Posts posted by glbarlow
There’s no need for primer. The first layer is just the base for the second layer. Use all the wood filler you want and sand away as long as you don’t sand through it you’re fine. Take into account the second layer to the stern post but remember you’ll want to sand that layer smooth too
First and foremost don’t over think it. Have fun.
I remember every step of this build. It was so much more fun after getting all the copper plating finished.
1 hour ago, DelF said:
Chris kindly ran up a boxwood version
Well, aren’t we special😳😂
- Rustyj, chris watton and mtaylor
- 2
- 1
On 6/27/2020 at 10:09 AM, glbarlow said:
It’s linked in my post above, it’s a .pdf, not a video
On 11/6/2020 at 3:58 AM, Rik Thistle said:
somehow found it's way into the shipyard, opened itself and started assembling parts...strange!
I hate when that happens, but it seems to happen a lot to me too...🤣
- Edwardkenway, BobG and Rik Thistle
- 3
A cutter most likely would have a windless and not a capstan, so good choice.
Your deck is looking good, nice work. I like your moulding, and your macro photo. Probably interesting to drop down to this size from the huge Winnie.
I’ve always appreciated how you present the rigging, I note the double lines and appreciate the detail blow out as you place it, on the same sheet and near where it goes. I like seeing the full picture all at once so I can visualize how that detail fits in the bigger scheme. In other words, please continue as is. It’s worth it at least to me and I’m sure others.
I wasn’t entirely kidding about works of art. I’ve reached the stage with kits I rely far more on the plans than the instructions.
- DelF, chris watton, mtaylor and 2 others
- 5
2 minutes ago, DelF said:
the workshop needs new wallpaper!
Clearly plans are works of art, suggest to her having them all framed 😆
- DelF, chris watton and mtaylor
- 3
Such great detail that must be in that number of plan sheets, amazing!
- chris watton and mtaylor
- 2
1 hour ago, chris watton said:
designing the boats (28 foot pinnace, 24 foot launch and 22 foot yawl), which will be included with the kit,
Yikes 3 boats. The 4 on Vanguard took me forever, but I’m sure it will look great on the final product.
- mtaylor, Nirvana and chris watton
- 3
Nice to see another Cheerful underway. I can see you're in great shape for the square tuck
- Ryland Craze and mtaylor
- 2
Congratulations on this next release - I hope it sells well and helps fund Sphinx's development 😄
- DelF, Gord-Canada, mtaylor and 4 others
- 7
3 hours ago, glennard2523 said:
I am Ok at the woodworking skills but have great difficulty with the rigging aspects.
Like Derek I almost always drill out the hole in every block, use just the tiniest bit of CA and twist it a tiny bit while the CA is still wet. I pull all my line thru a block of bees wax before rigging it. Nothing wrong with any of those things.
I rig as many as possible of the blocks on the masts and yards before mounting them and mount blocks on the hull before it gets to crowded and I work inside out first with standing then running rigging.
My best rigging tool is a large needle with the threading end about 1/4th cut off leaving a nice Y that I can maneuver lines in tight places with the pointed end glued into a six inch long 4mm dowel, in fact I have two of these.
Aside from ratlines, I enjoy rigging. It’s a fun puzzle to weave together and really makes a model. I researched my Pegasus to get every rope it would have carried onboard and in the right place, it’s a nest that I’m not now sure how I pulled off, but it looks great.
I hope you come to enjoy this part and go back to finish rigging your Speedy.
- Ryland Craze and DelF
- 2
Wow, I knew it was a hard life, but that’s devastating.
I’m always amazed at your metalwork. I’ve never done any of that, but am going to have to try doing something. Your deck details are impressive. So much into one small (relative to our usual fare) craft.
Thanks guys. I definitely recommend both the weathering powder and the soft brushes to apply it - it's a subtle affect as you note but a very good one in making the guns look more realistic (but I'm not using the algae green on the water line of the hull just to be clear - its a metal only application for me.
It's supposed to be relaxing, not creating anxiety. I'd encourage you to check my two logs after you watch Chuck's videos and tutorials to see how I practically implemented them. As I said, I've built 9 models, but converting to Chuck's methods made a huge difference for me. I could have never single planked Cheerful as well as I did without having used it. It's not that hard once you get the hang of it, and it doesn't take that long to get the hang of it....
