BANYAN
SPECIAL CONTRIBUTOR
Everything posted by BANYAN
  1. Nice progress Steven; those arcades look good. It appears you have made best use of the grain direction to provide a little strength. cheers Pat
  2. Hi Pete, you've made some progress since I saw your diorama. I like the engineering you are using and assume the light beam (optical switch) is a better option than a limit switch at each end? Folks, having seen this diorama I can say that the actual construction looks even better to the eye than the photos show; a testament to Pete's artistic abilities. cheers Pat
  3. Hi Doug, that is unusual indeed. I can't help with the diagonal knees but there is some discussion about iron knees in James Peake - Rudiments of Naval Architecture_1851 (see plates 6 and 7 amongst others) which discusses the iron fittings used in hull construction. This is available as a pdf online. cheers Pat
  4. Looks good UV, like the way the way the truks (top bits) turned out Cheers Pat
  5. That is looking great Michael; and agree with Druxey, the joinery is very good. cheers Pat
  6. Thanks OC, things have slowed a little lately while I do more research and produce some parts (and a road trip of 10 days departing Monday coming) Hope to do some work on my Vampire on return also. cheers
  7. Nice 'bodging' Rob, looks functional and appropriate at the scale you are working cheers Pat
  8. Great idea Rob; I look forward to seeing how these turn out. cheers Pat
  9. I always enjoy seeing updates to your build; the work is exceptionally good. cheers Pat
  10. Thanks Tecko; appreciate you looking in and commenting. cheers Pat
  11. Even with the 'tails' to be docked you can see the quality of the rigging and fittings ED; really like those spider bands. cheers Pat
  12. Thanks for looking Joss. WRT footropes, I soaked mine in diluted PVA and shaped them as they dried; might be worth a try? cheers Pat
  13. You did a very fine restoration on that model Michael and I am sure it will always be a great memory. That workshop look great with plenty of natural light. cheers Pat
  14. Quite the production run GL; look forward to the hull coming together. cheers Pat
  15. You don't stand still do you Denis, i just found your new build and your well into it already! Looks good! I'll take more time to have a better look now that I have found it cheers Pat
  16. A pleasure to meet you the other night Tim and see this little beauty; you have done a great job on her. cheers Pat
  17. Richmond, also try Float-A-Boat in Melbourne for scale rope; they have a range. Also, you could try Modellers Central (ex Modellers Shipyard in Sydney. cheers Pat
  18. Excellent work as usual Ed; appreciate the tips on the processes involved. cheers Pat
  19. That's what it is all about Rod - live and learn looks good. cheers Pat
  20. Nice work OC, she came up a treat. Make sure you find 'pride of place' on the display stand for her eventually. cheers Pat
