Posts posted by glbarlow
I think maybe 2 or 3 of my Sphinx’s boats will have been lost in a storm 🤪😂🤣
- GuntherMT, chris watton and mtaylor
1
2
I spent an entire day making two ladders, the things we do.
You’ll be really good at it my the ninth one 😂
- FrankWouts, Matt D and Rustyj
3
Very clean crisp work. Nice job on the rigging, the seized blocks look great.
- VTHokiEE, Dfell and Old Collingwood
3
Quite the dissertation. It is my opinion that your ‘facts’ are just another opinion and like all opinions, including mine, worth about as much as that toilet paper roll - though everyone knows it should hang down from the front.
Anyway, I use CA and I’m happy doing it. This post has gone off the rails. I’m out. 😇
Just so someone says it, a few of you need to add “in your opinion” to some of your bold unbending statements.
So in my opinion: 1.CA is the best choice for planking a hull using Chuck’s method linked above, PVA is just so unnecessary. 2. I have models over 25 years old done with CA that are just fine and look great. 3. I don’t think any well built ship model survives dropping to the floor, it’s best not to do that. 3. Edge gluing is not only totally unnecessary it’s also detrimental to the look of the hull. 4. I doubt the humidity variance in most first world homes creates an issue. 5. I’ll put up my nine models as examples of using CA for hulls any time.
I don’t understand why people don’t just acknowledge design and build preferences as just that, a preference. There are many ways that are right and many that work just fine. There are very few that are wrong, using CA for hull planking is not one of those. Why denigrate a method different than your preference, why not instead offer your method as one of many options. In my opinion...
- toms10, Richard44, Keithbrad80 and 3 others
6
My kingdom for an ample supply of boxwood. It’s going to look great!
- VTHokiEE, chris watton and FrankWouts
3
Nice looking hull, very smooth. 120 grit, go big or go home🤪
Completing the Deck
Decking Cheerful seems like three different projects, planking the center around the deck furniture, the first belt of six curved planks, and the final belt of hooked scarphs. It took me a while to sort out how to do this third step and interesting design features of Cheerful’s deck, at least for me it wasn’t readily obvious how to create them, or at least create ones that fit. So I thought for those interested, and with my never ending quest to provide way too much detail, I thought I’d share how I did it. I again acknowledge there are likely better and more than one way (write your own log:-) this is just how did them.
I did some measurements and determined that starting with 5/16 planks (the widest of my selection of cedar) would be wide enough to include the scarphs. I could have also used 3 inch wide sheet wood, and maybe I should have, but the 5/16 was my choice so I ripped some planks and off I went.
Back from the “hook” itself the plank obviously has to be 3/16 to match the rest of the deck so I slide a 3/16 plank until it met the margin plank and marked that line. I decided after some experimentation I wanted a 3mm fit “into the hook” on the bow and 2mm on the stern. I selected the smaller size on the stern because the hook portion would be too large for my taste due the more narrow overall angle, so the fit was largely dictated by my choice of size of the resulting hook (or hood as I’ve seen some call it). So I made a little jigs, one 3mm and one 2mm. I slide that under the 3/16 plank and drew a line the would become the size and shape of the hook to check the look and also put a light mark at that spot on the margin plank as shown in the photo.
Next to get the required angle on the front edge I fit and cut some Tamiya tape. You can see my earlier marks below the tape.
Then I transferred the tape to my 5/16 plank and made the cut.
I slid the full plank into its future home and transferred the pencil mark I’d made on the margin plank to the 5/16 plank, and the first step is done. That mark defines the hook forward and the 3/16 plank behind. The cut of the angle has to be larger than the mark, otherwise it won't be a hook, this can be adjusted by the width of the fit into the hook, part of the measurement process that led me to the 3mm and 2mm jigs.
Next I used a 3/16 plank to mark its width onto the 5/16 plank, holding it firm with my heavy ruler and handy square, but double checked it with another ruler. As it turns out I needed to remove 3mm (so fun jumping back and forth from imperial to metric).
My scarph is marked and ready to cut. The total length of each scarph is determined by the butt joint plan I noted in my last post, the total length of course varied for each of the twelve (6 per side) I made.
Since I can’t take a photo and wield a #11 blade at the same time here is the result. I used my little 220 and 320 grit sanding blocks and files to finish it up. I also slightly beveled the back side on all four sides. This is an important step I believe. I want the top edge dictating the fit not any minor differences on the sides or bottom edge.
And what do you know, it fits. It's ok if its short of the mark a bit (resulted from squaring it up and matching it to the starboard size in this case) it just can't be longer than the mark on the margin plank. I also had to remember not to forget the pencil mark on the edge closes to the side to simulate caulking.
