Everything posted by Canute
Robert, be careful with the Plastruct goods. They come in white styrene and gray ABS plastic. The cement for ABS is different from styrene. Make sure you use the correct stuff.
There is a site with line drawings and pictures of WW I ships and Seydlitz in particular here: http://www.sms-navy.com/bc/sms_bc_seydlitz.htm A nice hard cover book with one chapter for Seydlitz is: https://www.amazon.com/German-Battlecruisers-World-War-One/dp/1591141915/ref=sr_1_1?ie=UTF8&qid=1537528604&sr=8-1&keywords=german+battlecruisers+of+world+war+one Greg has found some pretty clear photos, which will really help in placing the anti torpedo nets.
Glad you are recovering from the pneumonia, Jim. Only had one bout myself, but I've been more careful of late. The 3 days in hospital were OK while I was on the cardiac floor, but I got shipped to a freezing dungeon after my 48 hour test for heart issues. Couldn't wait to get out. I really do appreciate your watercolors. Thank you for sharing.
Ah, you're giving them a run for the money. And you're having fun doing it.
- 405 replies
- tamiya
- king george v
Asheville area looked like that today. The storm is coming tomorrow for us, since it is moving so slowly.
- 742 replies
- constitution
- frigate
I'm using Win 7/Firefox, too, on this entry. You may need to update your "old, outdated" system.
I've seen most chalks and pastels disappear when spraying a fixative over them. Started using something called Pan Pastels, which can be applied with a variety of tools (brushes, sponges, etc.) No fixative required. Here's a link: http://www.modelingcolors.com/index.html They do list some European outlets. Nothing for Oz or Japan.
- 405 replies
- tamiya
- king george v
I find that working on fine details has to be done in short bursts. Try building Z scale (1/220) structures or N scale (1/160) double hung windows. <Remind me not to do those ever again!> Do one operation at a time (glaze a window, say) and do 2-4 operations. Then walk away; maybe work on something you can see without using your optical enhancers. You won't get done in a hurry, but what's the fun in that? Like Greg said, sometimes you feel you're plodding along. I've been rolling brass HO scale piping clamps for a grain hopper. The detail set gave me more than enough and happily none have been launched into Never-never Land. Having good pliers of the correct size helps there, too. 👍
- 405 replies
- tamiya
- king george v
Well done on that bridge. And your weapons work is really good.
- 467 replies
- mikasa
- wave models
Some of us are geographically challenged, Greg. And I think Carl was tired, too. I better start saving for the PE sets. Don't know if there will be any 3D printed stuff. Looks unlikely.
- 1,090 replies
- showcase models
- vendetta
Eric, nicely done decking. I, too, use that vinegar/steel wool weathering method. Normally, I brush the stuff on the strips. Just dipping in and quickly removing to a drying sheet is a good idea. Prevents too dark a result. I'll use that tip of removing beaded stains spots now, too.
- 599 replies
- sidewheeler
- arabia
(and 4 more)
Guys, I'd use the branded thinner recommended for the line of paint you are using, since you're trying to dilute and spray or brush it onto your model. You want it to go on smooth. Use the water, Windex, or home brewed other thinners to clean brushes and air brushes. And wash the paint crumbs, stuck up in the bristles, out with soap and water. I have some old brushes I used to apply oil based paint, back in the day. Now I use them for dry brushing.
The nets are brass, huh? Gonna be a fun build.
- 1,090 replies
- showcase models
- vendetta
Denis, I use a red auto body putty Bondo brand Glazing & Spot Putty. Smelly, but it works. Does a slight etch into the plastic, so it won't move.
I've been using a broken drill bit ( #78 or so, 0.016 inch US wire size drill) to put the tiny drop where I need it. And then burn the dried stuff off the end when it gets gummed up. Got a lot of those broken #78s, since you just look at them cross-eyed to snap them .
- 1,090 replies
- showcase models
- vendetta
The master pattern makers are using 3D printing to do up their masters nowadays. I just got a resin kit of a railroad boxcar with oil-canning of the sides. Relatively easy to model in HO (1/87) scale. Don't know how tough it would be, showing these effects, on 3D masters for our usual steel ship scales, like 1/200 or 1/350.
Model Monkey, a 3D printer outfit, is advertising Arizona parts in the old Revell box scale in gray resin: https://www.model-monkey.com/1-426-scale
