Everything posted by druxey
Planking
druxey replied to bluenose2's topic in Building, Framing, Planking and plating a ships hull and deck
Also, kit 'walnut' may or may not be.... -
Welcome aboard! There are several fine builders on this site who happen to be female. Check them out.
Is there a suitable solvent you can use to dilute the Acrifix and reduce its viscosity? Lovely detail. Again I marvel what you are able to do at this small scale.
HMS EURYALUS by Matiz - FINISHED - scale 1:56
druxey replied to matiz's topic in - Build logs for subjects built 1801 - 1850
A bin usually has a lid, not a door. Is this the case here? -
Spoken like a true Aussie, Pat!
You forgot to mention: ALLEN KEY: Is always a metric size when you require duodecimal or vice versa. Either variety is effective at converting hexagonal recesses into round ones. RAZOR SAW: Is neither a razor nor, usually, a saw. DISPOSABLE BLADE: Definitely. ROBERTSON SCREWS: Those weird Canadian screws with square recesses that use screwdrivers which actually work. Oh, well. Too bad, America. I'm sure that there are others.
I've built many fully framed hulls without owning a spindle sander, as I'm sure others have as well. Some joints are far better cut using a very sharp chisel, unless you are Greg and have all the bells and whistles for a milling machine! For cutting curved pieces you will need a jeweler's saw and bench pin if you do not own a scroll saw.
Yup - but you'll never make that mistake again! It's all part of the learning process, so get out the rubbing alcohol to release the glue.... You'll be happy that you re-did this. As you already know, a mistake tends to compound itself if left untreated.
- 23 replies
- Lowell Grand Banks Dory
- Model Shipways
Welcome! And yes, rigging is scary if you've never done it before. However, if you take it slowly and methodically, line by line, it becomes less scary. Like any complex job, break it down into small steps. Also, there's lots of helpful folk available here to answer any really vexing questions you may have.
Also, if you do not have a removable insert, the paint-wet material will stick to the board, and will tear when trying to get it off!
Mike: The insert can be of any material that is the same thickness as the frame. Usually the seams are drawn or painted with a slightly thicker paint than is used on the sail. It is not normally white. Boltropes in this method are glued on using acrylic matt medium.
Actually the new rabbit hole you've opened is fascinating; predating Olivier, as it does.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Nutria (coypu) is a different rodent!
Mike: the small booklet on making SilkSpan sails from SeaWatch Books will answer all your questions. However, if you wet any form of paper, it will buckle and distort as it dries. Therefore one wets and stretches paper on a frame. It will dry taut and flat. If rewetted (with dilute acrylic paint, for instance) it will stay flat as long as it is stretched until dry. Then one can cut it free and it will not buckle.
Welcome aboard, Adam!
Well done. All you need now is the lobster!
- 22 replies
- Finished