To complete the row I do the same process on the stern then determine the length of a 3/16 plank to fit between them. I cut that plank a little long then use my Byrnes Sander extremely gently and slowly form the edge until I have the right length (it’s actually spinning in this photo, close as I’ll get to live action shots).
Then it’s back to the bending station to get the required curve for a tight fit. I’ve said it multiple times and will say it once more (for the last time in this log as I don’t think there is anything left to bend): Chuck's technique of using dry heat in the form of a travel iron (so much quieter and quicker than a hair dryer) is the way to bend wood in my humble opinion. The only water I use is dipping my finger into the little pitcher shown in the photo and lightly wetting the wood. I can (and have) unbend the same plank if I bend it too much. I have a couple of templates depending on what curve I need and always put a scrap piece between the plank and clamp to keep it from marking or crimping the plank. This process just works for me.
Here’s the completed row, the three pieces now glued to the deck. I don’t think I got the curve exactly right on the first belt. Oh well, it’s the curve I have.
I hope this step by step detail helps someone someday, it was a certainly process of discovery for me. Yet again a thing I’d never done before, thank you @Chuck and Cheerful.
Here’s the nearly completed deck. I’m not done, I’ll lightly sand the first coat of WOP and apply a second plus there are a few blemishes I’ll attend to before moving on. I personally think Chuck’s design and instructions make for a pretty interesting deck. There’s a lot more going on than my usual straight bow to stern planking.
So many joints and angles here at the stern. I think it’s pretty cool how it all fits together, making each plank was a process in and of itself.
A look at the bow and it’s interlocking pieces. The planks aren’t discolored in front of the hatches, that’s the shadow they’re casting from the poor orientation of my workshop light above and behind.
Finally another above look. My only minor disappointment is the amount of variation in the cedar color. The WOP did even it out a lot but there is more variation than on the hull. The 5/16 is darker and as it was used only on the outside stands out, plus there is a much paler plank running either side of center. I like that it’s not all the same, it makes it come alive, I just kinda wish there was just a little less variation. I’m sure that will all fade together as the rest of the deck and cannon are added. Again there are shadows from lighting, I first thought what are those squares, then realized its window light coming through the gun ports on the far side plus the work light coming from behind.
My grumbling aside, I’m happy with the finally completed hull. As Chuck noted in the monograph, with the deck complete all the big messy stuff is done. Now I begin to add the details, sub-assemblies and mini-kits to make it a ship.
I started April 30th, so it’s been eight months to reach this point. What a fun ride its been.
21 hours ago, Rik Thistle said:
least painful fix
Where's the fun in that, sometimes I think I wind up doing the most painful rebuild possible 😄
Being willing to step back and improve something is the sign of a good modeler, its only the impossibly great ones that never have do-overs.
Amazing detail and quality, museum ready.
- FrankWouts and mtaylor
2
Fine work Rusty, your skill is showing thru as usual with the quality of the planking not to mention how quickly you reached this point.
This is really good work Tim. Rigging is fun for me, it means you’re close to the end. I thin your mouse and stay collar look fine, as BE points out you won’t notice it once you step back other than seeing it as a unit. The rigging and deck looks great, you’re going to finish with a fine model.
- VTHokiEE and Old Collingwood
2
Probably still plenty of thickness to fill, sand, and repaint the hull. Nice job on the Wales, remove and replace is a way of life for me...
- Rik Thistle and BobG
2
As others mentioned clove hitches are the way to go, but the lazy way is half hitches on the inner shrouds but these may slip. I hate rat lines, but do find once I get in a rhythm it becomes almost meditative. An option is a touch of your choice of glue on each knot to keep them there.
One key suggestion is to create a grid on paper the height of the shrouds (I use Excel, but there are better ways) with horizontal lines spaced per the plans but also vertical lines to make sure the shrouds keep their line and don’t get pulled in. Place this paper behind the shrouds. It’s both a guide and keeps you from going cross-eyed trying to see the ropes.
- toms10, mtaylor and jeff watts
2
1
On 12/13/2020 at 5:58 AM, Rik Thistle said:
decking layout
18 hours ago, Freebird said:new to this forum
On 12/13/2020 at 10:14 AM, Matt D said:deck lining.
47 minutes ago, BobG said:attention to detail
Thank you all for your kind comments, they are really appreciated. @chuck has designed such a nice model, it’s a fun, but challenging, build. Also thanks for the new likes and followers.
I’ve finished one side of the deck, I hope to complete it by this weekend.
Wipe On Poly Techniques
in Painting, finishing and weathering products and techniques
Posted · Edited by glbarlow
It’s $13 a can. 😞