I had a very detailed Pegasus log that was lost in the great crash. Pegasus is my favorite build, in fact that’s it in my little signature bubble. I highly recommend you do two things, review and learn Chucks method of lining the hull and planking from the link Mugje provided and locate Blue Ensigns Pegasus build log since mine was lost). I converted to Chuck’s method and in my opinion there is no better way to learn how to plank a ship. Both my Nelson and Cheerful logs linked i. My signature line describe how I put it to work.
Measurements and tapering planks are an essential part of planking, but every hull even of the same model are different. Chuck’s method ensure the measurements you get are for your hull, not what someone else got. The most important recommendation I have is not to overthink it and not get lost in details and too many sources of advice and tutorials. Pick one that works for you and make sawdust.
Have fun!
As I posted earlier I took a break from the hull to put together some cannon, turns out it wasn’t much of a break - it’s a process to assemble these guns. I thought I’d take a step back and show some of how they came about. Likely nothing novel, most of us have made plenty of ship’s guns.
Before I left the hull I took the time to make a little jig to drill the holes for the gun eyelet’s and ring bolts at each port. I won’t add them until later, but it was easier to drill the holes with an empty deck.
Next up was giving the brass guns an acetone bath as painting prep and then testing my eyes and fingers to put the tiny emblems on each barrel. I almost gave up, it does take some effort. It’s a good thing Chuck’s mini-kit provides plenty of extra’s, a lot died during the process. The secret is putting glue on a pin to apply it. Once you have as little glue as possible, then put less than that on the emblem. Fine point tweezers are essential.
I’m not big on using an airbrush, I have a very basic propellent can model I rarely use. My thought is the ships of the time weren’t painted with spray guns so… (plus it seems more trouble than its worth, but to each their own, it looks good well done). It’s different with metal cannons, so airbrushed they are. I used a different primer paint this time as I noted in my earlier post.
The mini-kits for the guns include everything needed to build the carriages from laser cut parts, so after making the first one it was time for a production line.
As many have noted before, a jig is essential to aligning the axels to the sides. Cleaning off the laser char from all the small pieces is a chore but the red paint would show through if I hadn’t, so time well spent. Rounding off the axels is also a process, there are no extra axels in the kit so it’s a process done slowly. I suppose maybe I could have made my own quoin handles but my patience was already tested enough with small part assembly. Fortunately I had 5mm brass belaying pins that fit the bill.
Then it’s hand painting each carriage and mounting the trucks. Someone said to paint them anything but black, I’m not in on that so mine are in fact black. Just to be different and because I like the look I left the axels natural (though I may not stay with that choice, we’ll see later).
Added to my 'never done before' list is the use of weathering powder, I was skeptical but I have to say it made all the frustration of applying the emblems worthwhile. The Doc O-Brien’s Rusty Brown gave life to the barrels and really makes the emblems stand out. I went all in and bought this weathering brush set from MicroMart, I’m sure any brush would work but using one to apply, one to even out and the large very soft brush as a final buff really is worth the expense. No surprise, the key is minimalism - it takes very little power to make it work. I was pretty basic on the cap square, cut from black card paper, I may add a hinge later when I make the next five. I did use the weathering powder on the card strip, it’s just too black next to the barrel otherwise.
So after a lot more time than I thought it would take I have the two long guns and five of the ten carronades finished. There are ring bolts that go on the sides of all the carriages (and the hull) but that comes later by making the breech ropes as a single unit off the ship, the holes for them are drilled and ready. The previous post actually show the barrels better than these photos, they have more of a rusty tinge to them than the blue black they appear here. Maybe I'll get better photos when my iPhone 12 Pro arrives later this week.
I enjoyed making the guns, among other things it put off figuring out scarph joints for a while. There were times though when I felt like mini-me here and was ready to blow things up. I still have five more to do the next time I need a break from the deck work.
Off to the deck I go - maybe to never be heard from again.
Amongst the many interesting aspects of this vessel, I wonder about the mundane fact of how many fishermen fell overboard in rough seas with so little to keep them from doing so.🥶
- Blue Ensign and Martin W
- 2
On 10/24/2020 at 7:32 AM, VTHokiEE said:
the fly tying glue
Did you find a US source for Derek’s special glue?
- Old Collingwood and VTHokiEE
- 2
Chris Watton and Vanguard Models news and updates
in Traders, Dealers, Buying or Selling anything? - Discuss New Products and Ship Model Goodies here as well!!
Nice!
