Everything posted by druxey
It was common practice (in naval dockyards, at least) to launch, check for any leaky seams, drydock, seal, then copper the bottom. Otherwise it would be harder to detect the source of water ingress and a pain to remove the copper to caulk the offending seam(s.)
- 3,560 replies
- clipper
- hull model
AIRBRUSH OPINIONS PLEASE...
druxey replied to MadDogMcQ's topic in Painting, finishing and weathering products and techniques
You will have as many varying opinions as replies here! I've used all the usual makes mentioned and they are all fine. However, for ease of cleaning and no easily damaged long needles, you might consider Aztek as an alternative.- 40 replies
- best airbrush
- compressor
Now you know the meaning of the word 'druxey': rotten to the core. It is a form of wood rot found in the shipyard: spongy white veins inside logs.
- 3,560 replies
- clipper
- hull model
Are you reeving the laniard in the correct direction or is your line not 'hardened'?
I always thought canaries were yellow, not salmon colored! (Another 'druxey correction')? Seriously, I'm very flattered.
- 3,560 replies
- clipper
- hull model
We await the results of the Museum's findings!
Cutting and shaping masts: tips on how to do it.
druxey replied to Peterhudson's topic in Masting, rigging and sails
Seems like using a sledgehammer to crack a nut. None of my masts and spars have seen a lathe. It is not difficult to start with square stock marked out (don't need a four jaw chuck!), cut it eight-square except fo the square sections, then round off the parts that need it, using strips of sandpaper back and forth until the 'flats' just disappear. You don't need a lathe with a long bed ($$$), 4 jaw chuck ($$), steady ($$), filing rest ($$) or other paraphernalia. Just pencil and rule, sharp chisel and sandpaper. There; I just saved you a ton of money! -
Welcome. You are already well versed in modelmaking!
In the article the builder is Donald McCabe, not McKay!
- 3,560 replies
- clipper
- hull model
Take or send these images either to National Museums Scotland or the British Museum.
Welcome to the Canuck contingent here!
Well, back on topic. It was a fun diversion, though! I'm sure that the full-length columns will be less likely to collapse than the originals, so perhaps it was a fortunate accident. Glad you could save the decorative painted part of the xylokastra. Stupid question: couldn't you find thread in the color you needed without having to make the witches' brew of dye?
With all due respect, the bow flare-out to the bowsprit seems less extreme in the launch photo than your drawing. Something more like:
- 3,560 replies
- clipper
- hull model
Mots d'heures gousses rames! That takes me back a few years. Chortled my way through it (if anyone doesn't know what the book is about, say the words out loud.)
From paintings I've seen, I would agree that the yellow ochre was more of a buff color. Of course this is my subjective opinion but, as a designer, I've a pretty good color memory.
