Everything posted by dvm27
I received my Volume II today and it's everything one could hope for. The accompanying CD with patterns and illustrations as well as printed plans make this one of the most well documented model builds I've ever seen. Ed and Bob (SeaWatch Books) have done a great service for ship modelers in general and plank on frame modelers in particular.
HMS Sussex by mij - Scale 1:48
dvm27 replied to mij's topic in - Build logs for subjects built 1501 - 1750
Excellent start MJ! I love the indexed setup you're using. Insuring the frames are centered and the maximum height of breadth is where it belongs should be relatively easy with this jig. -
Sherline lathe - distance between centers
dvm27 replied to Landlubber Mike's topic in Modeling tools and Workshop Equipment
You can do the same with a Sherline, provided the thickness of the stock does not exceed 3/8". I found that turning long lengths of wood into masts was very difficult due to deflection over the lathe bed (on longer yards and masts). I believe it easier to make them as per the original by turning them into eight, then sixteen sided blanks before rounding them by hand. There is an excellent description in Antscherl's Rigging a Sixth Rate Sloop of War. Personally, if I was to purchase another Sherline lathe it would have the smaller bed. -
Suggestions for an admiralty style model please
dvm27 replied to Shazmira's topic in Wood ship model kits
Actually, Chuck's completed Confederacy would be more appropriately be labelled a Georgian style model. Admiralty, or Navy Board style, usually refers to a model left in frame. If this is something you'd like to try I'd suggest starting with a cross-section model such as Echo, Triton. or bomb vessel cross-section. All three projects include excellent instructions for framing a contemporary ship model and will provide excellent practice for modelling a complete vessel in this manner. I believe the Hobby Mill provides framing sets for all three projects. -
ancre LE BONHOMME RICHARD by Jeronimo - FINISHED
dvm27 replied to Jeronimo's topic in - Build logs for subjects built 1751 - 1800
Love those barrels with individual staves even though they're mostly hidden by the lattice work and doors. Such attention to detail makes this a truly unique model.- 662 replies
- bonhomme richard
- frigate
Wonderful work, as always, Karl. Are you cutting the mortises for the carlings with the beams already glued in place or prior to fixing the beams?- 662 replies
- bonhomme richard
- frigate
Congratulations on the laying of the keel, Ed. I'm really looking forward to this build.
- 3,618 replies
- young america
- clipper
Problem is I believe Jim needs to sell something like 400 units to make it profitable. But if we each bought ten each...
Oscillating spindle sander!
Just ask Jim. He's always happy to provide this information.
Also looking forward to this build Ed. have you decided how you will build the hull? Frames, lifts, POB? I don't believe I've seen an historically correct plank on frame clipper ship model although I'm sure they exist.
- 3,618 replies
- young america
- clipper
Lovely Toni. You must have found the miniature hinge pins we included for those photo-etched hinges
- 1,449 replies
HMS Naiad 1797 by albert - FINISHED - 1/48
dvm27 replied to albert's topic in - Build logs for subjects built 1751 - 1800
Just from seeing your boxing joint, Albert, I can tell you're going to make a beautiful Naiad. -
SaturnV, If I understand your question correctly you are referring to the bevel of the frames. In the bow, the fore edge of each frame needs to be shaped to fay into the aft edge of the next frame. I would recommend not pre-bevelling the frames unless you are very experienced. It is best to install all the frames first, then bevel with 80 grit sandpaper, gouges etc. Once properly bevelled the frames will have a smooth surface for the planking to land on.
Alex, Are all the carvings cast as well? What about the rigols over the ports. They are quite nice.
- 227 replies
- cumberland
- 74 gun
