Trussben
Everything posted by Trussben
  1. Nice work Sjors, you will have to be VERY careful reaching around her now. Ben
  2. Can somebody tell me the drill and tap size that I need for bolting the keel to the build board. Ben
  3. Nice Progress Maury - Nice to hear that it has started to be less delicate, that worries me for when I get to that point with my hands. ben
  4. Here is my first attempt completed, rabbet cut with a V gouge and rising wood installed. ben
  5. Hi Thomas and thanks for reposting your most excellent build log of the Syren, simply stunning work. Ben
  6. Excellent update Sjors, looking mighty fine and very large! Ben
  7. Interesting mounting ideas bob, I still haven't decided what I want to do but you have given me another idea so thanks. Ben
  8. Thanks CRF and Druxey for the advice on the rabbet, first off I am going to try practicing on scrap using my v gouge chisel, if I cannot achieve good results then I will try the scraper. Ben
  9. An update of the Keel. The 0.5mm Rivets were installed as per loaction on the plan. False Keel harris joint was cut and black paper added and then glued to the bottom of the keel. Rising wood took quite a few hours to make using nothing but hand tools and I think it came out ok but we shall see. Now onto carving the rabbit in the keel - The part I have dreaded the most up to now, muck it up and I can throw away several hours of work, but I guess its all good practice anyway! ben
  10. Thanks Mark, I will try to do you and the others proud, I'm already enjoying it more than kit building but don't tell my Confed!
  11. Hi Bob and welcome, nice to have another Longboat here and believe me that without everybody's including your logs this place would not be what it is. Keep up the great work but take it slow, she is a mighty delicate thing until you get some planking on her. Ben
  12. I remember the reversed walkway from before but your catch and fix was excellent. Skid beams are great as well. Ben
  13. Thanks Druxey for the info, bad terminology on my part as I did know they were bolts. I ordered brass scale rivets from scalehardware the same as Greg used, 0.5mm head diameter, but the shaft is 0.034 which is a #80 drill bit and I have no bits or way to drill all the way through, so I printed out the plans and cut out the keel section with a razor, I will use this to mark out both sides and drill them from each side. Ben
  14. Very nice work on the cannons and breechings, I also do like the trademark brass ends to the cannons - different and an effective change in contrast. Now that he who has no name has proclaimed an Aggy build, I can see the Sjorsian wars military buildup is in full swing again and Augie is rattling sabers about a LARGE next build, ho hum! Nice work man and keep it up. Ben
  15. Nice to have you along for the ride Sjors, I hope it will be an interesting voyage for both of us. Ben
  16. Hi Rusty, yeh 3 at at time for the next two weeks, that's how close the longboat is. I bought some scale brass rivets 0.5mm for the keel treenails but I will have to use a #80 drill bit so we shall see how many I break.
  17. Hi Greg and CRF and thanks. Greg - Question 1 already, can I assume that the treenails go right through the Keel? In other words seen on both sides of the keel? ben
  18. Here is the keel that I have made using only a razor saw, chisel and a file. The black joints are made using art paper of a thickness 0.008. I will be using Titebond wood glue for the entire build. Its not perfect as you could get with a table saw but I think its pretty good for a first attempt and I may well make another but I want to practice making the false keel and rising wood and carving the rabbit before I do any retrys. ben
  19. Well All - Here is the beginning of my Scratch Building career, I chose the ECHO cross section from Admiralty Models because of the work by Greg & David in the TFFM books that I own and intend to build a Swan class one day but needed something easier than a full model to start with. This is going to be very slow to begin with as I am working on my Confederacy which is about half way completed and will be taking most of my limited modelling time. Also I am still building up my collection of tools, I have plenty of hand tools and a beautiful Dewalt scroll saw, but I still wish to get a JimSaw and thickness sander - however I will start with hand tools for most of the work. The first pic is the wood framing package from AM which is supplied to them by Jeff @ Hobbymill, Its Boxwood and machined to the sizes that are called for in the plans, there seems to be quite a bit of material supplied above what would be needed to actually frame the model for those Opps moments which Im sure I will have plenty of in my learning curve. I have been watching the great starts that others here have made on this and hope that I can acheive something close to them. BTW the first version I make will be just the hull framing, no planking or internal framing, then I will make a second version which will be the full Monty. And here we go!! ben
  20. I will defiantly be watching this build, thanks for starting a log of her. Ben
  21. Nice choice on the Agammenon, she's a fine ship and I'm sure you will do her justice. Myself I will be finishing my Longboat in the next few weeks while I wait for paint to dry on the Confed, as soon as she's out of dock #2, my scratch building career will begin on the Echo cross section. I look forward to seeing you finish the Mirage. Ben
  22. I'm with the others, I think a Confed in your future is a great idea seeing what you have accomplished with the Syren. Ben
  23. Wow buddy, the bloody thing is huge, you'll be able to fire real mortars with it, gonna need a lot of wood to build her - I worry about your pension again, rice and beans for the foreseeable future I think. Ben
  24. Nope, Just saying that you must be a damn surgeon with that Sander, If I used it the entire starboard side would have been gone.
  25. I'd forgotton you hand to make all your chainplates by hand, I find that a task and Im glad there is PE in the kit. ben
