druxey
Everything posted by druxey
  1. Nicely done, Ben. And Greg has a good point - it has happened to me as well!
  2. In the past, at 1:48, I've put together several pieces to form those compound curves. The rail also curves in plan view AND is sloped as seen from the side!)
  3. You assume a distance of the stern post overhang using an estimated overall 85' 0", or a measured 6' 9". The ratio of 6' 9" to 18' 0" is very close to 1:2.5 which is what I suspect Baker used in his construction. That angle produced by that ratio is 22 degrees. See how that fits, Waldemar.
  4. You may find that the angle 20.5 degrees is actually a slope with a ratio of x inches in y inches (or feet).
  5. Nice wiggly tafferel rail, but the number of cross-grain sections will be difficult to work with....
  6. Welcome aboard!
  7. More CNC.... Soon you can just sit back and let automation take over!
  8. Belated happy anniversary and birthday, Alan! A for (repeated) effort! Hopefully all goes well this time around.
  9. It appears that the fairing over the sixth bulkhead from the bow needs further beveling. There should not be an angle to the garboard in the area where you have cut it. Check it out.
  10. Was notching both for floors and first futtock cross-chocks a deliberate choice , Chuck?
  11. Thanks, Waldemar. I did understand that the limber channel drawings were representative, based on findings. Also I appreciate the clarification on the figures written on the cross section. Is the difference between the number and actual radius perhaps due to distortion over time?
  12. I've never seen a larger, clearer version of the plan that you are overlaying on, Waldemar. That figure written on the plan; does it read 5.2634? If so, what does this signify? I've been pondering your illustration of deadrise/limber channels. It begs the question as to when (in naval ships) the channels were moved to run above the floor timbers. The variants you show are fascinating, especially version E that runs centrally above the keel.
  13. Most ingenious, Chuck!!!! You certainly are a creative problem solver. Well done.
  14. I note some other near ratios on your latest iteration, Waldemar! Might they be exact, but for distortion over time and reproduction, I wonder? That 11.5 is sooo close to 12, for instance, as is 24.3 close to twice 12!
  15. Also, even thin tape is too wide for the purpose. One can move the thread with white glue incrementally by moistening a finger and rolling the thread as needed. See the planking tutorial by David Antscherl on this site.
  16. Thank you, Waldemar. My impression is that ratios were very common - often decimal rather than duodecimal.
  17. Definitely additive work is more forgiving than subtractive!
  18. A very respectable job of the tricky headwork, particularly if you've not done this before.
  19. Fascinating topic/discussion! What relationship is there - if any - between the span across the supposed first (lower) deck and the keel length and moulded breadth?
  20. You won't want to make the captain (whomsoever he may be!) cross by that missing cross! Coming along famously.
