Tigersteve
Everything posted by Tigersteve
  1. Looks great! Make the rest now while you have the momentum. Steve
  2. Hi Moab and welcome. There are a couple of sources I will check out. https://www.crowntimberyard.com/ http://www.ocoochhardwoods.com/ Steve
  3. Probably not the smoothest functioning Serv-o-Matic, but it’s functioning fairly well and complete. Chuck sent me a new set of gears so I have a couple of extras. I’m making a couple of adjustments to my workspace. Mayflower construction will begin soon Steve
  4. Disk attachment. The drum attachment will destroy the frames. Steve
  5. Good choice. Lots of sanding next. I was able to use my rotary tool for some of the sanding, especially at the bow and stern. You would need to be careful though. I hit this part in several sessions. It’s tedious, but very important. All the remaining work rests on these frames, which need to be very thin. Steve
  6. Thank you. It is a beautiful machine. I’m not looking forward to gluing with CA, but it must be done. The cherry wood is very nice and perfect for this. I’m looking forward to clearing this little project off the work space and starting the Mayflower. Steve
  7. Partial assembly of the machine. The gears are not glued to the brass tubes. I suggest test fitting the gears and rotating them before you glue to make sure they rotate freely. Two of my gears were just a bit off when I glued them and this caused them to not rotate freely. Parts are laser cut precisely. Chuck is mailing me some new ones. Before assembly, a third sanding and coat of Wipe-on-Poly was applied. A very smooth finish was the result. Steve
  8. A very precise build so far! Steve
  9. If you’re not loving how dark the stain is you can sand it. That will lighten the color. Steve
