Everything posted by BANYAN
Nice progress; would driving (punching) the nails be easier, you would only need to go a half millimeter or so - BUT PLEASE DO a test first. If feasible, you could fill them as part of the overall fairing effort? AL usually uses limewood as the first layer which is soft and somewhat forgiving so should not split if not over aggressive with the punching. cheers Pat
That looks great Denis, those nets and gear are really starting to take shape. cheers Pat
You're getting quite the dab hand at this Greg; those gun turrets look very good indeed. Nice work. cheers Pat
Looks like it was a great event; glad to hear you were able to enjoy it. Some really well made small models thercheers Pat
You're powering along mate. Glad you saw that as a minor setback and that you took the plunge and fixed that pesky bulkhead - she will look all the better for it. cheers Pat
- 742 replies
- constitution
- frigate
Once again, these vessels show off their amazing simple but elegant lines - nice work Russ. cheers Pat
- 420 replies
- captain roy
- lugger
Go on, get out in the snow Denis! You need a path to the road which goes to your supplier for those extra half round clips That is some nice progress on the nets and trawl booms - this is going to look really good fitted up. cheers Pat
Worth the wait; looks good Sjors. She now has her poles and branches cheers Pat
- 1,616 replies
- caldercraft
- agamemnon
Vossie, There are many ways to skin the planking cat if you accept you need to spile. My prefered method is to bevel on the upper edge of the new plank (same as Chuck I think). I found that if I put a bevel on the lower edge of the laid plank (before fixing), that I often had to bevel the top edge of the new plank also anyway. The top edge bevel only meant that I could get a good clean joint knowing the plank above had a good solid straight edge to butt to and some light sanding levelled any thickness difference. Looking at your last photo I think you may be tapering too much (I know some of this is due to angle of the shot and angle the model is sitting, but there appears to be an upward sweep developing. I think you are doing it the same way I did, in that I only tapered where I needed, and for me it was not from half way, but further forward or aft. I was doing Endeavour though and she had very rounded (bluff) bows so the planks were pretty level for at least one half the length of the ship. cheers Pat
- 714 replies
- lady nelson
- victory models
I want one, I want one! Very nice use of technology to make the job a little easier and achieve excellent results. cheers Pat
That looks pretty good Greg; with that additional work it should very realistic. How did you hold up in the heat? cheers Pat
Very nice fit Russ, won't have any trouble keeping these aligned when gluing up as they all seem to sit very square. cheers Pat
- 420 replies
- captain roy
- lugger
Vossie, I found that using rubber bands around the hull with balsa wood block wedged between band and the plank worked best. I also put a strip of electricians tape on the block face closest to the plank to avoid any glue seepage sticking to the block. I tried all those different clamping adaptions but found this to be the easiest to use and proved quite effective. The thicker rubber bands proved best and they simply stayed on the hull throughout and I simply adjusted the blocks as required. if you get the right tension/pressure on the rubber bands the blocks keeps everything in place and yet the keel etc won't get marked. In some places I had to use additional larger blocks to get the right pressure but the basa was dirt cheap at the local hardware store. cheers Pat
- 714 replies
- lady nelson
- victory models
Small but significant progress Denis, the look of the chain on those drag poles/booms look very natural - great effect achieved. cheers Pat
Terrific technique Michael, and a valuable mini-tutorial for us lesser mortals Those rails look excellent in situ. cheers Pat
- 749 replies
- albertic
- ocean liner
HMCSS Victoria 1855 by BANYAN - 1:72
BANYAN replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Thanks Carl- 1,013 replies
- gun dispatch vessel
- victoria
Stunning! The decorations set her off nicely and are very well executed. Are the carvings from Cherry also? cheers Pat
- 728 replies
- le fleuron
- 64 gun
A late comer Russ, somehow missed your new build - but better late than never I suppose Looks like another very nice Biloxi Lugger in the making. cheers Pat
- 420 replies
- captain roy
- lugger
Welcome back to the fray Dave; the boats are looking good! I need to get cracking as I only have the garboard planks on the yawl. I have been putting it off as I have been trying to get ahead on the Victoria, which has been taking an inordinate amouint of my time. cheers Pat
Thanks Russ, the shape had me bamboozled there for a while cheers Pat- 1,013 replies
- victoria
