Tigersteve
Everything posted by Tigersteve
  1. I agree with Per. Seems awfully expensive for the case. Regarding the photos- try placing it near a window with daylight. No flash. Don't shoot the photo towards the daylight though. Steve
  2. Looks good. Don't forget to line the first couple frames and the last couple. Steve
  3. Add another "wow" to the log. Steve
  4. Looks like a nice kit. I'd like to join the fun. Steve
  5. I love your work philosophy. Good choice to rip out and redo. I actually planked mine twice. First time I ruined it with treenailing and model expo sent me replacement parts so I could do it all again. :-) It's a painful decision to redo something but it's always worth it in the end. Steve
  6. The aft platform was fairly simple to craft. Edge-glued after using a #2 pencil to simulate the caulking. After I was satisfied with the shape of my template I traced it onto my maple strips. Straight cuts were made with several passes of an exact knife for the general shape. The rotory tool with sanding disk got the wood close to the outline so I could fine sand the rest. Since the strips were edge-glued, there was a slight bend. I braced the back with a single strip of wood. One more sanding and coat of finish is needed before it is glued. Steve
  7. You are correct. Model Expo changed the instructions regarding the thwart dimensions. Plans were the way to go. Nice work. Steve
  8. Congrats Derek on another ridiculously fast Longboat build! I like this version better than the first. Nice color scheme. Steve
  9. As long as you line off the hull you should be fine. About the first 4-5 bulkheads the taper starts at the bow. There is also some tapering needed at the stern. Again- Bob F illustrates a good tutorial. Hope this helps. Steve
  10. Thank you for the nice comments and likes. There will be a bit of painting. Minimal as possible. Steve
  11. That looks good. Don't forget to taper the planks at the bow. I do not see any tick marks in that area. You will soon run out of room. Steve
  12. Below are the process photos of the floorboard installation. Shaping the planks was accomplished first. I traced a cap to create the rounded shape at the bow. Next step was to install the middle plank. After this dried, the next two outer planks were glued. Finally, the last two planks were installed. Wipe-on-Poly was applied the following day. Five non-consecutive days to complete this process. After applying the finish I noticed a plank was a bit loose. This will be fastened before the next steps. Steve
  13. Just take your time with it it's a challenge, but you will learn a lot. There are dozens of longboat logs, but BobF has the most detailed and impressive one. Erik's log is linked below. Another very clean log. His garboard is placed a bit more forward, but his plan worked very well for him. Steve
  14. That is incorrect. It is the other way around. Take a long look at BobF's log. It will help you a lot. Steve
