VTHokiEE
Everything posted by VTHokiEE
  1. I agree, I actually picked one up based on that thread and have been doing my best to use it more and more. I suppose I meant larger sanding, mainly the hull after planking. I made a saw dust mess in my garage doing that.
  2. Very cool pictures, thanks for sharing! It doesn’t look all that disorganized (maybe that says something about my area though...). How do you keep sawdust from getting everywhere?
  3. I think that whatever you choose she’ll have a fond memory of the time; I also think that completing any model at 6 is a very proud accomplishment. It may be a lot to find a model that you’re able to build at 6 that you’re still “proud” of in a modeling sense much later. I’d love to see what people suggest though as I may try to get my 7 year old or eventually 3 year old interested in the hobby. Maybe something like the Optimist Dinghy from MarisStella? http://www.marisstella.hr/gotovi_modeli_galery.php?id=32&tip=2&optimist-dinghy39cm-1-6
  4. That’s a splendid idea, what size tubing do you use and do you have brand recommendations?
  5. Thanks! I haven’t done any coppering yet but I’m certain there will be some plates I have to remove when I do a build with them. I wasn’t certain if simply pulling them off would rip at the planks too much.
  6. Thanks, that’s great to know! I don’t mind tinkering (I have a 3D printer that needed a decent amount of modifications). As soon as I can think up how to arrange the garage I think I’ll pick one up.
  7. Awesome review! I’ve had a desktop laser cutter on my mind for a little while. I was looking at something like this: https://www.amazon.com/Orion-Motor-Tech-Upgraded-Engraving/dp/B07SQQMN3F
  8. I bought some syringes (https://www.amazon.com/gp/aw/d/B01HFTYINS/) to get a little more precise with my glue application.
  9. Are the sails going to be pre-sewn? Are you planning on using them in your build (or is Chris, I’m curious what they will look like)? Being an amateur the differences of wood frequently escape me (aside from the “that looks nice” aspect). What visually would be different between the decks? Given the potential beginner market it may be a good idea to do side by side pictures so that a novice has a better idea of what the upgrade means to them (or maybe it’s simply me 🙂). I’m looking forward to the two builds!
  10. Thank you! That was a trying time to say the least for me, but I am very glad that I redid it. I learned a lot from it (and hopefully some of that learning will translate into a relaxing second planking). I’m very much enjoying watching your speedy build and learning a lot from that as well.
  11. I had started the V-108 as well, but stalled. I wasn’t a huge fan of all the cuts as well. Is there any significant cutting with these laser cut kits? I’ve been hesitant to buy a paper model because I didn’t really know what to expect (and I probably should try something smaller like a lighthouse first). I’m excited to follow your build along!
  12. Small update: I still need to attach the top 1x4mm strip in order to call the 1st planking complete but after a good deal of sanding and some filling here I am: Next up I have to attach the stern post; I’ll have to be careful after that in order not to knock it right off again.
  13. I would recommend going to a physical store for DAP Rapidfuse where it will be cheaper; I see it at Walmart for around $5 and Lowes for about $6 (or buy it online from a different source).
  14. I've found these videos are helpful as well regarding another planking method:
  15. What type of CA glue did you use? I think using CA takes a lot of practice, but maybe a gel version for things like planking would help prevent the stains.
  16. I’m not certain if you did or not based on your pictures but I have seen it recommended that you plank both sides at once to minimize the chance of the hull warping. I don’t have enough experience to know how critical that is but it might be something to keep in mind in the future. It’s looking good so far!
  17. I promised myself I wouldn’t buy a new kit until I finished my current one. I’m blaming you and your build log if I break my promise 😂
  18. Ha, it took me a few minutes but I see what you mean (and I’m glad I posted the picture). I shaped it based off the other side (which wasn’t the best idea). I’m not going to change it now (first layer reasoning) but thank you for pointing out my error so I can correct it on the 2nd planking!
  19. I wanted to emphasize your materials, I had to buy extra lime wood planks (because I stink at planking) and the planks I bought were no where near the quality of your wood. I really enjoy your material selection (now to learn how not to make a mess of them 😁) and I’m glad to pay for the quality.
  20. I vote yes, go for it. The build is coming along really nicely!
  21. Here is a picture of where I am now: Due to the untapered garboard plank the remaining 4 planks will get a little thin on the stern. Maybe I’ll try to get fancy and do a drop plank (I think that is the right term?) since it’ll get covered anyway.
  22. Thank you! I think wood filler will be able to sort out the dips pretty well. I placed the final plank on one side this morning. I made the mistake of doing the garboard plank last so it’s too skinny, but as a first layer it’ll do. On the other side I think I’ll run a non-tapered plank for the garboard plank (if possible) to see how it would be done on the second layer and then mark out the hull for the remaining planks. That’s a good point, I am striving for the former but I wasn’t considering the later. I’ll keep an eye out for that.
