BANYAN
SPECIAL CONTRIBUTOR
Everything posted by BANYAN
  1. Looks a good fit Michael; once you have the ladder sorted you will be in a good position to determine how the other gear/furniture will fit.. cheers Pat
  2. Look forward to it Matrim; looks like you have researched her fairly thoroughly. cheers Pat
  3. Nice work on the spars and rigging; coming along very nicely Augustus. cheers Pat
  4. Hi Keith, could these be a more modern version of the 'compressor/chain stop' used in ships from the mid-19th century. They used a cam arrangement to lift or raise the cable; when raised the bottom created a smaooth surface allowing the cable to run, when lowered it formed a depression into which a link would fall then be 'stopped'. As a final 'safety, a guillotine could be lowered/screwed down to lock the chain in place. The mechanism was controlled by a tackle fitted to the lever in the early days. Attached is a versions from the 1850's manufactured by Browne and Harfield (patented by them). The general shape of your sort of alludes to something similar. Have you search chain controller or chain compressor in the yacht chandlers web sites? Probably have but just in case. cheers Pat
  5. Geez that looks good Keith, really neat. Ah, I'm not the only one then (forgetting things that is!) cheers Pat
  6. Looks like you are well and truly on top of this Keith (pun intended ). I very much like the idea of the slot with sliding cams to help retain the rail in place and at the correct displacement against the bulwark. In hindsight I also wish I had thought of painting and masking the hull before adding the cap rail, as painting that proved a source of some exasperation cheers Pat
  7. Beautiful work as always Doris, your craftsmanship and the quality of the work continue to inspire. cheers Pat
  8. John, Michael, Carl, Keith, Druxey, Eberhard - thank you all for your very kind comments and encouragement; but as we all know we are our own worst critics Thanks also for the advice re turning acrylic; I have noted that all away. I think my issue is turning speed as I have put the 10K rpm mod onto my lathe to get the higher turning speeds required for a clean wood finish. The lowest speed is mid 1-2 k rpm, which is probably still too fast Anyway it is done now and I am onto to completing the pivot gun as best I can. Still some research required on the subject of 'ship's cranes as I need to make that decision very soon. The Contract called for 'two cranes' for ash removal. Still not sure what way to go, as I would have thought a 'goose neck' davit would have been the go, but as the Contract was specific for the 'fish davit' I think they may have specified it as such. That said, a full blown crane seems a bit excessive and there is nothing showing on the imagery. Cranes were around at the time and I have found two 'possible' illustrations/drawings of such items in the NMM (for this specific period) but they seem too big. As far as I can tell, a simple goose neck davit over the hatch would have done the trick? Any ideas? cheers Pat
  9. Hi Steven, a pity the paper doers not provide better evidence (and discussion) for your build. This seems a common theme in some maritime subjects where authors all disagree with each other rather than getting together to try and find common ground and then develop the 'thesis' etc from there Ayt least you now know you can discount that paper. Happy New Yeatr cheers Pat
  10. That looks so very realistic Michael; very nice work cheers Pat
  11. Niiice; you'll be done before you know it Rob. Happy New Year cheers Pat
  12. Allan, I am currently building at 1:72 but am finding it more and more difficult to add the level of detail I would like (although EdT seems to be able to accomplish it ) All future builds will be at 1:40 for the reasons already given, PLUS there is a much larger 'after market' for some bits and bobs you may wish to purchase rather than scratch build. cheers Pat
  13. Thanks John, this is what they should have looked like . Happy New Year to you both and wishing you a safe and fulfilling 2020 cheers Pat
  14. Another warm welcome from down under Matt. I'me sure that the help of our members you will be able to complete your next ship model. cheers Pat
  15. Great to see this stunning model back gracing our screens Michael. happy New year and the best of everything to you and yours for 2020. cheers Pat
  16. Hi all, after a short (ish) sojourn I am back at the modelling desk; a long list of 'honey please do' jobs and continued research (on the rigging) interrupted by the festive season is my excuse The following shows the additional work that has been done. The progress photo (before fitting the circular skylights) shows the broadside gun carriages loosely sited in their future position. I cannot progress these until we finish printing the 3D barrels but unfortunately my mate helping me with that, has a few health issues and that must take priority. I have the trunnion caps, tackles and breeching ropes ready to go once we are in a position to print the guns. the pivot gun slide has also been made and all the pieces for the carriage which sits on top have been cut but not yet assembled. The circular skylights were made from turned acrylic rod (8mm) and PE which I drew up and I had etched here in Melbourne. The photos show the 'prototype skylight which has since been cleaned up a little more. Al (alpayed on this forum - building the Danmark) turned these for me as I was doing something wrong and the rod kept melting on me. These formed the base with the spigot being used as the locating pins and a small hole was drilled in the top while still in the lathe to accept a brass pin. This pin is intended to represent a small rod and cover in the actual item that could be raised to allow ventilation through the skylight. The sides were photo etched with the brass vertical bars etched deeper so that when the top and bottom were painted to represent the wooden parts, it looked like the bars were recessed. The side were rolled and formed on a dowel then silver soldered for strength before painting. The conical part represents the bars over the top but at this scale it proved simply too difficult to include the wooden framing. Overall I think they came out ok, but I am tempted to redo the tops as I could not get the 'exact' diameter of the formed cone to sit on top of the side pieces. to the eye it looks fine, but a close inspection, especially through the camera shows they are not sitting uniformly on top of the side pieces. cheers, and a very happy, healthy and safe 2020 Pat
  17. Great progress Gaetan, up to your very high standards of workmanship as usual. Nice photos BTW. cheers Pat
  18. Hi all, I use the Beileshi with my glass and without - no issue either way but does affect the working distance. Gaetan, I was skeptical at first but they seem to be proper glass lenses and they do include the working distances per lens (by magnification). The table that came with mine state: Lens Plate Mag ratio Focus (Focal Length) 2 1.5x 20 inches 4 2x 10 inches 5 2.5x 8 inches 10 3.5x 4 inches cheers Pat
  19. Happy new year to you too mate; glad to see you could put in a few more hours (especially in this heat). That cage and netting looks great! A very convincing 'trampoline' - what material did you use, it looks a very fine mesh? cheers Pat
  20. Greg, I recently purchased a Beleshi Glass Lens headband (no light). While these are the enclosed type, I have found the reduced field of view does not interfere with my modelling. They also do not have a 'mounted' LED but I never use that feature anyway. I went for a 'package' deal that included 3 lenses of different focal lengths/magnification. I got these at a really good price through Amazon Australia. At first, based on the price, I was sceptical these were actually glass lenses but they are - much cheaper than many of the the other manufacturers and I have found them very good. The only issue being that because they are ground glass lenses the 'depth of field' is much more defined and dependent on the magnification selected. That said once you determine your working length/focal length they are very clear and easy to work with. I am going to invest in another pair (at that price not a problem) so that I have extra lenses and have two magnification levels to work with, without having to change out the lenses. Give me a bell or PM if you need extra info. cheers Pat
  21. Great technique for attaining the bowsprit shap in the bulwarks Keith; another idea to tuck away. Look forward to seeing your cap rails in situ. I put in a couple of hours today working on my skylights; posts to follow soon. cheers Pat
  22. Agree glass lenses; only way to go. cheers Pat
  23. Nice to see this beauty gracing our screens again Rob. cheers Pat
  24. You and me both mate; I don't think the workshop is a safe place for the next couple of days I have completed the 'honey please do' list so should be back into the model making seriously again in the NY. Best wishes for a great 2020 cheers Pat
