michael mott
Everything posted by michael mott
  1. Hi Matija I just came to your build today, wonderful work on this boat, there is an inherent charm in the shape and detail of her. Michael
  2. beautiful workmanship on the interior Bob, I can almost see the the deck even though it is not there. Michael
  3. Steve I am glad that I have been of help regarding these mechanisms. Gary, thank you for your kind words. I have been very fortunate in my working career inasmuch that I have always been able to work doing the things I enjoy doing the most. The interesting thing is that while I worked building models commercially I did not have much interest in building models for myself. I have a tendency to work in spurts and am very focused during these times, I think it has a lot to do with solving ways to accomplish the next part. currently I am procrastinating about what part to tackle next. A little bit of "model-makers block" Michael
  4. An amazing amount of work Nils. Quite and education sorting out all the control points and leads in that forest of lines. Michael
  5. Nice depiction of some working tools in the emblem on the cover. I am also interested in the small chisels they look beautiful. Michael
  6. Mark Thank you for your instruction, I did anticipate it coming. Michael
  7. Fantastic work there Patrick, I am assuming you will be fluffing up the pillows in the master bed suit ;~) Michael
  8. Hi Ben what a brilliant way to keep your family members happy, looking forward to seeing the doll boat come together, your idea has given me an idea for my granddaughter. Michael
  9. I appreciate your candid comment Ed. I was a bit surprised by the gloss, perhaps most by the degree of it more than the fact that it is glossy. I can also appreciate your need to not dally over these things too long when dead lines loom. I think that we come up against the whole issue again of scaling nature with regard to the finishes we impart on our models. sort of reminds me in a way of the old comment about if we scaled the earth down to the size of a billiard ball it would be much smoother than a billiard ball. I hope that you will not be upset later that you are not completely satisfied now, later. Regards Michael
  10. Toni Thank you for taking the time to share the display case set up. The mahogany cases lend such a great sense of timeless quality to the visual presentation of your work. Being able to reflect on your development and having the ability to see where you have been with regard to the ships you have built. The pysanky display is amazing as well. I cannot imagine how many hours you have spent doing all the work in those cases. Prolific seems to pale as a descriptor. Thank you again for sharing. Michael
  11. A great job on the curves Bob, Have you considered party balloons for the vinyl they are a type of rubber and come in all sorts of colours. Michael
  12. I find that this is one of the more engaging aspects of going to the craft stores, What can this be used for? is the song running through my head. Michael
  13. Bob, what is the purpose for the vinyl? once I know that I can give it some thought. Michael
  14. Very clean and precise work Alex, I am enjoying watching your progress. Michael
  15. Lextin, another way to clamp the pieces once you have cleaned the old glue off is to use a couple of pieces of wood like this simple wood clamps made from scrap. once the glue is set knock out the wedges and the clamps can be taken apart for some other use. Michael
  16. hi Scott, a great start I will be following along. I am looking forward to seeing your steam plant come together as well. Michael
  17. Mark in my case it was a commercial melt pot that was electric, the chap I worked for was a bit unscrupulous and would cheap out on the quality of the metal sometimes, I wont go into the details of one event that scared the .... out of me! there was metal all over the room. I went home early that day after giving him an earful. Michael
  18. Mark your first attempts at casting look great, That said I thought that Druxey's comment about casting the barrel muzzle up was the way I would have approached it, one other thought that occurs to me is to make the bottom of your pouring sprue (gate) a smooth curve rather than the right angles that you have done in your first one. The venting looks good to me. something you might try is to leave the vents off until you start to cast especially with the pewter, and as you test the pours you can use a sharp #11 blade to cut v groove vents from the trunnions and begin with small almost no holes and increase them till the right flow occurs. sometimes a little back pressure helps to fill the area right next to the main body rather than a fast flow. The talcum powder helps a great deal with the metal, I had a small muslin bag that I used to fill with talc and used it to dust the moulds the casting worked best when the moulds had warmed up after a few runs, so you will notice that the casting improves usually with the 2nd 3rd 4th pours and so on until the mould reaches its optimal working temp. I spent many evenings of my boyhood casting costume jewelery in 12 inch circular centrifugal moulds, that were made by vulcanizing them in a metal shell under great pressure. The casting machine had a turntable that was like a record turntable with 6 counterbalance weights that would apply pressure to the steel plate on top of the two halves of the mould, there was no speed control as such but I learned by trial and error what speeds and speed of pour into the central cavity. I used to get paid 3 shillings per gross and there were eight to twelve pieces per mould depending on the particular shape. I used to cast 3 gross per evening (guitar callouses couldn't hold a candle to mine in those days) When I had my own business building models I had the commercial casting equipment but eventually sold it because i didn't use it much. Michael
