and the larger table Saw. Have not used this yet but looks promising when I have the need. (It's hard to get Proxxon anything here, have to talk to a supplier in Australia.) Cheers....HOF.
- 130 replies
- mare nostrum
- artesania latina
Hi Chap, Looking good. (Nice Miniature" Joinery skills.) Cheers....HOF.
- 130 replies
- mare nostrum
- artesania latina
Well Chap, If you planked the top of the Companionway, it would be consistent with the other Deck structures. Your call!! (You could "Dry Fit" the Mahogany to see how it looks first?) Like the Jon Derre effect!! (Individuality,) Your piece of Marine Art, no one else's. Cheers....HOF.
- 130 replies
- mare nostrum
- artesania latina
Nice!! Are you going with a "Working" Companion Way Door or not possible with this Kit version? Cheers....HOF.
- 130 replies
- mare nostrum
- artesania latina
You'll get back into it Chap. No Stress!! If it's any consolation, I've got "Sanson" and "Endeavour" waiting for my attentions. (Sanson to be finished after Pen Duick.) Definitely a hobby and more an "Object De Art." (My View anyway.) Cheers....HOF.
- 291 replies
- bounty
- billing boats
Hi Chap, Have you had a look at the "Billings" catalogue? If you have a look at the Artesania Latina.net catalogue, there are just heaps of bits and pieces. (You just need the Part # then get Cornwall Models to order the bits in for you, Unsure if you can purchase direct from A/L) Cheers....HOF.
- 130 replies
- mare nostrum
- artesania latina
Very nice!! The Wheel House looks great. If you're going to make another "Painted" version, you could do a Diorama with the Boat on a Slipway for Maintenance and use the Engine as if it was being worked on? (Just an idea....) Cheers....HOF.
- 130 replies
- mare nostrum
- artesania latina
Doug, It's a Tease!! Seriously, I'm looking forward to the results also. Cheers....HOF.
- 130 replies
- mare nostrum
- artesania latina
Hi Steve, Nice progress, looking really good. The White is White Lead Paint, producing a dirty White finish. The alternative seems to have been a mixture of Wood-Coal Tar that gave an almost Black finish, Sulphur was often added to the mixture to ward off Toredo. ("Historic Ship Models" - Wolfram Zu Mondfeld)
- 291 replies
- bounty
- billing boats
Very Nice work Chap!! I really like the "Upgraded" version to an otherwise mediocre kit. Brings back a few memories.... Cheers....HOF.
- 130 replies
- mare nostrum
- artesania latina
Thanks Chap!! The research continues.... Cheers....HOF.
Has anyone heard of a "Gaff Reef?" Currently building A/L Pen Duick and the Rigging in question runs in a series of Single Blocks and Lines under and the length of the Main Boom. I am finding it difficult to reconcile the plans with where it starts/finishes and what items are terminated to it. Google is not all that helpful today.... Any advice/diagrams would be very much appreciated. Cheers....HOF.
Thanks Steve, It was a real labour of love.... (Kit Level - Expert, I found out why) Cheers....HOF.
- 207 replies
- billing boats
- cutty sark
Hi Peter, Nice work and nice recovery regarding the old wood components. Cheers....HOF.
- 207 replies
- billing boats
- cutty sark
