Everything posted by Canute
I suspect most modern navies use anti-slip paints nowadays. A coat of flat paint should suffice at the scales we build in. This is a paint guide for a US carrier, but it has a number of paint brands and also adjusts for scale. Base chart: https://www.cybermodeler.com/naval/essex/essex_profile33-10a.shtml Scale fade discussion: https://www.cybermodeler.com/color/scale_effect.shtml
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
I'd use the Lifecolour thinner, since it is formulated for that paint. Without that, I'd use distilled water; no telling what might be added to your municipal water. I wouldn't use the Lifecolour thinner for cleanup, too pricy for that. You could make your own, as this fellow did: https://www.cybermodeler.com/tips/thinner.shtml
Piet, thank you for letting us see a part of your personal connection with the star-crossed ships of ABDA. You've done a superb job in your memorial.
- 378 replies
- java
- pacific crossroads
Railroads used something called car cement to seal up the panel seams on metal roofs and that gunk was black to start. Might use a charcoal grey for that. Straight black would be way too dark.
- 83 replies
- marcle models
- card
Craig, sign me up for this one, too. Quite a novel ship.
- 89 replies
- independence lcs-2
- trumpeter
Same here, running Win7 and Firefox, I can see all the pix on this log.
- 122 replies
- tamiya
- King George V
I guess so, Mark. I've seen airplane models done up with salt. Didn't realize you wash off the areas with water, thought it was done dry.
- 405 replies
- tamiya
- king george v
Greg, this chipping fluid you used intrigues me. How do you apply it? Is it random or applied across the whole surface? Do you leave any on the hull after you brush it?
- 405 replies
- tamiya
- king george v
Hmm, another technique. I think I like the pant leg method, a bit of dust/dirt versus grease. Any grease/oils are anathema for our paints sticking properly.
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
OC, you may want to consider working from the center-line of the ship out to the bulwarks. The superstructure looks like a mountain, so you may want to work from the middle out.
I use both tapes, although I try to cut the blue painter's tape with a straight edge to make sure the edges are sharp. Also stick it on my pant leg to reduce the stickiness of the blue tape.
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
That's what the Tamiya masking tape is for. Helps prevent messing up paint jobs.
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
Carl, did you cut individual strips or is it a piece of scribed wood or plastic? Nicely done, either way. Did you pre-shade the hull?
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
Working on stuff that tiny, I'd recommend about 30 minutes and switch off to bigger stuff. Can't work too well when you're cross-eyed.
Carl, that was in an era of multiple marches for temperance. And the US did have that Constitutional Amendment (#18) banning alcohol in 1919. We woke up and repealed the 18th with the 21st in 1933. Prohibition of alcohol didn't sit well with most folks.
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
The USN is officially "dry". They gave up shipboard alcohol way back when. Strongest stuff they serve is coffee. That's the start of the reference to coffee as "joe", since the Secretary of the Navy when it took place was a gentleman by the name of Josephus Daniels. I suspect there have been a gazillion workarounds over the years.
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
Cripes, that's a miniature of every single piece of the real thing. Good luck, Kevin.
- 83 replies
- marcle models
- card
Splendid Cats, Queen Elizabeth fast battleships, Ostfrieseland, lots of stuff. Would be fun.
- 1,090 replies
- showcase models
- vendetta
Jewels versus tinker toys with those 8 x 20mm cannon. Cross-eyed yet?
- 405 replies
- tamiya
- king george v
