Everything posted by druxey
Oh, I'm sure you'll do a nice job on the kit 'as is'. But you may feel you want to kit bash a different kit later on.... Just sayin'!
- 109 replies
- Finished
- Artesania Latina
Life happens! We understand, You'll get back to it when you can.
- 8 replies
- Model Shipways
- Lowell Grand Banks Dory
Your comments on the kit scale fitting out make me think you are on your way to either kit-bashing (modifying the model as you build it) or even scratch building!
- 109 replies
- Finished
- Artesania Latina
If you must use wire wool, use bronze not steel for the reasons given above. However, it's hard to find these days.
That is one of the critical points in forming the quarter gallery; everything is parallel to each other. You should be fine from here on.
- 399 replies
- winchelsea
- Syren Ship Model Company
Ships name 1700s
druxey replied to DaveBaxt's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
B. E.: I know that the French usually showed the ship's name in a compartment on the counter, but was not aware of this being done by the British in the early 19th century. Victory's name was certainly seen this way in early 1900's photographs (below), and persisted until changed to something more appropriate recently. -
Wet and dry paper is used for metal, not wood. This, and the fact you are using extremely fine grades is why you are getting clogging. Garnet, emery, aluminum oxide and silicon carbide are used on wood. See: https://www.empireabrasives.com/blog/sandpaper-grit/ Usually, for wood, 400-grit is as fine as you need to go.
Best wishes as you manage an elderly parent. It's never easy.
- 2,634 replies
- heller
- soleil royal
(and 9 more)
Ships name 1700s
British ships' names appeared across their counters officially in 1772, although this may have formally been done for a few years earlier. The practice seems to have been discontinued during the Napoleonic wars. -
Soft, medium or stiff brushes?
druxey replied to CPDDET's topic in Painting, finishing and weathering products and techniques
Look after a good quality sable and it will last you years. I have some over 30 years old and they are still in good shape. Cheap brushes are a snare and delusion. You have to keep buying them over and over and they will shed hairs in your beautiful fresh coat of paint! -
Swan-Class Sloop by Stuglo - FINISHED - 1:48
druxey replied to stuglo's topic in - Build logs for subjects built 1751 - 1800
The illustration shows full-size practice. You can cheat, as long as the end-result looks right.- 475 replies
Glad you had such a good time. I'm so sorry that I had to miss the great showing this time. U.S.: Why you no open land border to nice, polite, vaccinated Canadians?
- 2,634 replies
- heller
- soleil royal
(and 9 more)
"When all else fails, read the instructions!" Good save, though!- 475 replies
