Baker
Everything posted by Baker
  1. Welcome, and good luck with your build
  2. Great work on this model I am not such an expert in windows on ship models. But this is how I made mine (post 178)
  3. Greetings and welcome to MSW
  4. Update, The chimney from the kitchen below deck. On most models, the output faces forward. On the old plan it is directed backwards. Original piece. Adjusted and mounted on deck Extra detail on the channels The windlass Original piece. Adjusted and mounted With extra detail
  5. Thanks. I think it's a standard helmet. I built this model in the 80s (without help from the internet it was searching and guessing) The 2 figures on motorbikes with the Airfix recovery set in scale 1/76 had roughly the same helmet. That was then my only reference https://www.google.com/search?q=airfix+recovery+set&rlz=1C1SFXN_enBE500BE526&tbm=isch&source=iu&ictx=1&fir=4SoVkQADE-nmUM%3A%2CixGGk9LuLJDy_M%2C_&vet=1&usg=AI4_-kR9S9CH25Ykw9FlDldhKTM74iBSFQ&sa=X&ved=2ahUKEwjhi5-L6_blAhWI66QKHQ1UCO0Q9QEwAnoECAYQCA#imgrc=bX6dobsw-r-wUM:&vet=1 Did a quick search on google, It looks like a real standard issue helmet https://www.google.com/search?q=british+motorcycle+helmets+ww2&rlz=1C1SFXN_enBE500BE526&source=lnms&sa=X&ved=0ahUKEwin3M6-6_blAhVRDOwKHQ_hBokQ_AUIDSgA&biw=1600&bih=757&dpr=1 Ps, If I remember correctly. There are a few difficult construction phases in this model. You can always ask if something is not clear
  6. Long, long ago I built the military version. The original brand was Esci. i have build al there models on the 1/9 scale Good luck with the build
  7. Great models
  8. Greetings And
  9. Greetings, Patrick
  10. Great work with the painting And everything else also of course 👍👍
  11. I now have 5 planks on each side of the mast. And there comes central 1 in the middle, this plank will then be slightly wider than the other planks. My knowledge of the English language is not that good (Never learned it at school). So, Mr. Google says chart = grafiek = Since I am active on this forum my English knowledge has improved. But it looks if there are different ways to speak and write English. English english American English Australian English Is this correct ?
  12. Small update, The captain's cabin is furnished. More detail can be added but that is not really going to remain visible. The poop deck planking has started. First a test, the planks are made a bit tapered. Planking in progress. Thanks for following
  13. Small update, Some PE parts have been used (leftovers of military modeling) Looking around this forum for different Bounty logs. It seems like there are different models. Every manufacturer of ship models has its own version. I go for this solution. Thanks for following
  14. There are different types of masking tape. For every surface there is a tape with a different adhesive strength. The blue tape of the 3M company (my employer) gave me the best results for this purpose. With only some small errors here and there that needs to be repainted afterwards (Scraping off with a knife and thereafter repainting) And, great work GL.
  15. Great model. Welcome to MSW
  16. Welcome to MSW from Belgium
  17. Welkom buurman (Welcome neighbor)
  18. Greetings, Patrick
  19. Nice models. Greetings, and welcome to MSW
  20. Welcome to MSM and greetings from Belgium.
  21. Welcome to MSW, and good luck with your model.
